Komatsu Engine SA6D170-A-1P-7U 10001-UP Parts Catalog
Model: Komatsu SA6D170-A-1P-7U Engine
Number of Pages: 166 Pages
SA6D170-A-1P-7U S N 10001-UP
HEAD COVER MOUNTING
AIR INTAKE MANIFOLD AND AFTER COOLER (HIGH ALTITUDE SPEC.)
AIR INTAKE (TURBOCHARGER TO AFTER COOLER)
AIR INTAKE (TURBOCHARGER TO AFTER COOLER) (HIGH ALTITUDE SPEC.)
AFTER COOLER WATER PIPING (HIGH ALTITUDE SPEC.)
AIR INTAKE CONNECTION
TURBOCHARGER AND SHIELD COVER (HIGH ALTITUDE SPEC.) (FOR PERU)
TURBOCHARGER (TL7701) (INNER PARTS)
TURBOCHARGER LUBRICATING OIL PIPING (HIGH ALTITUDE SPEC.) (FOR PERU)
TURBOCHARGER WATER PIPING (HIGH ALTITUDE SPEC.) (FOR PERU)
MUFFLER CONNECTION
WATER MANIFOLD
THERMOSTAT AND THERMOSTAT HOUSING (ULTRA ALTITUDE SPEC.)
WATER TEMPERATURE SENSOR AND WIRING
CYLINDER BLOCK (FOR FCD PISTON)
CYLINDER BLOCK (FCD PISTON SPEC.)
CYLINDER BLOCK BLIND COVER
GEAR CASE AND FRONT COVER (MECHANICAL PUMP SPEC.)
FRONT COVER ACCESSORY (MECHANICAL GOVERNOR SPEC.)
OIL FILLER (MECHANICAL GOVERNOR SPEC.) (FOR HD465-5)
OIL PAN AND SUCTION TUBE (FOR EXCEPT JAPAN)
OIL PAN AND SUCTION TUBE (LESS OIL LEVEL SENSOR) (MECHANICAL GOVERNOR SPEC.)
OIL LEVEL GAUGE (FOR EXCEPT JAPAN)
OIL LEVEL GAUGE (LESS OIL LEVEL SENSOR) (MECHANICAL GOVERNOR SPEC.)
FLYWHEEL HOUSING (MECHANICAL GOVERNOR SPEC.) (DRY TYPE)
FLYWHEEL (FOR HD465-5)
ENGINE MOUNTING (FOR HD465-5)
VIBRATION DAMPER
PISTON (FOR FCD PISTON)
CRANK PULLEY (HARDENING PULLEY SPEC.)
CAMSHAFT AND CAMFOLLOWER
ROCKER ARM HOUSING (FOR NO
FRONT POWER TAKE OFF (AIR COMPRESSOR DRIVE) (SANDY AND DUSTY SPEC.)
OIL FILTER (WITH ALARM)
LUBRICATING OIL FILTER PIPING (WITH ALARM)
MECHANICAL PUMP
OIL COOLER MOUNTING
FUEL INJECTION PUMP (HIGH ALTITUDE SPEC.) (FOR PERU)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (HIGH ALTITUDE SPEC.) (FOR PERU) (INNER PARTS)
FUEL INJECTION PUMP BRACKET AND FUEL PIPING
FUEL INJECTION PUMP DRIVE
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN (MECHANICAL GOVERNOR SPEC.)
AIR INTAKE MANIFOLD COVER (WITHOUT AUTO PRIMING SYSTEM)
ENGINE STOP MOTOR
ENGINE STOP MOTOR LINKAGE
COOLING FAN (SUCTION TYPE)
TENSION PULLEY
FAN BELT
ALTERNATOR MOUNTING (50A)
ALTERNATOR DRIVE (HARDENING PULLEY SPEC.)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7 (2)
STARTING MOTOR (7 (3)
STARTING MOTOR (7 (4)
STARTING MOTOR (7 (5)
SAFETY GUARD (INJECTION PUMP DRIVE AND FUEL TUBE)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR PIPING (1 2) (AIR LINE)
AIR COMPRESSOR PIPING (2 2) (WATER LINE)
AIR COMPRESSOR (INNER PARTS)
CYLINDER HEAD GASKET KIT (HD465-5) (EXCEPT JAPAN)
CYLINDER BLOCK GASKET KIT (FOR HD465-5)
WATER PUMP GASKET KIT (FOR HD465-5)
AIR COMPRESSOR GASKET KIT (FOR HD465-5)
NAME PLATE (JAPANESE-ENGLISH)
PM-CLINIC (WATER COOLING TURBOCHARGER SPEC.)
HEAD COVER MOUNTING
MUFFLER CONNECTION
WATER MANIFOLD
VIBRATION DAMPER
MECHANICAL PUMP
OIL COOLER MOUNTING
ENGINE STOP MOTOR
TENSION PULLEY
FAN BELT
