Komatsu Engine SA6D155-4A 50816-UP Parts Catalog
Model: Komatsu SA6D155-4A Engine
Serial Number: 50816-UP
Number of Pages: 115 Pages
SA6D155-4A S N 50816-UP
COMPRESSION RELEASE
AIR INTAKE MANIFOLD AND AFTER COOLER
AIR CLEANER AND PRE-CLEANER
TURBOCHARGER (KTR130-9G AND KTR130-9G-2) (INNER PARTS)
WATER MANIFOLD AND THERMOSTAT
GEAR CASE AND COVER
POWER TAKE OFF
CRANKSHAFT AND VIBRATION DAMER
OIL STRAINER AND PIPING
LUBRICATING OIL FILTER
BYPASS FILTER
P.T.O. LUBRICATING OIL PIPING
CAMSHAFT LUBRICATING OIL PIPING
FUEL INJECTION PUMP AND PIPING (1 2)
FUEL INJECTION PUMP AND PIPING (2 2)
FUEL INJECTION PUMP DRIVE AND AUTOMATIC TIMER
AUTO PRIMING SYSTEM (1 2)
AUTO PRIMING SYSTEM (2 2)
AUTO PRIMING SYSTEM CONTROL UNIT
AUTOMATIC TIMER
WATER PUMP (1 2)
WATER PUMP (2 2)
COOLING FAN AND ACCESSORY DRIVE
TENSION PULLEY
ALTERNATOR AND MOUNTING (35A)
ALTERNATOR AND MOUNTING (50A)
ALTERNATOR DRIVE
STARTING MOTOR AND MOUNTING
SAFETY RELAY
STARTING MOTOR (11KW)
TOOL AND KIT
