Komatsu Engine SA6D155-4A-35 20338-UP Parts Catalog
Model: Komatsu SA6D155-4A-35 Engine
Serial Number: 20338-UP
Number of Pages: 168 Pages
SA6D155-4A-35 S N 20338-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
COMPRESSION RELEASE
AIR INTAKE MANIFOLD AND AFTER COOLER
PRE-HEATER NOZZLE AND PIPING
AIR INTAKE CONNECTION
EXHAUST MANIFOLD AND TURBOCHARGER
WATER MANIFOLD AND THERMOSTAT
TURBOCHARGER
AIR CLEANER AND PRE-CLEANER
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
GEAR CASE AND COVER
OIL PAN
OIL PAN HEATER (TBG SPEC. AND FRENCH NOISE SUPPRESSION SPEC.)
OIL PAN (COLD WEATHER SPEC.)
HEATER (COLD WEATHER SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING
POWER TAKE OFF
CRANKSHAFT AND VIBRATION DAMPER
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
ALTERNATOR DRIVE (800W)
ALTERNATOR DRIVE (800W) (35A) (1200W) (50A)
ALTERNATOR DRIVE (SANDY AND DUSTY SPEC.)
ENGINE SUPPORT
ENGINE SUPPORT (TBG SPEC. AND FRENCH NOSIE SUPPRESSION SPEC.)
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
OIL STRAINER AND PIPING
LUBRICATING OIL FILTER
LUBRICATING OIL FILTER BRACKET
BYPASS FILTER
P.T.O. LUBRICATING OIL PIPING
CAMSHAFT LUBRICATING OIL PIPING
LUBRICATING OIL COOLER
FUEL SYSTEM
FUEL INJECTION PUMP AND MOUNTING
FUEL INJECTION PIPING AND SPILL PIPING
FUEL INJECTION PUMP AND MOUNTING (TBG SPEC)
INJECTION PUMP DRIVE AND SERVICE METER
FUEL FILTER AND MOUNTING
WATER SEPATOR
FUEL NOZZLE AND SPILL PIPE
AUTO PRIMING SYSTEM (1 3)
AUTO PRIMING SYSTEM (2 3)
AUTO PRIMING SYSTEM (3 3)
AUTO PRIMING SYSTEM (1 2)
AUTO PRIMING SYSTEM (2 2)
FUEL INJECTION PUMP (1 6)
FUEL INJECTION PUMP (2 6)
FUEL INJECTION PUMP (3 6)
FUEL INJECTION PUMP (4 6)
FUEL INJECTION PUMP (5 6)
FUEL INJECTION PUMP (6 6)
AUTOMATIC TIMER
NOZZLE HOLDER
FUEL INJECTION PUMP (1 6) (TBG SPEC)
FUEL INJECTION PUMP (2 6) (TBG SPEC)
FUEL INJECTION PUMP (3 6) (TBG SPEC)
FUEL INJECTION PUMP (4 6) (TBG SPEC)
FUEL INJECTION PUMP (5 6) (TBG SPEC)
FUEL INJECTION PUMP (6 6) (TBG SPEC)
COOLING AND ELECTRICAL SYSTEM
WATER PUMP (1 2)
WATER PUMP (2 2)
COOLING FAN AND FAN DRIVE
TENSION PULLEY AND SHAFT
CORROSION RESISTOR AND PIPING
DYNAMO AND MOUNTING (500W)(20A)
ALTERNATOR AND MOUNTING (800W)(35A)
ALTERNATOR AND MOUNTING (800W) (35A)(1200W) (50A)
ALTERNATOR AND MOUNTING (50A) (SANDY AND DUSTY SPEC.)
STARTING MOTOR AND MOUNTING (11KW)
REGULATOR AND SAFETY RELAY
A.P.S. CONTROL UNIT
DYNAMO (500W)(20A)
ALTERNATOR (800W)(35A)
ALTERNATOR (DELCOREMY) (50A)
ALTERNATOR (1200W)(50A)
ALTERNATOR (50A) (WITH HARDENING PULLEY) (INNER PARTS)
STARTING MOTOR (11KW)
TOOL AND KIT
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
COMPRESSION RELEASE
TURBOCHARGER
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
GEAR CASE AND COVER
OIL PAN
POWER TAKE OFF
CAMSHAFT AND TAPPET
ENGINE SUPPORT
BYPASS FILTER
FUEL SYSTEM
WATER SEPATOR
AUTOMATIC TIMER
NOZZLE HOLDER
WATER PUMP (1 2)
WATER PUMP (2 2)
A.P.S. CONTROL UNIT
DYNAMO (500W)(20A)
TOOL AND KIT
GASKET KIT
- KOMATSU Fault Codes
