Komatsu Engine SA6D140E-3J-7 110001-UP Parts Catalog
Model: Komatsu SA6D140E-3J-7 Engine
Serial Number: 110001-UP
Number of Pages: 151 Pages
SA6D140E-3J-7 S N 110001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
AIR CLEANER
EXHAUST MANIFOLD
TURBOCHARGER AND OIL PIPING
TURBOCHARGER AND OIL PIPING (1)
TURBOCHARGER AND OIL PIPING (LANDFILL SPEC)
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS)
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS) (1)
TURBOCHARGER (KTR110L-585E) (LANDFILL SPEC) (INNER PARTS)
HEAT SHIELD
HEAT SHIELD (LAND FILL SPEC.)
MUFFLER
MUFFLER (LANDFILL SPEC)
CYLINDER BLOCK
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR)
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR) (WITH COOLANT HEATER)
FRONT COVER (FRONT POWER TAKE OFF SPEC.) (WITH SLEEVE)
FRONT COVER MOUNTING AND BREATHER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (WITH COOLANT HEATER)
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
FLANGE
CAMSHAFT
ROCKER ARM
CAMFOLLOWER
FRONT POWER TAKE OFF (SANDY AND DUSTY SPEC.)
FRONT POWER TAKE OFF (NON DRIVE SPEC.)
OIL PUMP
OIL FILTER AND PIPING
OIL COOLER
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND)
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND)
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS)
FUEL SUPPLY PUMP (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
COMMON RAIL (INNER PARTS) (1)
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
FUEL FILTER (THREAD 1-5 8)
FUEL FILTER (EXTREMELY BAD FUEL GROUND SPEC.) (THREAD 1-5 8)
FUEL FILTER (EXTREMELY BAD FUEL GROUND SPEC.) (THREAD 1-1 4)
FUEL FILTER CARTRIDGE (SERVICE ONLY)
PRE FILTER MOUNTING (THREAD 1-1 4)
FUEL INJECTOR
FUEL RETURN
FUEL CONTROL (CHASSIS MOUNT)
WATER PUMP
WATER PUMP (LANDFILL SPEC)
THERMOSTAT AND AIR VENT
THERMOSTAT AND AIR VENT (LANDFILL SPEC)
CORROSION RESISTOR
WATER LINE PLUG (WITHOUT CORROSION RESISTOR)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (75A) (EXCEPT JAPAN)
ALTERNATOR MOUNTING (60A) (HARDENING PULLEY)
ALTERNATOR MOUNTING (90A) (SANDY AND DUSTY SPEC)
ALTERNATOR (75A) (INNER PARTS) (EXCEPT JAPAN)
ALTERNATOR (60A) (INNER PARTS) (HARDENING PULLEY)
ALTERNATOR (90A) (SANDY AND DUSTY SPEC) (INNER PARTS)
ALTERNATOR (75A) (INNER PARTS) (HARDENING PULLEY)
WIRING (1 3) SWITCH AND HEATER
WIRING (2 3) FUEL INJECTOR
WIRING (3 3) SENSOR
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
NAME PLATE AND CAUTION PLATE (ENGILIS) (REGULATION OF EPA NORTH AMERICA)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU)
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA)
FUEL CONTROL (CHASSIS MOUNT) (1)
SPARE PARTS
EXHAUST PIPE
