Komatsu Engine SA6D140E-3E-7 110001-UP Parts Catalog
Model: Komatsu SA6D140E-3E-7 Engine
Serial Number: 110001-UP
Number of Pages: 147 Pages
SA6D140E-3E-7 S N 110001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
AIR CLEANER
AIR CLEANER (INNER PARTS)
EXHAUST MANIFOLD
TURBOCHARGER AND OIL PIPING
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS)
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR)
CYLINDER BLOCK COVER AND OIL FILLER (COLD TERRAIN SPEC.)
FRONT COVER (AIR COMPRESSOR SPEC.)
FRONT COVER MOUNTING AND BREATHER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAMFOLLOWER
OIL PUMP
OIL FILTER
OIL COOLER
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA 2ND)
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (EXTREMELY BAD FUEL GROUND SPEC.)
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY EXTREMELY BAD FUEL GROUND SPEC.)
FUEL PUMP SUPPLY AND RETURN PIPING
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA 2ND)
FUEL PUMP SUPPLY AND RETURN PIPING (EXTREMELY BAD FUEL GROUND SPEC.)
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY EXTREMELY BAD FUEL GROUND SPEC.)
FUEL SUPPLY PUMP (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA 2ND) (INNER PARTS)
FUEL SUPPLY PUMP (PUMP) (EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY EXTREMELY BAD FUEL GROUND PSEC.) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA 2ND) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
COMMON RAIL (INNER PARTS)
COMMON RAIL (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA 2ND) (INNER PARTS)
COMMON RAIL (EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
COMMON RAIL (LOW-VISCOSITY EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
FUEL FILTER (THREAD 1-5 8)
FUEL FILTER CARTRIDGE (SERVICE ONLY)
WATER SEPARATOR (BAD FUEL GROUND SPEC.)
PRE FILTER MOUNTING (EXTREMELY BAD FUEL GROUND SPEC.) (THREAD 1-1 4)
PRE FILTER (SERVICE ONLY)
FUEL INJECTOR
FUEL RETURN
FUEL CONTROL (CHASSIS MOUNT)
WATER PUMP
THERMOSTAT AND AIR VENT
COOLING FAN
FAN PULLEY AND V-BELT
FAN DRIVE
CORROSION RESISTOR
WATER LINE PLUG (WITHOUT CORROSION RESISTOR)
ALTERNATOR MOUNTING (50A) (HARDENING PULLEY)
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (50A) (HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (INNER PARTS)
WIRING (1 3) SWITCH AND HEATER
WIRING (2 3) FUEL INJECTOR
WIRING (3 3) SENSOR
FRONT POWER TAKE OFF COVER (FOR COMPRESSOR LESS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
NAME PLATE AND CAUTION PLATE (FOR EU EXHAUST GAS REGULATION)
NAME PLATE AND CAUTION PLATE (ENGILIS) (REGULATION OF EU 2ND)
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA)
CAUTION PLATE
