Komatsu Engine SA6D140E-3C-7 110001-UP Parts Catalog
Model: Komatsu SA6D140E-3C-7 Engine
Serial Number: 110001-UP
Number of Pages: 130 Pages
SA6D140E-3C-7 S N 110001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
AIR CLEANER
AIR CLEANER (INNER PARTS)
EXHAUST MANIFOLD
TURBOCHARGER AND OIL PIPING
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS)
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR)
FRONT COVER (FRONT POWER TAKE OFF SPEC.) (WITH SLEEVE)
FRONT COVER MOUNTING AND BREATHER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAMFOLLOWER
FRONT POWER TAKE OFF (SANDY AND DUSTY SPEC.)
FRONT POWER TAKE OFF (NON DRIVE SPEC.)
OIL PUMP
OIL FILTER AND PIPING
OIL COOLER
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND)
FUEL PUMP SUPPLY AND RETURN PIPING
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND)
FUEL SUPPLY PUMP (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS)
COMMON RAIL (INNER PARTS)
COMMON RAIL (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
PRE FILTER MOUNTING (EXTREMELY BAD FUEL GROUND SPEC.) (THREAD 1-1 4)
FUEL INJECTOR
FUEL RETURN
FUEL CONTROL (CHASSIS MOUNT)
WATER PUMP
THERMOSTAT AND AIR VENT
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (35A) (HARDENING PULLEY)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (60A) (HARDENING PULLEY)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (35A) (HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (60A) (INNER PARTS) (HARDENING PULLEY)
ALTERNATOR (75A) (INNER PARTS) (HARDENING PULLEY)
WIRING (1 3) SWITCH AND HEATER
WIRING (2 3) FUEL INJECTOR
WIRING (3 3) SENSOR
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
NAME PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA)
NAME PLATE (FOR EU)
COOLING FAN
COOLING FAN (REVERSIBLE)
EXHAUST PIPE
FAN BELT
SPARE PARTS
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR CLEANER
EXHAUST MANIFOLD
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAMFOLLOWER
OIL PUMP
OIL COOLER
FUEL PIPING
FUEL INJECTOR
FUEL RETURN
WATER PUMP
TENSION PULLEY
CORROSION RESISTOR
WIRING (3 3) SENSOR
NAME PLATE (FOR EU)
COOLING FAN
EXHAUST PIPE
FAN BELT
SPARE PARTS
- KOMATSU Fault Codes
