Komatsu Engine SA6D140-1FF-G 10001-UP Parts Catalog
Model: Komatsu SA6D140-1FF-G Engine
Serial Number: 10001-UP
Number of Pages: 217 Pages
SA6D140-1FF-G S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD AND AFTER COOLER
AIR INTAKE MANIFOLD AND AFTER COOLER (FOR ELECTRICAL GOVERNOR)
AFTER COOLER WATER PIPING
AFTER COOLER WATER PIPING (FOR ELECTRICAL GOVERNOR)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (WITH EXHAUST BRAKE)
EXHAUST MANIFOLD (WITHOUT EXHAUST BRAKE)
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110G-344E) (INNER PARTS)
TURBOCHARGER (KTR110G-F45E) (INNER PARTS)
TURBOCHARGER OIL PIPING
EXHAUST BRAKE
EXHAUST BRAKE (REPAIR PARTS AND KIT)
EXHAUST BRAKE (INNER PARTS)
CYLINDER BLOCK
CYLINDER BLOCK (WITH VANDALISM PROTECTION)
OIL FILLER AND SENSOR
OIL FILLER AND SENSOR (WITH VANDALISM PROTECTION)
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
CAMFOLLOWER COVER (FOR ELECTRICAL GOVERNOR)
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (WITHOUT OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
OIL PAN AND SUCTION TUBE (WITHOUT OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (WITHOUT OIL LEVEL SENSOR)
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE (WITHOUT OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING (FOR ELECTRICAL GOVERNOR)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (WITH HARDENING PULLEY)
CRANK PULLEY (WITH NON HARDENING PULLEY)
ROCKER ARM
ROCKER ARM (FOR ELECTRICAL GOVERNOR)
CAMSHAFT AND CAMFOLLOWER
CAMSHAFT AND CAMFOLLOWER (FOR ELECTRICAL GOVERNOR)
FRONT POWER TAKE OFF
OIL PUMP
OIL ADAPTER
OIL FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP (PUMP) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (INNER PARTS) (1)
FUEL INJECTION PUMP PIPING (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP LUBRICATOR (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP DRIVE
FUEL INJECTION PUMP DRIVE (FOR ELECTRICAL GOVERNOR)
FUEL FILTER (FOR ELECTRICAL GOVERNOR)
FUEL FILTER
WATER SEPARATOR (WITH WATER SEPARATOR)
WATER SEPARATOR
FUEL LIFT PUMP (FOR ELECTRICAL GOVERNOR)
LIFT PUMP (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN (FOR ELECTRICAL GOVERNOR)
FUEL RETURN
ENGINE STOP MOTOR
FUEL CONTROL (FOR ELECTRICAL GOVERNOR)
CABLE SUPPORT (FOR ELECTRICAL GOVERNOR)
WATER PUMP
THERMOSTAT AND PIPING
AIR VENT
COOLING FAN
FAN PULLEY (NON HARDENING PULLEY)
FAN PULLEY (HARDENING PULLEY)
FAN DRIVE (NON HARDENING PULLEY)
FAN DRIVE (HARDENING PULLEY) (SANDY AND DUSTY SPEC.)
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (50A) (HARDENING PULLEY)
ALTERNATOR (60A) (INNRE PARTS)
ALTERNATOR (50A) (HARDENING PULLEY) (INNER PARTS)
HEATER WIRING
SAFETY GUARD
SAFETY GUARD (FOR ELECTRICAL GOVERNOR)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
AIR COMPRESSOR PIPING
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH)
NAME PLATE AND CAUTION PLATE (GERMAN)
NAME PLATE AND CAUTION PLATE (SPANISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (INDONESIAN)
NAME PLATE AND CAUTION PLATE (ITALIAN)
NAME PLATE AND CAUTION PLATE (GREEK)
NAME PLATE AND CAUTION PLATE (PORTUGUESE)
NAME PLATE AND CAUTION PLATE (POLISH)
NAME PLATE AND CAUTION PLATE (CZECH)
SENSOR (EXHAUST TEMPERTURE¤ OIL PRESSURE¤ AIR PRESSURE) (FOR PM-CLINIC)
