Komatsu Engine SA6D140-1EE 17739-UP Parts Catalog
Model: Komatsu SA6D140-1EE Engine
Serial Number: 17739-UP
Number of Pages: 205 Pages
SA6D140-1EE S N 17739-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD AND AFTER COOLER (EXCEPT JAPAN)
AFTER COOLER WATER PIPING (EXCEPT JAPAN)
AIR CLEANER
AIR CLEANER (SANDY AND DUSTY SPEC.)
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (INNER PARTS)
TURBOCHARGER OIL PIPING
HEAT SHIELD
MUFFLER (SANDY AND DUSTY SPEC.)
MUFFLER
EJECTOR PIPING (SANDY AND DUSTY SPEC.)
EJECTOR PIPING
CYLINDER BLOCK
CYLINDER BLOCK (COLD TERRAIN SPEC.)
OIL FILLER AND SENSOR
OIL FILLER AND SENSOR (COLD TERRAIN SPEC.)
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
CAMFOLLOWER COVER (WITH BYPASS OIL FILTER)
CAMFOLLOWER COVER (WITH BY-PASS OIL FILTER)
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT AND CAMFOLLOWER
FRONT POWER TAKE OFF
FRONT POWER TAKE OFF (SANDY AND DUSTY SPEC.)
OIL PUMP
OIL ADAPTER
OIL ADAPTER (WITH BY-PASS OIL FILTER)
OIL FILTER
OIL FILTER (WITH BY-PASS OIL FILTER)
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR AND PIPING
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
STOP MOTOR
FUEL CONTROL
WATER PUMP AND THERMOSTAT
AIR VENT
COOLING FAN
TENSION PULLEY
FAN BELT
CORROSION RESISTOR
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (50A) (INJURY FROM SALT TERRAIN SPEC.)
ALTERNATOR MOUNTING (50A) (EC SPEC.)
ALTERNATOR MOUNTING (75A) (EC SPEC.)
ALTERNATOR MOUNTING (50A) (INJURY FROM SALT TERRAIN SPEC.) (WITH COVER)
ALTERNATOR (50A) (EC SPEC.) (INNER PARTS)
ALTERNATOR (75A) (EC SPEC.) (INNER PARTS)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (7.5KW) (INJURY FROM SALT TERRAIN SPEC.)
STARTING MOTOR (7
HEATER WIRING
SAFETY GUARD (EC SPEC.)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH)
NAME PLATE AND CAUTION PLATE (GERMAN)
NAME PLATE AND CAUTION PLATE (INDONESIAN)
NAME PLATE AND CAUTION PLATE (POLISH)
NAME PLATE AND CAUTION PLATE (PORTUGUESE)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (GREEK)
NAME PLATE AND CAUTION PLATE (SPANISH)
NAME PLATE AND CAUTION PLATE (ITALIAN)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (CZECH)
