Komatsu Engine SA6D140-1B-G 10001-UP Parts Catalog
Model: Komatsu SA6D140-1B-G Engine
Serial Number: 10001-UP
Number of Pages: 221 Pages
SA6D140-1B-G S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110A-11J) (INNER PARTS)
TURBOCHARGER (KTR110G-344A) (INNER PARTS)
TURBOCHARGER OIL PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
OIL FILLER AND SENSOR
OIL FILLER AND SENSOR (WITH VANDALISM PROTECTION)
CYLINDER BLOCK (2 2)
OIL FILLER AND SENSOR (WITH VANDLISM PROTECTION)
FRONT COVER
FRONT COVER ACCESSORY
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (WITHOUT OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.) (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.) (WITH OIL LEVEL SENSOR) (1)
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (WITHOUT OIL LEVEL SENSOR)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.) (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.) (WITHOUT OIL LEVEL SENSOR)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (NON HARDENING PULLEY)
CRANK PULLEY (WITH HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
FRONT POWER TAKE OFF
OIL PUMP
OIL ADAPTER
OIL FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER (COOLANT HEATER SPEC.) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING (EXHAUST GAS REGULATION)
FUEL INJECTION PUMP (PUMP) (1 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR (WITH WATER SEPARATOR)
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP
THERMOSTAT AND PIPING
AIR VENT
COOLING FAN
FAN PULLEY (NON HARDENING PULLEY)
FAN PULLEY (HARDENING PULLEY)
FAN DRIVE (NON HARDENING PULLEY)
FAN DRIVE (HARDENING PULLEY) (SANDY AND DUSTY SPEC.)
CORROSION RESISTOR AND PIPING
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (50A) (HARDENING PULLEY)
ALTERNATOR (60A) (INNRE PARTS)
ALTERNATOR (50A) (HARDENING PULLEY) (INNER PARTS)
HEATER WIRING
SAFETY GUARD
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
AIR COMPRESSOR PIPING
WATER PUMP GASKET KIT
CYLINDER BLOCK GASKET KIT
AIR COMPRESSOR GASKET KIT
CYLINDER HEAD GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH)
NAME PLATE AND CAUTION PLATE (GERMAN)
NAME PLATE AND CAUTION PLATE (SPANISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (INDONESIAN)
NAME PLATE AND CAUTION PLATE (ITALIAN)
NAME PLATE AND CAUTION PLATE (GREEK)
NAME PLATE AND CAUTION PLATE (PORTUGUESE)
NAME PLATE AND CAUTION PLATE (POLISH)
NAME PLATE AND CAUTION PLATE (CZECH)
FUEL FILTER (ORDERING TRANSFERDED PARTS)
STOP MOTOR (ORDERING TRANSFERDED PARTS)
SPARE PARTS (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (ENGLISH) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (FRANCH) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (GERMAN) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (SPANISH) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (ARABIC) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (CHINESE) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (INDONESIAN) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (PORTUGUESE) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (SPANISH-ENGLISH) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (RUSSIAN) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (ITALIAN) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (GREEK) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (POLISH) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (CZECHO) (ORDERING TRANSFERDED PARTS)
CAUTION PLATE (PERSIAN) (ORDERING TRANSFERDED PARTS)
SPARE PARTS (ORDERING TRANSFERDED PARTS) (1)
OIL FILTER (ORDERING TRANSFERDED PARTS)
WATER SEPARATOR (ORDERING TRANSFERDED PARTS)
TIMER (ORDERING TRANSFERDED PARTS)
