Komatsu Engine SA6D125E-3C-7L 310001-UP Parts Catalog
Model: Komatsu SA6D125E-3C-7L Engine
Serial Number: 310001-UP
Number of Pages: 141 Pages
SA6D125E-3C-7L S N 310001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER ACCESSORY (BREATHER)
AIR INTAKE MANIFOLD AND AFTER COOLER (LAND FILL SPEC.)
AFTER COOLER WATER PIPING (LAND FILL SPEC.)
HEATER SWITCH
AIR CLEANER (LAND FILL SPEC.)
EXHAUST MANIFOLD (LAND FILL SPEC.)
TURBOCHARGER MOUNTING AND LUBRICATOR (LAND FILL SPEC.)
TURBOCHARGER (INNER PARTS)
MUFFLER (LAND FILL SPEC.)
THERMOSTAT AND THERMOSTAT HOUSING
WATER TEMPERATURE SENSOR
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (OIL PRESSURE SWITCH AND BLIND COVER)
FRONT COVER
FRONT COVER ACCESSORY (POWER TAKE OFF COVER AND POINTER)
IDLER GEAR
CAMFOLLOWER COVER (WITH OIL FILLER)
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON AND CONNECTING ROD
CRANK PULLEY
ROCKER ARM AND HOUSING
CAMSHAFT AND CAMFOLLOWER
CAMSHAFT ACCESSORY (TACHOMETER DRIVE)
OIL PUMP
OIL FILTER AND PIPING
OIL COOLER
OIL COOLER MOUNTING BOLT
WATER DRAIN VALVE
FUEL SUPPLY PUMP AND COMMON RAIL
FUEL SUPPLY PUMP AND COMMON RAIL (LOW VISCOSITY FUEL SPEC.)
FUEL SUPPLY AND RETURN PIPING
FUEL SUPPLY AND RETURN PIPING (LOW VISCOSITY FUEL SPEC.)
FUEL SUPPLY PUMP (1 2) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (2 2) (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND LUBRICATING OIL PIPING
FUEL INJECTION PIPING
FUEL SUPPLY PUMP DRIVE
FUEL FILTER AND PIPING (THREAD 1-1 4)
FUEL FILTER AND PIPING (THREAD 1-5 8)
FUEL FILTER CARTRIDGE (THREAD 1-5 8) (SERVICE ONLY)
FUEL FILTER CARTRIDGE (THREAD 1-1 4) (SERVICE ONLY)
FUEL INJECTOR AND FUEL RETURN PIPING
FUEL RETURN PIPING
FUEL PRE-FILTER AND PIPING (THREAD 1-1 4) (BAD FUEL SPEC.)
FUEL CONTROLLER (CHASSIS MOUNT) (FOR REGULATION OF EPA 2ND AND EU 2ND)
FUEL CONTROLLER (CHASSIS MOUNT) (HIGH ALTITUDE SPEC.)
WATER PUMP
AIR VENT PIPING
HANGER ENGINE (FRONT SIDE)
CORROSION RESISTOR
WATER LINE BLIND PLUG (FOR WITHOUT CORROSION RESISTOR)
ALTERNATOR AND MOUNTING (50A) (HARDENING PULLEY)
ALTERNATOR AND MOUNTING (75A) (HARDENING PULLEY)
ALTERNATOR (50A) (HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (75A) (HARDENING PULLEY) (INNER PARTS)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (7.5KW) (TRIMMING SPEC.)
STARTING MOTOR (7
STARTING MOTOR (7.5KW) (TRIMMING SPEC.) (INNER PARTS)
STARTING MOTOR (7 (1)
WIRING (1 2) MAIN HARNESS
WIRING (2 2) REAR SIDE HARNESS
SAFETY GUARD (1 2) (FOR EXHAUST MANIFOLD) (LAND FILL SPEC.)
SAFETY GUARD (2 2) (FOR TURBOCHARGER) (LAND FILL SPEC.)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA AND EU)
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA 2ND)
AIR CLEANER CAP
CAUTION PLATE (ENGLISH)
SPARE PARTS
FUEL CONTROLLER (CHASSIS MOUNT) (HIGH ALTITUDE SPEC.) (1)
CAUTION PLATE (ENGLISH) (1)
CAUTION PLATE (GERMAN)
CAUTION PLATE (FRENCH)
CAUTION PLATE (SPANISH)
CAUTION PLATE (CHINESE)
CAUTION PLATE (INDONESIAN)
CAUTION PLATE (ITALIAN)
CAUTION PLATE (PERSIAN)
ENGINE
CYLINDER HEAD
HEAD COVER
HEATER SWITCH
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
CRANK PULLEY
OIL PUMP
OIL COOLER
WATER DRAIN VALVE
FUEL RETURN PIPING
WATER PUMP
AIR VENT PIPING
CORROSION RESISTOR
STARTING MOTOR (7
AIR CLEANER CAP
SPARE PARTS
- KOMATSU Fault Codes
