Komatsu Engine SA6D102E-2 30379212-UP Parts Catalog
Model: Komatsu SA6D102E-2 Engine
Serial Number: 30379212-UP
Number of Pages: 63 Pages
ENGINE
CYLINDER HEAD
CYLINDER HEAD GASKET
WATER TEMPERATURE SENSOR
REAR HANGER
HEAD COVER
BREATHER AND HOSE
AIR INTAKE HEATHER
AFTER COOLER WATER PIPING
EXHAUST CONNECTOR CLAMP
EXHAUST MANIFOLD GASKET AND BOLT
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
EXHAUST MANIFOLD AND AFTER COOLER
TURBOCHARGER OIL PIPING
THERMOSTAT HOUSING
THERMOSTAT
CYLINDER BLOCK
OIL PRESSURE SWITCH
FRONT COVER
DUST SEAL
CAMFOLLOWER
CYLINDER BLOCK BLIND PLUG
OIL PAN MOUNTING
OIL PAN MOUNTING (1)
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
CAMSHAFT
ROCKER ARM
TAPPET
FRONT GEAR TRAIN DRIVE SHAFT
ACCESSORY PULEY
TACHOMETER DRIVE COVER
OIL PUMP
OIL COOLER AND OIL FILTER
FUEL INJECTION PUMP
BOOST TUBE
FUEL INJECTION PUMP MOUNTING
FUEL FILTER
FUEL FILTER PIPING
FUEL INJECTION PIPING
CYLINDER BLOCK BLIND COVER AND FUEL FEED PUMP
INJECTION NOZZLE
FUEL JOINT
SOLENOID
WATER PUMP
WATER CONNECTOR
FAN DRIVE PULLEY
FAN SPACER
ALTERNATOR (60A)
BELT TENSIONER
ALTERNATOR MOUNTING
STARTING MOTOR MOUNTING (5
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
