Komatsu Engine SA12V140-1U-A 10001-UP Parts Catalog
Model: Komatsu SA12V140-1U-A Engine
Serial Number: 10001-UP
Number of Pages: 399 Pages
SA12V140-1U-A S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
AFTER COOLER WATER PIPING
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (VHMS SPEC.)
TURBOCHARGER MOUNTING (WATER COOL SPEC.)
TURBOCHARGER MOUNTING (HIGH ALTITUDE SPEC.)
TURBOCHARGER (KTR110G-F45C) (INNER PARTS)
TURBOCHARGER (HIGH ALTITUDE SPEC.) (KTR110L-EH4CW) (INNER PARTS)
TURBOCHARGER (HIGH ALTITUDE SPEC.) (KTR110L-585CW) (INNER PARTS)
TURBOCHARGER OIL PIPING (WATER COOL SPEC.)
TURBOCHARGER OIL PIPING (HIGH ALTITUDE SPEC.)
TURBOCHARGER COOLING (WATER INNLET LINE) (WATER COOL SPEC.)
TURBOCHARGER COOLING (WATER INNLET LINE) (HIGH ALTITUDE SPEC.)
TURBOCHARGER COOLING (WATER OUTLET LINE) (WATER COOL SPEC.)
TURBOCHARGER COOLING (WATER OUTLET LINE) (HIGH ALTITUDE SPEC.)
TURBOCHARGER COOLING (WATER OUTLET LINE) (WATER COOL SPEC.) (FOR HD785-5)
TURBOCHARGER COOLING (WATER INNLET LINE) (WATER COOL SPEC.) (FOR HD785-5)
TURBOCHARGER OIL PIPING (WATER COOL SPEC.) (FOR HD785-5)
TURBOCHARGER (KTR110G-F45C) (HD785-5) (INNER PARTS)
TURBOCHARGER MOUTING (WATER COOL SPEC.) (FOR HD785-5)
HEAT SHIELD (FOR WA800.900¤ D475A AND HD785
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE (INNER PARTS)
THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK (FOR ELECTRICAL GOVERNOR)
CYLINDER BLOCK COVER
CYLINDER BLOCK COVER (FOR ELECTRICAL GOVERNOR)
CYLINDER BLOCK BLIND COVER (WATER COOL SPEC.)
CYLINDER BLOCK RELATED PARTS (WITH TACHOMETER DRIVE)
CYLINDER BLOCK RELATED PARTS (FOR ELECTRICAL GOVERNOR)
FRONT COVER
FRONT COVER (FOR ELECTRICAL GOVERNOR)
GEAR CASE
GEAR CASE (FOR ELECTRICAL GOVERNOR)
BREATHER
BREATHER (FOR ELECTRICAL GOVERNOR)
GEAR CASE (FOR MECHANICAL GOVERNOR)
GEAR CASE (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.)
BREATHER AND FRONT SEAL (FOR MECHANICAL GOVERNOR)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (R.H. BANK)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (L.H. BANK)
BLOWBY SENSOR (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (R.H. BANK)
IDLER GEAR
CAM FOLLOWER COVER
CAM FOLLOWER COVER (FOR ELECTRICAL GOVERNOR)
OIL FILLER
OIL FILLER (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.) (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (FOR QUICK COUPLER)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.) (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (FOR QUICK COUPLER)
FLYWHEEL HOUSING
FLYWHEEL HOUSING (FOR MECHANICAL GOVERNOR)
FLYWHEEL
ENGINE SUPPORT AND BRACKET
ENGINE SUPPORT AND BRACKET (KP-1A)
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
CRANK PULLEY (TOROPICAL SPEC.)
ROCKER ARM AND HOUSING (FOR ELECTRICAL GOVERNOR)
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER (FOR ELECTRICAL GOVERNOR)
CAM FOLLOWER
CAM FOLLOWER (FOR MECHANICAL GOVERNOR)
ROCKER ARM AND HOUSING (FOR MECHANICAL GOVERNOR)
TACHOMETER DRIVE
OIL PUMP
OIL FILTER (WITH ALARM)
OIL FILTER
OIL FILTER (VHMS SPEC.)
OIL FILTER (WITH ALARM) (VHMS SPEC.)
OIL ADAPTER (WITH ALARM)
OIL ADAPTER
OIL ADAPTER (VHMS SPEC.)
OIL ADAPTER (WITH ALARM) (VHMS SPEC.)
OIL PRESSURE SENSOR (WITH ALARM)
OIL PRESSURE SENSOR
OIL PRESSURE SENSOR (VHMS SPEC.)
OIL PRESSURE SENSOR (WITH ALARM) (VHMS SPEC.)
BYPASS FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER MOUNTING
OIL COOLER MOUNTING (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (FOR MECHANICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION ) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (TIMER) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (TIMER) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP LINKAGE (FOR MECHANICAL GOVERNOR)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP BRACKET (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (L.H. BANK)
FUEL INJECTION PUMP PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (R.H. BANK)
FUEL INJECTION PUMP PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP DRIVE
FUEL FILTER (FOR MECHANICAL GOVERNOR)
FUEL FILTER (FOR ELECTRICAL GOVERNOR)
FUEL PIPING (FOR MECHANICAL GOVERNOR)
FUEL PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
LIFT PUMP (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL INJECTION NOZZLE (FOR PAMA)
NOZZLE HOLDER (INNER PARTS)
NOZZLE HOLDER (FOR PAMA) (INNER PARTS)
FUEL RETURN (L.H. BANK)
FUEL RETURN (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL RETURN (R.H. BANK)
FUEL RETURN (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
STOP MOTOR AND LINKAGE (FOR MECHANICAL GOVERNOR)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS) (FOR TOMISHIMAKENSETU)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS) (FOR PAMA) (HIGH ALTITUDE SPEC.)
WATER PUMP
WATER PUMP (WITHOUT CORROSION RESISTOR)
COOLING SYSTEM PIPING
COOLING SYSTEM PIPING (WITHOUT CORROSION RESISTOR)
AIR VENT
AIR VENT (WITHOUT CORRO.RSTR.)
COOLING FAN
COOLING FAN (TROPICAL SPEC.)
FAN PULLEY
FAN DRIVE
FAN DRIVE (TROPICAL SPEC.)
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (FOR 90A ALTERNATOR)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
STARTING MOTOR (7 (3)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR)
ELECTRICAL WIRING (FOR MECHANICAL GOVERNOR)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR) (HARNESS HEAVY DUTY TYPE)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION)
SAFETY GUARD (INJECTION PUMP DRIVE) (FOR ELECTRICAL GOVERNOR)
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
TOOL
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (GERMAN)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (INDONESIAN)
NAME PLATE AND CAUTION (CHINESE)
NAME PLATE AND CAUTION (FRENCH)
PM-CLINIC
PM-CLINIC (WITH MAINTENANCE MONITOR)
FUEL FILTER
LIFT PUMP
STOP MOTOR AND LINKAGE (FOR MECHANICAL GOVERNOR) (1)
BYPASS FILTER (1)
NAME PLATE AND CAUTION (ENGLISH) (1)
AMPLIFIER (VHMS SPEC.)
FUEL CONTROLLER (HIGH ALTITUDE SPEC.)
