Komatsu Engine SA12V140-1U-98 11640-UP Parts Catalog
Model: Komatsu SA12V140-1U-98 Engine
Serial Number: 11640-UP
Number of Pages: 266 Pages
KOMATSU SA12V140-1U-98 S N 11640-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (1 2) (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
AIR INTAKE MANIFOLD AND AFTER COOLER (1 2) (L.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
AIR INTAKE MANIFOLD AND AFTER COOLER (2 2) (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
AIR INTAKE MANIFOLD AND AFTER COOLER (2 2) (R.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
WATER PIPING (FOR ELECTRICAL GOVERNOR)
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (VHMS SPEC.)
TURBOCHARGER MOUNTING (FOR HD985-5)
TURBOCHARGER (KTR110G-F45C) (FOR HD985-5) (INNER PARTS)
TURBOCHARGER OIL PIPING (FOR HD985-5)
TURBOCHARGER COOLING (WATER INNLET LINE) (FOR HD985-5)
TURBOCHARGER COOLING (WATER OUTLET LINE) (FOR HD985-5)
HEAT SHIELD (FOR WA800¤900-2 AND HD785¤985-3)
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE (INNER PARTS)
THERMOSTAT AND MOUNTING (WITHOUT AIR COMPPRESSOR)
CYLINDER BLOCK (FOR ELECTRICAL GOVERNOR)
CYLINDER BLOCK
CYLINDER BLOCK COVER (FOR ELECTRICAL GOVERNOR)
CYLINDER BLOCK RELATED PARTS (FOR ELECTRICAL GOVERNOR)
FRONT COVER (FOR ELECTRICAL GOVERNOR)
FRONT COVER
GEAR CASE (FOR ELECTRICAL GOVERNOR)
BREATHER (FOR ELECTRICAL GOVERNOR)
GEAR CASE RELATED PARTS (FOR ELECTRICAL GOVERNOR)
GEAR CASE RELATED PARTS (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (R.H. BANK)
BREATHER AND FRONT SEAL (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (L.H. BANK)
BLOWBY SENSOR (FOR ELECTRICAL GOVERNOR) (VHMS SPEC.) (R.H. BANK)
IDLER GEAR
CAMFOLLOWER COVER (FOR ELECTRICAL GOVERNOR)
OIL FILLER
OIL FILLER (WITH OIL LEVEL SENSOR)
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.) (FOR HD985-5)
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.) (FOR HD985-5)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR)
FLYWHEEL HOUSING (FOR ELECTRICAL GOVERNOR)
FLYWHEEL
ENGINE SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM AND HOUSING (FOR ELECTRICAL GOVERNOR)
CAMSHAFT AND GEAR
CAMSHAFT AND CAMFOLLOWER (FOR ELECTRICAL GOVERNOR)
CAMFOLLOWER
CAMFOLLOWER AND TACHOMETER DRIVE SHAFT
OIL PUMP
OIL FILTER (WITH ALARM) (FOR HD985-5)
OIL FILTER
OIL FILTER (WITH OIL PRESSURE SWITCH AND ALARM)
OIL FILTER (VHMS SPEC.)
OIL FILTER (WITH OIL PRESSURE SWITCH AND ALARM) (VHMS SPEC.)
OIL ADAPTER (WITH ALARM)
OIL ADAPTER
OIL ADAPTER (WITH OIL PRESSURE SWITCH AND ALARM)
OIL ADAPTER (VHMS SPEC.)
OIL ADAPTER (WITH OIL PRESSURE SWITCH AND ALARM) (VHMS SPEC.)
OIL PRESSURE SENSOR (WITH ALARM)
OIL PRESSURE SENSOR
OIL PRESSURE SENSOR (WITH OIL PRESSURE SWITCH AND ALARM)
OIL PRESSURE SENSOR (VHMS SPEC.)
OIL PRESSURE SENSOR (WITH OIL PRESSURE SWITCH AND ALARM) (VHMS SPEC.)
OIL PRESSURE SWITCH
OIL PRESSURE SWITCH (VHMS SPEC.)
BYPASS FILTER (FOR HD785-5 AND HD985-5)
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER MOUNTING
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2)(FOR ELECTRICAL GOVERNOR)(EC REGULATION)(INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2)(FOR ELECTRICAL GOVERNOR)(FOR EC REGULATION)(INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION ) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2)(FOR ELECTRICAL GOVERNOR)(FOR EC REGULATION)(INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2)(FOR ELECTRICAL GOVERNOR)(FOR EC REGULATION)(INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
COUPLING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS)
FUEL INJECTION PUMP BRACKET (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (1 2) (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (2 2) (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (1 2) (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (2 2) (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP DRIVE (FOR HD785-5 AND HD985-5)
FUEL FILTER (FOR ELECTRICAL GOVERNOR)
FUEL PIPING (1 2) (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL PIPING (2 2) (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
LIFT PUMP (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION NOZZLE AND SPILL PIPE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL RETURN (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS) (FOR HD985)
WATER PUMP
COOLING SYSTEM PIPING
AIR VENT
COOLING FAN
FAN PULLEY
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR DRIVE (FOR 50A AND 75A)
ALTERNATOR DRIVE (FOR 90A ALTERNATOR)
ALTERNATOR DRIVE (FOR 90A)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR) (HARNESS HEAVY DUTY TYPE)
ELECTRICAL WIRING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION)
SAFETY GUARD (INJECTION PUMP DRIVE) (FOR ELECTRICAL GOVERNOR)
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
TOOL
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
PM-CLINIC
FUEL FILTER
LIFT PUMP
BYPASS FILTER (FOR HD785-5 AND HD985-5) (1)
AMPLIFIER (VHMS SPEC.)
FUEL CONTROLLER (FOR HD785¤HD985-5) (HIGH ALTITUDE SPEC.)
ENGINE
CYLINDER HEAD
HEAD COVER
SHIELD PLATE
EXHAUST MANIFOLD
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
OIL FILLER
OIL LEVEL GAUGE
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
CAMSHAFT AND GEAR
CAMFOLLOWER
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL PRESSURE SENSOR
OIL PRESSURE SWITCH
OIL COOLER
OIL COOLER MOUNTING
WATER PUMP
AIR VENT
COOLING FAN
FAN PULLEY
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
STARTING MOTOR (7
TOOL
PM-CLINIC
FUEL FILTER
LIFT PUMP
- KOMATSU Fault Codes
