Komatsu Engine SA12V140-1S-A 10001-UP Parts Catalog
Model: Komatsu SA12V140-1S-A Engine
Number of Pages: 328 Pages
SA12V140-1S-A S N 10001-UP
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (COLD TERRAIN SPEC.) (FOR ELECTRICAL GOVERNOR)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (COLD TERRAIN SPEC.) (FOR ELECTRICAL GOVERNOR)
AFTER COOLER WATER PIPING
AFTER COOLER WATER PIPING (FOR ELECTRICAL GOVERNOR)
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.) (FOR ELECTRICAL GOVERNOR)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR) (VHMS SPEC.)
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER (KTR110G-F45A) (INNER PARTS)
TURBOCHARGER BLIND COVER
HEAT SHIELD (FOR WA800.900¤ D475A AND HD785
MUFFLER (1)
MUFFLER PIPING
THERMOSTAT HOUSING (WITH AIR COMPPRESSOR)
CYLINDER BLOCK RELATED PARTS
GEAR CASE
BREATHER
GEAR CASE (WITHOUT AIR COMPRESSOR)
GEAR CASE (VHMS SPEC.)
BREATHER AND FRONT SEAL
BREATHER AND FRONT SEAL (WITHOUT AIR COMPRESSOR)
BREATHER AND FRONT SEAL (VHMS SPEC.)
BLOWBY SENSOR (VHMS SPEC.)
CAM FOLLOWER COVER
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING (FOR MECHANICAL GOVERNOR)
ENGINE SUPPORT AND BRACKET
CRANK PULLEY (PULLEY DIAMETER 182MM)
CAMSHAFT AND CAMFOLLOWER
CAM FOLLOWER
OIL FILTER (COLD TERRAIN SPEC.)
OIL FILTER (VHMS SPEC.)
OIL ADAPTER
OIL ADAPTER (COLD TERRAIN SPEC.)
OIL ADAPTER (VHMS SPEC.)
OIL PRESSURE SENSOR (VHMS SPEC.)
BYPASS OIL PIPING
BYPASS FILTER (CHASSIS MOUNT)
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER MOUNTING
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (TODAKA)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (TODAKA) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (TODAKA) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (TODAKA) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (TODAKA) (INNER PARTS)
FUEL INJECTION PUMP LINKAGE
FUEL INJECTION PUMP LINKAGE (TODAKA)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP BRACKET (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP DRIVE (WITH AIR COMPRESSOR) (FOR ELECTRICAL GOVERNOR)
FUEL FILTER AND PIPING (L.H. BANK)
FUEL FILTER AND PIPING (FOR ELECTRICAL GOVERNOR)
FUEL FILTER AND PIPING (R.H. BANK)
FUEL PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN (L.H. BANK)
FUEL RETURN (L.H. BANK) (FOR ELECTRICAL GOVERNOR)
FUEL RETURN (R.H. BANK)
FUEL RETURN (R.H. BANK) (FOR ELECTRICAL GOVERNOR)
STOP MOTOR AND LINKAGE (FOR MECHANICAL GOVERNOR)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS)
WATER PUMP (WITHOUT CORROSION RESISTOR)
AIR VENT
AIR VENT (WITHOUT CORROSION RESISTOR)
COOLING FAN (TODAKA)
FAN PULLEY
FAN PULLEY (-40 DEC.)
FRONT HANGER (WITHOUT FAN DRIVE)
TENSION PULLEY
TENSION PULLEY (-40 DEC.)
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (90A) (-40 DEC.)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (INNER PARTS) (-40 DEC.)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (FOR 90A ALTERNATOR)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7 (2)
ELECTRICAL WIRING
SAFETY GUARD (INJECTION PUMP DRIVE)
SAFETY GUARD (INJECTION PUMP DRIVE) (FOR ELECTRICAL GOVERNOR)
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
AIR COMPRESSOR GASKET KIT
WATER PUMP GASKET KIT
BYPASS FILTER
BYPASS FILTER BRACKET
FUEL CONTROLLER
ALTERNATOR RELATED PARTS
