Komatsu Engine SA12V140-1Q 10034-UP Parts Catalog
Model: Komatsu SA12V140-1Q Engine
Serial Number: 10034-UP
Number of Pages: 151 Pages
KOMATSU SA12V140-1Q S N 10034-UP
AIR INTAKE MANIFOLD AND AFTER COOLER (1 2) (L.H. BANK) (ELECTRICAL GOVERNOR SPEC.)
AIR INTAKE MANIFOLD AND AFTER COOLER (2 2) (R.H. BANK) (ELECTRICAL GOVERNOR SPEC.)
EXHAUST MANIFOLD AND TURBOCHARGER (1 2) (L.H. BANK)
EXHAUST MANIFOLD AND TURBOCHARGER (2 2) (R.H. BANK)
EXHAUST BRAKE AND MOUNTING (ELECTRICAL GOVERNOR SPEC.)
EXHAUST BRAKE (INNER PARTS)
WATER PIPING
TURBOCHARGER COOLING PIPING (1 2) (WATER INLET LINE)
TURBOCHARGER COOLING PIPING (2 2) (WATER OUTLET LINE)
CYLINDER BLOCK COVER (ELECTRICAL GOVERNOR SPEC.)
FRONT COVER (ELECTRICAL GOVERNOR SPEC.)
GEAR CASE AND GEAR (ELECTRICAL GOVERNOR SPEC.)
OIL PAN (ELECTRICAL GOVERNOR SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING (ELECTRICAL GOVERNOR SPEC.)
CRANKSHAFT (ELECTRICAL GOVERNOR SPEC.)
CAMSHAFT (ELECTRICAL GOVERNOR SPEC.)
LUBRICATING OIL FILTER AND PIPING
BYPASS FILTER AND PIPING
LUBRICATING OIL ADAPTER
FUEL INJECTION PUMP AND PIPING (1 2) (L.H. BANK) (ELECTRICAL GOVERNOR SPEC.)
FUEL INJECTION PUMP AND PIPING (2 2) (R.H. BANK) (ELECTRICAL GOVERNOR SPEC.)
FUEL INJECTION PUMP DRIVE (ELECTRICAL GOBERNOR SPEC.)
FUEL PIPING (1 2) (L.H. BANK)
FUEL PIPING (2 2) (R.H. BANK)
FUEL INJECTION PUMP (PUMP L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP R.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP R.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP L.H.) (1 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP L.H.) (2 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP R.H.) (1 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP R.H.) (2 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
COUPLING (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
LIFT PUMP (ELECTRICAL GOVERNOR SPEC.) (INNER PARTS)
WATER PUMP AND MOUNTING
COOLING SYSTEM PIPING
THERMOSTAT AND MOUNTING
COOLING FAN AND MOUNTING
TENSION PULLEY AND MOUNTING
CORROSION RESISTER AND MOUNTING
ALTERNATOR AND MOUNTING (75A)
ALTERNATOR DRIVE (ELECTRICAL GOVERNOR SPEC.)
STARTING MOTOR AND MOUNTING (7
ELECTRICAL WIRING
ACCESSORY
AIR COMPRESSOR AND MOUNTING (ELECTRICAL GOVERNOR SPEC.)
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
TOOL AND KIT
