Komatsu Engine SA12V140-1E-A 10001-UP Parts Catalog
Model: Komatsu SA12V140-1E-A Engine
Serial Number: 10001-UP
Number of Pages: 330 Pages
SA12V140-1E-A S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK)
AFTER COOLER WATER PIPING
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (WITH COOLANT HEATER)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (WITH COOLANT HEATER)
AFTER COOLER WATER PIPING (WITH COOLANT HEATER)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
AIR CLEANER MOUNTING
AIR CLEANER AND PRE CLEANER
AIR CLEANER (INNER PARTS)
EXHAUST MANIFOLD
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER (KTR110A-B21A) (INNER PARTS)
TURBOCHARGER AND LUBRICATING OIL PIPING (FOR REGULATION OF EC)
TURBOCHARGER (KTR110G-F45A) (INNER PARTS)
TURBOCHARGER (KTR110G-444S) (INNER PARTS)
TURBOCHARGER (FOR REGULATION OF EC) (KTR110G-444A AND F45A) (INNER PARTS)
TURBOCHARGER (FOR REGULATION OF EC) (KTR110G-F45A) (INNER PARTS)
TURBOCHARGER (KTR110G-444A AND F45A) (INNER PARTS)
TURBOCHARGER BLIND COVER
TURBOCHARGER SHIELD COVER (FOR REGULATION OF EC)
HEAT SHIELD (FOR WA800.900¤ D475A AND HD785
MUFFLER
MUFFLER (FOR REGULATION OF EC)
EJECTOR VALVE AND EXHAUST PIPE
EJECTOR VALVE AND EXHAUST PIPE (FOR REGULATION OF EC)
THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK BLIND COVER
FRONT COVER
GEAR CASE
BREATHER
BREATHER AND FRONT SEAL
IDLER GEAR
CAM FOLLOWER COVER
OIL FILLER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (ADAPTER TYPE)
ROCKER ARM AND HOUSING
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAM FOLLOWER (FOR MECHANICAL GOVERNOR)
ROCKER ARM AND HOUSING (FOR MECHANICAL GOVERNOR)
TACHOMETER DRIVE
OIL PUMP
OIL FILTER
OIL ADAPTER
BYPASS FILTER
BYPASS FILTER PIPING
OIL COOLER
OIL COOLER (WITH BLOCK HEATER)
OIL COOLER MOUNTING
OIL COOLER MOUNTING (WITH BLOCK HEATER)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP MOUNTING (WITH STOP LEVER)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (WITH STOP LEVER) (INNER PARTS)
FUEL INJECTION PUMP LINKAGE
FUEL INJECTION PUMP LINKAGE (WITH STOP LEVER)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP PIPING (L.H. BANK)
FUEL INJECTION PUMP PIPING (R.H. BANK)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK)
FUEL INJECTION PUMP DRIVE
FUEL FILTER
FUEL PIPING
WATER SEPARATOR
FUEL INJECTION NOZZLE AND SPILL PIPE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN (L.H. BANK)
FUEL RETURN (R.H. BANK)
STOP DEVICE
AIR VENT
WATER PUMP
COOLING FAN
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (FOR 50A AND 75A ALTERNATOR)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (7 (1)
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR MOUNTING (7 (2)
STARTING MOTOR (7 (2)
STARTING MOTOR (7 (3)
STARTING MOTOR (7 (4)
STARTING MOTOR (7 (5)
SAFETY GUARD (INJECTION PUMP DRIVE)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (CHINESE)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (INDONESIAN)
NAME PLATE AND CAUTION (ARABIC)
NAME PLATE AND CAUTION (PORTUGUESE)
NAME PLATE AND CAUTION (GERMAN)
NAME PLATE AND CAUTION (FRENCH)
PM-CLINIC
PRE CLEANER
INSTRUCTION PLATE (AIR CLEANER)
EJECTOR VALVE AND EXHAUST PIPE (FOR EC REGULATION)
