Komatsu Engine SA12V140-1D-A 10001-UP Parts Catalog
Model: Komatsu SA12V140-1D-A Engine
Serial Number: 10001-UP
Number of Pages: 320 Pages
SA12V140-1D-A S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK)
AFTER COOLER WATER PIPING
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
EXHAUST MANIFOLD
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER AND LUBRICATING OIL PIPING (WATER COOL SPEC.)
TURBOCHARGER (KTR110A-32F) (INNER PARTS)
TURBOCHARGER BLIND COVER AND CLAMP
TURBOCHARGER MOUTING
TURBOCHARGER MOUNTING (WATER COOL SPEC.)
TURBOCHARGER (KTR110G-F45C) (KTR110G-344C) (INNER PARTS)
TURBOCHARGER (KTR110G-F45C) (INNER PARTS)
TURBOCHARGER (KTR110G-F45C) (KTR110G-344C) (INNER PARTS) (1)
TURBOCHARGER WATER PIPING (1 2) (WATER COOL SPEC.)
TURBOCHARGER OIL PIPING (WATER COOL SPEC.)
TURBOCHARGER WATER PIPING (2 2) (WATER COOL SPEC.)
TURBOCHARGER COOLING (WATER INNLET LINE) (WATER COOL SPEC.)
TURBOCHARGER COOLING (WATER OUTLET LINE) (WATER COOL SPEC.)
HEAT SHIELD (FOR WA800.900¤ D475A AND HD785
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE (INNER PARTS)
THERMOSTAT HOUSING
CYLINDER BLOCK (WATER COOL TURBO SPEC.) (EXCEPT JAPAN)
CYLINDER BLOCK (FOR MECHANICAL GOVERNOR)
CYLINDER BLOCK
CYLINDER BLOCK BLIND COVER
CYLINDER BLOCK BLIND COVER (WATER COOL SPEC.) (FOR MECHANICAL GOVERNOR)
FRONT COVER
GEAR CASE
BREATHER
GEAR CASE (FOR MECHANICAL GOVERNOR)
BREATHER AND FRONT SEAL (FOR MECHANICAL GOVERNOR)
IDLER GEAR
CAM FOLLOWER COVER
OIL FILLER (WITHOUT OIL LEVEL SENSOR) (FOR MECHANICAL GOVERNOR)
OIL PAN AND SUCTION TUBE (WITHOUT OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR)
OIL LEVEL GAUGE (WITHOUT OIL LEVEL SENSOR) (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR)
FLYWHEEL HOUSING (FOR MECHANICAL GOVERNOR)
FLYWHEEL
ENGINE SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
CRANK PULLEY (TOROPICAL SPEC.)
ROCKER ARM AND HOUSING
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAM FOLLOWER (FOR MECHANICAL GOVERNOR)
ROCKER ARM AND HOUSING (FOR MECHANICAL GOVERNOR)
TACHOMETER DRIVE
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL FILTER (WITH ALARM)
OIL ADAPTER (WITH ALARM)
BYPASS FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER MOUNTING
OIL COOLER MOUNTING (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING (FOR MECHANICAL GOVERNOR)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (TIMER) (L.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (TIMER) (R.H.) (FOR MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP LINKAGE (FOR MECHANICAL GOVERNOR)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP PIPING (L.H. BANK)
FUEL INJECTION PUMP PIPING (R.H. BANK)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK)
FUEL INJECTION PUMP DRIVE
FUEL FILTER (FOR MECHANICAL GOVERNOR)
FUEL PIPING (FOR MECHANICAL GOVERNOR)
FUEL INJECTION NOZZLE AND SPILL PIPE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN (L.H. BANK)
FUEL RETURN (R.H. BANK)
STOP MOTOR AND LINKAGE
AIR VENT (FOR MECHANICAL GOVERNOR)
WATER PUMP (FOR MECHANICAL GOVERNOR)
WATER PUMP
COOLING SYSTEM PIPING (FOR MECHANICAL GOVERNOR)
AIR VENT
COOLING FAN
COOLING FAN (TROPICAL SPEC.)
FAN PULLEY
FAN DRIVE
FAN DRIVE (TROPICAL SPEC.)
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (FOR 90A ALTERNATOR)
ALTERNATOR DRIVE (FOR 90A ALTERNATOR ELECTRIC GOVERNOR)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
STARTING MOTOR (7 (3)
ELECTRICAL WIRING (FOR MECHANICAL GOVERNOR)
SAFETY GUARD (INJECTION PUMP DRIVE)
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
CYLINDER HEAD GASKET KIT (FOR MECHANICAL GOVERNOR)
CYLINDER BLOCK GASKET KIT (FOR MECHANICAL GOVERNOR)
WATER PUMP GASKET KIT (FOR MECHANICAL GOVERNOR)
AIR COMPRESSOR GASKET KIT (FOR MECHANICAL GOVERNOR)
TOOL
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (GERMAN)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (INDONESIAN)
NAME PLATE AND CAUTION (CHINESE)
NAME PLATE AND CAUTION (FRENCH)
PM-CLINIC
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS) (EXCEPT JAPAN)
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS) (FOR PAMA) (HIGH ALTITUDE SPEC.)
