Komatsu Engine SA12V140-1A-A 10001-UP Parts Catalog
Model: Komatsu SA12V140-1A-A Engine
Serial Number: 10001-UP
Number of Pages: 342 Pages
SA12V140-1A-A S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER AND SHIELD PLATE
SHIELD PLATE
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK)
AFTER COOLER WATER PIPING
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (COLD TERRAIN SPEC.)
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (COLD TERRAIN SPEC.)
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.)
HEATER SWITCH (L.H. BANK)
HEATER SWITCH (R.H. BANK)
EXHAUST MANIFOLD
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER AND LUBRICATING OIL PIPING (WATER COOL SPEC.)
TURBOCHARGER (KTR110G-444S) (INNER PARTS)
TURBOCHARGER (KTR110G-F45A) (INNER PARTS)
TURBOCHARGER (WATER COOL SPEC.) (KTR110G-F45C) (INNER PARTS)
TURBOCHARGER (WATER COOL SPEC.) (KTR110G-F45A) (INNER PARTS)
TURBOCHARGER BLIND COVER
TURBOCHARGER WATER PIPING (WATER COOL SPEC.)
TURBOCHARGER BLIND COVER (WATER COOL SPEC.)
HEAT SHIELD (FOR WA800.900¤ D475A AND HD785
MUFFLER
MUFFLER (WATER COOL SPEC.)
MUFFLER PIPING
MUFFLER PIPING (WATER COOL SPEC.)
THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK (WATER COOL SPEC.)
CYLINDER BLOCK RELATED PARTS
CYLINDER BLOCK RELATED PARTS (WATER COOL SPEC.)
FRONT COVER
GEAR CASE
BREATHER
BREATHER AND FRONT SEAL
IDLER GEAR
CAM FOLLOWER COVER
OIL FILLER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
ROCKER ARM AND HOUSING
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAM FOLLOWER
OIL PUMP
OIL FILTER
OIL ADAPTER
BYPASS OIL PIPING
BYPASS OIL FILTER (CHASSIS MOUNT)
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
OIL COOLER MOUNTING
OIL COOLER MOUNTING (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP MOUNTING (LARGE BUCKET SPEC.)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (L.H.) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (L.H.) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (R.H.) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (R.H.) (LARGE BUCKET SPEC.) (INNER PARTS)
FUEL INJECTION PUMP LINKAGE
FUEL INJECTION PUMP LINKAGE (LARGE BUCKET SPEC.)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP PIPING (L.H. BANK)
FUEL INJECTION PUMP PIPING (R.H. BANK)
FUEL INJECTION PUMP LUBRICATING (L.H. BANK)
FUEL INJECTION PUMP LUBRICATING (R.H. BANK)
FUEL INJECTION PUMP DRIVE (WITH AIR COMPRESSOR) (FOR ELECTRICAL GOVERNOR)
FUEL FILTER AND PIPING (L.H. BANK)
FUEL FILTER AND PIPING (R.H. BANK)
FUEL INJECTION NOZZLE AND SPILL PIPE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN (L.H. BANK)
FUEL RETURN (R.H. BANK)
STOP MOTOR AND LINKAGE (FOR MECHANICAL GOVERNOR)
AIR VENT
WATER PUMP
COOLING FAN
FAN PULLEY
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (FOR 90A ALTERNATOR)
ALTERNATOR DRIVE (FOR 50A AND 75A ALTERNATOR)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR MOUNTING (7 (1)
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
STARTING MOTOR (7 (3)
SAFETY GUARD (INJECTION PUMP DRIVE)
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (FRONT) (INNER PARTS)
AIR COMPRESSOR (REAR) (INNER PARTS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (RUSSIAN)
NAME PLATE AND CAUTION (INDONESIAN)
NAME PLATE AND CAUTION (GERMAN)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (CHINESE)
NAME PLATE AND CAUTION (ARABIC)
PM-CLINIC
