Komatsu Engine S6D170-1G-6W 10001-UP Parts Catalog
Model: Komatsu S6D170-1G-6W Engine
Serial Number: 10001-UP
Number of Pages: 150 Pages
S6D170-1G-6W S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
ROCKER ARM HOUSING COVER
HEAD COVER MOUNTING
AIR INTAKE MANIFOLD AND AIR CONNECTION
AIR CLEANER
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110-776B) (INNER PARTS)
MUFFLER MOUNTING
MUFFLER EJECTOR PIPING
WATER MANIFOLD
WATER MANIFOLD AND THERMOSTAT
WATER TEMPERATURE SWITCH AND WIRING
CYLINDER BLOCK (FOR FCD PISTON)
CYLINDER BLOCK (FCD PISTON SPEC.) (FOR EXTREME COLD TERRAIN)
CYLINDER BLOCK COVER AND OIL PRESSURE SWITCH
GEAR CASE AND FRONT COVER (MECHANICAL PUMP SPEC.)
FRONT COVER ACCESSORY
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
POWER TAKE OFF
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON (FOR FCD PISTON)
CRANK PULLEY (HARDENING PULLEY SPEC.)
ROCKER ARM AND HOUSING
ROCKER ARM
CAMSHAFT AND CAMFOLLOWER
ROCKER ARM HOUSING (FOR NO
ROCKER ARM HOUSING (FOR NO (1)
FRONT POWER TAKE OFF (AIR COMPRESSOR DRIVE) (SANDY AND DUSTY SPEC.)
OIL PUMP
LUBRICATING OIL FILTER
MECHANICAL PUMP
LUBRICATING OIL COOLER
OIL COOLER MOUNTING AND ACCESSORY
FUEL INJECTION PUMP
FUEL INJECTION PUMP BRACKET AND FUEL PIPING
FUEL INJECTION PUMP DRIVE
FUEL FILTER AND FUEL PIPING (FOR WD600-1)
FUEL INJECTION NOZZLE AND SPILL PIPE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
AUTO PRIMING SYSTEM (FOR WD600-1)
ENGINE STOP MOTOR
WATER PUMP
COOLING FAN
FAN DRIVE (EXCEPT JAPAN)
TENSION PULLEY
FAN BELT (EXCEPT JAPAN)
CORROSION RESISTOR
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (50A)
ALTERNATOR DRIVE
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR (INNER PARTS)
CYLINDER HEAD GASKET KIT
AIR COMPRESSOR GASKET KIT
WATER PUMP GASKET KIT
CYLINDER BLOCK GASKET KIT
SPARE PARTS (WITH PRE-FILTER)
SPARE PARTS (EXCEPT JAPAN)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (RUSSIAN)
OTHER PARTS
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER MOUNTING
AIR CLEANER
EXHAUST MANIFOLD
MUFFLER MOUNTING
WATER MANIFOLD
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
FLYWHEEL HOUSING
POWER TAKE OFF
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
ROCKER ARM
OIL PUMP
MECHANICAL PUMP
FUEL INJECTION PUMP
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP
COOLING FAN
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR DRIVE
STARTING MOTOR (7
OTHER PARTS
- KOMATSU Fault Codes
