Komatsu Engine S6D170-1G 10490-UP Parts Catalog
Model: Komatsu S6D170-1G Engine
Serial Number: 10490-UP
Number of Pages: 132 Pages
S6D170-1G S N 10490-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR CLEANER AND MOUNTING
EXHAUST MANIFOLD AND TURBOCHARGER
TURBOCHARGER
MUFFLER AND MOUNTING
MUFFLER PIPING
WATER MANIFOLD AND THERMOSTAT
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
GEAR CASE AND GEAR
OIL PAN
OIL PAN (COLD TERRAIN SPEC. -30ßC¤ -40ßC)
FLYWHEEL AND FLYWHEEL HOUSING
POWER TAKE OFF
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND CAM FOLLOWER
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER AND MOUNTING
MECHANICAL PUMP AND PIPING
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND MOUNTING
FUEL INJECTION PUMP PIPING
FUEL RETURN PIPING
ENGINE STOP MOTOR AND MOUNTING
FUEL FILTER AND PIPING
ADDITIONAL FUEL FILER
FUEL NOZZLE AND SPILL PIPE
AUTO PRIMING SYSTEM
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (COUPLING)
FUEL INJECTION PUMP (FEED PUMP)
COOLING SYSTEM
WATER PUMP AND MOUNTING
COOLING FAN AND MOUNTING
TENSION PULLEY
CORROSION RESISTOR AND PIPING
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (35A¤ 50A¤ 75A)
ALTERNATOR DRIVE
STARTING MOTOR AND MOUNTING (7
ALTERNATOR (50A)
ALTERNATOR (35A)
ALTERNATOR (75A)
STARTING MOTOR (7
ACCESSORY
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR AND MOUNTING (COLD TERRAIN SPEC.)
AIR COMPRESSOR PIPING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR
AIR COMPRESSOR (COLD TERRAIN AND EXTREME COLD TERRAIN SPEC.)
ENGINE KIT
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
TURBOCHARGER
MUFFLER PIPING
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
GEAR CASE AND GEAR
OIL PAN
POWER TAKE OFF
CRANKSHAFT
FUEL SYSTEM
FUEL RETURN PIPING
AUTO PRIMING SYSTEM
COOLING SYSTEM
TENSION PULLEY
ELECTRICAL SYSTEM
ALTERNATOR DRIVE
ALTERNATOR (50A)
ALTERNATOR (35A)
ALTERNATOR (75A)
STARTING MOTOR (7
ACCESSORY
AIR COMPRESSOR
ENGINE KIT
GASKET KIT
- KOMATSU Fault Codes
