Komatsu Engine S6D155-4S 52707-UP Parts Catalog
Model: Komatsu S6D155-4S Engine
Serial Number: 52707-UP
Number of Pages: 128 Pages
S6D155-4S S N 52707-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR INTAKE MANIFOLD AND AFTER COOLER (WITH AFTER COOLER)
AIR CLEANER
AIR CLEANER (WITH AFTER COOLER)
EXHAUST MANIFOLD AND TURBOCHARGER
EXHAUST MANIFOLD AND TURBOCHARGER (WITH COVER)
TURBOCHARGER
HEAT SHIELD
MUFFLER
WATER MANIFOLD AND THERMOSTAT
WATER MANIFOLD AND THERMOSTAT (WITH AFTER COOLER)
WATER PIPING (WITH AFTER COOLER)
CYLINDER BLOCK
CYLINDER BLOCK (1)
CYLINDER BLOCK (COLD TERRAIN SPEC.)
GEAR CASE COVER AND FRONT SUPPORT
GEAR CASE AND GEAR
OIL PAN
OIL PAN (COLD TERRAIN SPEC.)
HEATER (COLD TERRAIN SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING
POWER TAKE OFF
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
OIL STRAINER AND PIPING
LUBRICATING OIL FILTER
BYPASS FILTER
BYPASS FILTER (COLD TERRAIN SPEC.)
P.T.O. LUBRICATING OIL PIPING
CAMSHAFT LUBRICATING OIL PIPING
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING (1 2)
FUEL INJECTION PUMP AND PIPING (2 2)
FUEL INJECTION PUMP DRIVE
FUEL FILTER AND PIPING
FUEL FILTER AND PIPING (WITH AFTER COOLER)
FUEL NOZZLE AND SPILL PIPE
AUTO PRIMING SYSTEM
ETHER STARTING AID (WITH AFTER COOLER)
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (FEED PUMP)
AUTOMATIC TIMER
COOLING SYSTEM
WATER PUMP
COOLING FAN AND ACCESSORY DRIVE
TENSION PULLEY
CORROSION RESISTOR AND PIPING
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (35A AND 50A)
ALTERNATOR DRIVE
STARTING MOTOR AND MOUNTING (11KW)
A.P.S. CONTROL UNIT AND SAFETY RELAY
ALTERNATOR (35A)
ALTERNATOR (50A)
STARTING MOTOR (11KW)
ENGINE KIT
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
AIR CLEANER
TURBOCHARGER
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
GEAR CASE AND GEAR
OIL PAN
POWER TAKE OFF
CRANKSHAFT
CAMSHAFT AND TAPPET
BYPASS FILTER
FUEL SYSTEM
AUTO PRIMING SYSTEM
AUTOMATIC TIMER
COOLING SYSTEM
WATER PUMP
TENSION PULLEY
ELECTRICAL SYSTEM
ALTERNATOR DRIVE
ALTERNATOR (35A)
ALTERNATOR (50A)
ENGINE KIT
GASKET KIT
- KOMATSU Fault Codes
