Komatsu Engine S6D140E-2A-6 22537-UP Parts Catalog
Model: Komatsu S6D140E-2A-6 Engine
Serial Number: 22537-UP
Number of Pages: 239 Pages
S6D140E-2A-6 S N 22537-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER MOUNTING
AIR INTAKE MANIFOLD
AIR CLEANER
AIR CLEANER (WITH INTAKE EXTENSION PIPE)
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING AND LUBRICATOR
TURBOCHARGER (INNER PARTS)
MUFFLER
MUFFLER (FOR AIR CLEANER WITH INTAKE EXTENSION PIPE)
EJECTOR PIPING
EJECTOR PIPING (FOR AIR CLEANER WITH INTAKE EXTENSION PIPE)
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (1 2) (WITH BLOCK HEATER)
CYLINDER BLOCK (2 2)
CYLINDER BLOCK (2 2) (WITH BLOCK HEATER)
CYLINDER BLOCK MOUNTING
CYLINDER BLOCK MOUNTING (WITH BLOCK HEATER)
FRONT COVER
FRONT COVER MOUNTING
IDLER GEAR
CAM FOLLOWER COVER
OIL PAN AND SUCTION TUBE (WITH OIL PAN HEATER)
OIL LEVEL GAUGE (WITH OIL PAN HEATER)
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (HARDENING)
CRANK PULLEY (NON HARDENING)
ROCKER ARM AND HOUSING
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
FRONT POWER TAKE OFF (WITHOUT FRONT POWER TAKE OFF)
OIL PUMP
LUBRICATING OIL FILTER AND MOUNTING
OIL COOLER
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP MOUNTING (WITH ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP (PUMP) (1 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (ACTUATOR) (1 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (ACTUATOR) (2 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP LUBRICATOR (WITH ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR AND MOUNTING
WATER SEPARATOR AND MOUNTING (WITH ELECTRICAL GOVERNOR)
ADDITIONAL FUEL FILTER (FORWARDED INDIVIDUALLY PARTS)
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP
THERMOSTAT HOUSING
AIR VENT
COOLING FAN
FAN PULLEY (WITH NON HARDENING PULLEY) (WITH AIR CONDITIONER)
FAN PULLEY (WITH HARDENING PULLEY)
FAN PULLEY (WITH HARDENING PULLEY) (WITH AIR CONDITIONER)
FAN DRIVE
FAN DRIVE (WITH HARDENING PULLEY)
CORROSION RESISTOR AND PIPING
ALTERNATOR MOUNTING (50A) (WITH NON HARDENING PULLEY)
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY)
ALTERNATOR MOUNTING (50A) (WITH HARDENING PULLEY)
ALTERNATOR MOUNTING (50A) (WITH HARDENING PULLEY) (EXTREME COLD TERRAIN SPEC.)
ALTERNATOR MOUNTING (75A) (WITH HARDENING PULLEY)
ALTERNATOR (50A) (WITH NON HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (50A) (WITH HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (50A) (WITH HARDENING PULLEY) (EXTREME COLD TERRAIN SPEC.) (INNER PARTS)
ALTERNATOR (75A) (WITH HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (60A) (WITH HARDENING PULLEY) (INNER PARTS)
HEATER SWITCH WIRING
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
SPARE PARTS
SPARE PARTS (WITH ADDITIONAL FUEL FILTER)
TAMPER PROOF KIT (FOR REGULATION OF EPA)
NAME PLATE AND CAUTION PLATE (FOR REGULATION OF EC) (FOR EU EXHAUST GAS REGULATION)
NAME PLATE AND CAUTION PLATE (FOR REGULATION OF EU)
NAME PLATE AND CAUTION PLATE (FRENCH)
NAME PLATE AND CAUTION PLATE (SPANISH)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (INDONESIAN)
NAME PLATE AND CAUTION PLATE (ITALIAN)
NAME PLATE AND CAUTION PLATE (GREEK)
NAME PLATE AND CAUTION PLATE (PORTUGUESE)
NAME PLATE AND CAUTION PLATE (POLISH)
NAME PLATE AND CAUTION PLATE (CZECH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (GERMAN)
NAME PLATE AND CAUTION PLATE (FOR REGULATION OF EPA)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (FOR REGULATION OF EPA) (FOR EU EXHAUST GAS REGULATION)
ENGINE WIRING PARTS (WITH ELECTRICAL GOVERNOR)
WASHER
HOOD (WITH INTAKE EXTENSION PIPE)
ELEMENT
GASKET
ELEMENT (1)
V-BELT
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER MOUNTING
AIR INTAKE MANIFOLD
AIR CLEANER
EXHAUST MANIFOLD
MUFFLER
EJECTOR PIPING
FRONT COVER
IDLER GEAR
CAM FOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CAMSHAFT
CAMFOLLOWER
OIL PUMP
OIL COOLER
FUEL FILTER
INJECTION NOZZLE
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP
THERMOSTAT HOUSING
AIR VENT
COOLING FAN
FAN DRIVE
SPARE PARTS
WASHER
ELEMENT
GASKET
ELEMENT (1)
V-BELT
- KOMATSU Fault Codes
