Komatsu Engine S6D140-1Z-F 10001-UP Parts Catalog
Model: Komatsu S6D140-1Z-F Engine
Serial Number: 10001-UP
Number of Pages: 149 Pages
S6D140-1Z-F S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR CLEANER
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (INNER PARTS)
TURBOCHARGER OIL PIPING
HEAT SHIELD
MUFFLER
MUFFLER (FOR SHORT EXHAUST PIPE)
EJECTOR PIPING
EJECTOR PIPING (FOR SHORT EXHAUST PIPE)
CYLINDER BLOCK (1 2) (BLIND COVER)
CYLINDER BLOCK (1 2) (FOR SCRAPER)
CYLINDER BLOCK (2 2) (BLIND COVER)
CYLINDER BLOCK (2 2) (FOR SCRAPER)
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
ROCKER ARM AND HOUSING
FRONT POWER TAKE OFF
FRONT POWER TAKE OFF (WITHOUT POWER TAKE OFF)
FRONT POWER TAKE OFF (1 2) (WITHOUT POWER TAKE OFF) (FOR SCRAPER) FOR SCRAPER)
FRONT POWER TAKE OFF (1 2) (FOR SCRAPER)
FRONT POWER TAKE OFF (2 2) (WITHOUT POWER TAKE OFF) (FOR SCRAPER)
FRONT POWER TAKE OFF (2 2) (FOR SCRAPER)
OIL PUMP
OIL ADAPTER
OIL FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
WATER PUMP
THERMOSTAT AND PIPING
AIR VENT
COOLING FAN (REVERSIBLE TYPE)
COOLING FAN
TENSION PULLEY
FAN BELT
FAN BELT (FOR SCRAPER)
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (35A)
ALTERNATOR (60A) (INNRE PARTS)
HEATER SWITCH WIRING
INJECTION PUMP SAFETY GUARD
INJECTION PUMP SAFETY GUARD (FOR SCRAPER)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
SPARE PARTS
SPARE PARTS (FOR SCRAPER)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH-ENGLISH)
NAME PLATE AND CAUTION PLATE (GERMAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (INDONESIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (POLISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (PORTUGUESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (GREEK-ENGLISH)
NAME PLATE AND CAUTION PLATE (SPANISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (ITALIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (CZECH)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR CLEANER
EXHAUST MANIFOLD
HEAT SHIELD
MUFFLER
EJECTOR PIPING
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT
CAMFOLLOWER
OIL PUMP
OIL ADAPTER
OIL FILTER
OIL COOLER
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
TENSION PULLEY
FAN BELT
CORROSION RESISTOR
SPARE PARTS
- KOMATSU Fault Codes
