Komatsu Engine S6D140-1Z 17626-UP Parts Catalog
Model: Komatsu S6D140-1Z Engine
Serial Number: 17626-UP
Number of Pages: 136 Pages
KOMATSU S6D140-1Z S N 17626-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR CLEANER
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (INNER PARTS)
TURBOCHARGER OIL PIPING
HEAT SHIELD
MUFFLER
MUFFLER (FOR SHORT EXHAUST PIPE)
EJECTOR PIPING
EJECTOR PIPING (FOR SHORT EXHAUST PIPE)
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (1 2) (FOR SCRAPER)
CYLINDER BLOCK (2 2) (BLIND COVER)
CYLINDER BLOCK (2 2) (FOR SCRAPER)
FRONT COVER
IDLER GEAR
CAM FOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM AND HOUSING
CAMSHAFT AND CAM FOLLOWER
FRONT P.T.O.
FRONT P.T.O. (WITHOUT FRONT P.T.O.)
FRONT P.T.O. (1 2) (WITHOUT FRONT P.T.O.) (FOR SCRAPER)
FRONT P.T.O. (1 2) (FOR SCRAPER)
FRONT P.T.O. (2 2) (WITHOUT FRONT P.T.O.) (FOR SCRAPER)
FRONT P.T.O. (2 2) (FOR SCRAPER)
OIL PUMP
OIL ADAPTER
OIL FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
INJECTION BRACKET AND PIPING
INJECTION PUMP LUBRICATOR
INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
WATER PUMP
THERMOSTAT AND PIPING
AIR VENT
COOLING FAN (REVERSIBLE TYPE)
COOLING FAN
TENSION PULLEY
FAN BELT
FAN BELT (FOR SCRAPER)
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (35A)
HEATER SWITCH WIRING
INJECTION PUMP SAFETY GUARD
INJECTION PUMP SAFETY GUARD (FOR SCRAPER)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
SPARE PARTS
SPARE PARTS (FOR SCRAPER)
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH-ENGLISH)
NAME PLATE AND CAUTION PLATE (GERMAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (INDONESIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (POLISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (PORTUGUESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (GREEK-ENGLISH)
NAME PLATE AND CAUTION PLATE (SPANISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (ITALIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (CZECH)
