Komatsu Engine S6D140-1X-F 10001-UP Parts Catalog
Model: Komatsu S6D140-1X-F Engine
Serial Number: 10001-UP
Number of Pages: 143 Pages
S6D140-1X-F S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR CLEANER MOUNTING (WITH INTAKE EXTENSION)
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110-344B) (INNER PARTS)
TURBOCHARGER OIL PIPING
MUFFLER
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
CYLINDER BLOCK ACCESSORY
FRONT COVER (WITH POWER TAKE OFF)
FRONT COVER
FRONT COVER ACCESSORY (WITH POWER TAKE OFF)
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (WITH HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
ROCKER ARM AND HOUSING
FRONT POWER TAKE OFF (WITH POWER TAKE OFF) (WITH HARDENING)
OIL PUMP
LUBRICATING OIL FILTER AND MOUTING
OIL COOLER
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
INJECTION NOZZLE
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP MOUNTING
AIR VENT
COOLING FAN
COOLING FAN (SUCTION)
FAN PULLEY (HARDENING PULLEY)
FAN DRIVE
ALTERNATOR MOUNTING (50A)
HEATER SWITCH WIRING
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
AIR COMPRESSOR RELIEF VALVE
WATER PUMP GASKET KIT
CYLINDER BLOCK GASKET KIT
CYLINDER HEAD GASKET KIT
AIR COMPRESSOR GASKET KIT
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE)
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
EXHAUST MANIFOLD
MUFFLER
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
CAMSHAFT
CAMFOLLOWER
OIL PUMP
OIL COOLER
FUEL FILTER
INJECTION NOZZLE
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP MOUNTING
AIR VENT
COOLING FAN
FAN DRIVE
- KOMATSU Fault Codes
