Komatsu Engine S6D140-1W-F 10001-UP Parts Catalog
Model: Komatsu S6D140-1W-F Engine
Serial Number: 10001-UP
Number of Pages: 162 Pages
S6D140-1W-F S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR CLEANER
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110G-444B) (INNER PARTS)
TURBOCHARGER (KTR110G-E44B) (INNER PARTS)
MUFFLER
EJECTOR
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE (WITHOUT OIL PAN HEATER)
OIL PAN AND SUCTION TUBE (WITH OIL PAN HEATER)
OIL LEVEL GAUGE (WITHOUT OIL PAN HEATER)
OIL LEVEL GAUGE (WITH OIL PAN HEATER)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER (EXTREME COLD TERRAIN SPEC.)
PISTON
CRANK PULLEY (NON HARDENING PULLEY)
CRANK PULLEY (HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
ROCKER ARM AND HOUSING
FRONT POWER TAKE OFF
OIL PUMP
OIL FILTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR (WITH WATER SEPARATOR)
INJECTION NOZZLE
FUEL RETURN
ENGINE STOP MOTOR
WATER PUMP
AIR VENT
COOLING FAN
FAN PULLEY (HARDENING PULLEY) (WITH AIR CONDITIONER TYPE)
FAN PULLEY (NON HARDENING PULLEY) (WITHOUT AIR CONDITIONER TYPE)
FAN PULLEY (NON HARDENING PULLEY) (WITH AIR CONDITIONER TYPE)
FAN PULLEY (HARDENING PULLEY) (WITHOUT AIR CONDITIONER TYPE)
FAN DRIVE (NON HARDENING PULLEY)
FAN DRIVE (HARDENING PULLEY)
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (50A) (ALTERNATOR WITH NON HARDENING PULLEY)
ALTERNATOR (50A) (WITH NON HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (60A) (INNRE PARTS)
HEATER SWITCH WIRING
INJECTION PUMP SAFETY GUARD
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
AIR COMPRESSOR RELIEF VALVE
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH-ENGLISH)
NAME PLATE AND CAUTION PLATE (GERMAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (INDONESIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (POLISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (PORTUGUESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (GREEK-ENGLISH)
NAME PLATE AND CAUTION PLATE (SPANISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (ITALIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (CZECH)
