Komatsu Engine S6D140-1U-F 10001-UP Parts Catalog
Model: Komatsu S6D140-1U-F Engine
Serial Number: 10001-UP
Number of Pages: 165 Pages
S6D140-1U-F S N 10001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD
AIR CLEANER MOUNTING
EXHAUST MANIFOLD
TURBOCHARGER MOUNTING
TURBOCHARGER (KTR110A-11S) (INNER PARTS)
TURBOCHARGER (KTR110G-444A) (INNER PARTS)
TURBOCHARGER OIL PIPING
MUFFLER (WITH EXHAUST CAP)
EJECTOR PIPING (WITH EXHAUST CAP)
CYLINDER BLOCK (1 2) (BLIND COVER)
CYLINDER BLOCK (2 2) (BLIND COVER)
FRONT COVER
FRONT COVER ACCESSORY
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
POWER TAKE OFF
POWER TAKE OFF LUBRICATOR
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (WITH HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
CAMSHAFT AND CAMFOLLOWER
CAMFOLLOWER
ROCKER ARM AND HOUSING
FRONT POWER TAKE OFF ACCESSORY
FRONT POWER TAKE OFF (WITH POWER TAKE OFF)
OIL PUMP
LUBRICATING OIL ADAPTER
LUBRICATING OIL ADAPTER AND PIPING
OIL COOLER
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
FUEL RETURN
WATER PUMP
THERMOSTAT AND PIPING
AIR VENT
COOLING FAN (REVERSIBLE TYPE)
COOLING FAN (HIGH SPEED FAN SPEC.)
TENSION PULLEY
COOLING FAN V-BELT (REVERSIBLE FAN TYPE)
COOLING FAN BELT (HIGH SPEED FAN SPEC.)
COOLING FAN BELT (NOISE SUPPRESSION SPEC. FOR EC)
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A¤ 60A)
ALTERNATOR MOUNTING (35A)
ALTERNATOR (60A) (INNRE PARTS)
STARTING MOTOR (7
HEATER SWITCH WIRING
SAFETY GUARD
WATER PUMP GASKET KIT
CYLINDER BLOCK GASKET KIT
CYLINDER HEAD GASKET KIT
SPARE PARTS (HIGH SPEED FAN SPEC.)
SPARE PARTS (EC NOISE SUPPRESSION SPEC.)
SPARE PARTS
NAME PLATE AND CAUTION PLATE (CHINESE)
NAME PLATE AND CAUTION PLATE (ENGLISH)
NAME PLATE AND CAUTION PLATE (FRENCH-ENGLISH)
NAME PLATE AND CAUTION PLATE (GERMAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (ARABIC)
NAME PLATE AND CAUTION PLATE (INDONESIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (PERSIAN)
NAME PLATE AND CAUTION PLATE (POLISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (PORTUGUESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (GREEK-ENGLISH)
NAME PLATE AND CAUTION PLATE (SPANISH-ENGLISH)
NAME PLATE AND CAUTION PLATE (ITALIAN-ENGLISH)
NAME PLATE AND CAUTION PLATE (RUSSIAN)
NAME PLATE AND CAUTION PLATE (CZECH)
CAUITON PLATE (ENGLISH) (NON REGULATION OF EPA)
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD
EXHAUST MANIFOLD
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
POWER TAKE OFF
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
CAMSHAFT
CAMFOLLOWER
OIL PUMP
OIL COOLER
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
FUEL RETURN
WATER PUMP
AIR VENT
TENSION PULLEY
CORROSION RESISTOR
STARTING MOTOR (7
SAFETY GUARD
SPARE PARTS
- KOMATSU Fault Codes
