Komatsu Engine S6D140-1U 10001-UP Parts Catalog
Model: Komatsu S6D140-1U Engine
Number of Pages: 90 Pages
S6D140-1U S N 10001-UP
AIR CLEANER AND MOUNTING
MUFFLER EJECTOR
CYLINDER BLOCK (WITH AIR CONDITIONER TYPE)
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
FRONT COVER AND FRONT SUPPORT (WITH AIR CONDITIONER TYPE)
POWER TAKE OFF
LUBRICATING OIL FILTER AND PIPING
LUBRICATING OIL ADAPTER
POWER TAKE OFF LUBRICATING OIL PIPING
WATER SEPARATOR AND PIPING (EXCEPT JAPAN)
WATER PUMP AND THERMOSTAT
WATER BYPASS PIPING
COOLING FAN AND V-BELT
COOLING FAN AND V-BELT (REVERSIBLE FAN TYPE)
TENSION PULLEY
ALTERNATOR AND MOUNTING (35A)
ALTERNATOR AND MOUNTING (50A)
STARTING MOTOR AND MOUNTING (11KW)
TOOL AND KIT
MUFFLER EJECTOR
POWER TAKE OFF
WATER BYPASS PIPING
TENSION PULLEY
TOOL AND KIT
