Komatsu Engine S6D125E-2J-6 60721-UP Parts Catalog
Model: Komatsu S6D125E-2J-6 Engine
Serial Number: 60721-UP
Number of Pages: 189 Pages
S6D125E-2J-6 S N 60721-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER (1)
HEAD COVER RELATED PARTS (OIL FILLER)
AIR INTAKE MANIFOLD
AIR INTAKE MANIFOLD (1)
HEATER SWITCH
AIR CLEANER
AIR CLEANER MOUNTING
AIR CLEANER CAP
EXHAUST MANIFOLD
TURBOCHARGER OIL PIPING
TURBOCHARGER (INNER PARTS)
MUFFLER (SILVER EXHAUST PIPE¤ 1130MM) (WITH COVER)
MUFFLER (WITHOUT COVER)
MUFFLER (WITHOUT COVER) (1)
MUFFLER (WITH COVER)
THERMOSTAT HOUSING
WATER TEMPERATURE SENSOR
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
CYLINDER BLOCK BLIND COVER AND PLUG
FRONT COVER
FRONT COVER MOUNTING
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
CRANK PULLEY (HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
TACHOMETER GEAR
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER MOUNTING PARTS
WATER DRAIN VALVE
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP DRIVE
FUEL FILTER (FOR SLAG HANDLING) (WITH HEAT RESISTING HOSE)
FUEL FILTER
WATER SEPARATOR AND PIPING
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
FUEL RETURN (FOR SLAG HANDLING) (WITH HEAT RESISTING HOSE)
FUEL CONTROL LEVER
WATER PUMP
AIR VENT
COOLING FAN
COOLING FAN (REVERSIBLE TYPE)
FAN PULLEY (NON HARDENING PULLEY)
FAN PULLEY (HARDENING PULLEY)
FAN DRIVE
CORROSION RESISTER
TORQUE CONVERTER AND TRANSMISSION OIL COOLER
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY)
ALTERNATOR MOUNTING (35A) (WITH NON HARDENING PULLEY) (WITH COVER)
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY) (WITH COVER) (WITH AIR CONDITIONER)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (INNER PARTS)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (INNER PARTS) (1)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (WITH COVER) (WITH AIR CONDITIONER) (INNER PARTS)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
SAFETY GUARD (FOR FUEL INJECTION PUMP DRIVE)
SAFETY GUARD (FOR EXHAUST MANIFOLD AND TURBOCHARGER)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
V-BELT (AIR CONDITIONER PUMP)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
TAMPER PROOF KIT (FOR REGULATION OF EPA)
HEATER SIGNAL
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND CAUTION PLATE (FOR REGULATION OF EPA)
NAME PLATE AND CAUTION PLATE (FOR TPEM APPLICATION)
NAME PLATE AND CAUTION (EPA DEREGULATION ACTION SPECIFICATION)
DUST INDICATOR
EXHAUST PIPE (SILVER EXHAUST PIPE¤ 1130MM)
EXHAUST PIPE (BLACK EXHAUST PIPE¤ 470MM)
CAUTION PLATE (ARABIC)
CAUTION PLATE (CHINESE)
CAUTION PLATE (GERMAN)
CAUTION PLATE (ENGLISH)
CAUTION PLATE (FRENCH)
CAUTION PLATE (INDONESIAN)
CAUTION PLATE (SPANISH)
CAUTION PLATE (PERSIAN)
CAUTION PLATE (ITALIAN)
CAUTION PLATE (PORTUGUESE)
