Komatsu Engine S6D125E-2B-6 60721-UP Parts Catalog
Model: Komatsu S6D125E-2B-6 Engine
Serial Number: 60721-UP
Number of Pages: 154 Pages
KOMATSU S6D125E-2B-6 S N 60721-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
HEATER SWITCH
AIR CLEANER MOUNTING
PRE-CLEANER
EXHAUST MANIFOLD (WITH COVER)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (WITH COVER) (FOR JAPAN)
TURBOCHARGER OIL PIPING (WITH COVER)
TURBOCHARGER OIL PIPING (WITHOUT COVER)
MUFFLER (BLACK EXHAUST PIPE¤ 860MM) (WITH COVER)
MUFFLER (BLACK EXHAUST PIPE¤ 860MM) (WITHOUT COVER)
MUFFLER (WITH COVER)
MUFFLER (WITHOUT COVER)
THERMOSTAT HOUSING
WATER TEMPERATURE SENSOR
WATER TEMPERATURE SENSOR (GAUGE PANEL TYPE)
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
CYLINDER BLOCK BLIND COVER AND PLUG
FRONT COVER (NOISE SUPPRESSION SPEC.)
FRONT COVER
FRONT COVER MOUNTING (NOISE SUPPRESSION SPEC.)
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING (NOISE SUPPRESSION SPEC.)
FLYWHEEL
ENGINE MOUNTING (NOISE SUPPRESSION SPEC.)
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER MOUNTING PARTS
WATER DRAIN VALVE
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP MOUNTING (INDUSTRY WASTE SPEC.)
FUEL INJECTION PUMP (PUMP) (1 2) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (INDUSTRY WASTE SPEC.) (INNER PARTS)
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP DRIVE
FUEL INJECTION PUMP DRIVE (INDUSTRY WASTE SPEC.)
FUEL FILTER (AUTO AIR BLEEDING)
FUEL FILTER
FUEL PUMP AND PIPING (AUTO AIR BLEEDING)
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
FAN PULLEY (NON HARDENING PULLEY)
FAN DRIVE
FAN GUARD (1 2)
FAN GUARD (2 2)
CORROSION RESISTER
ALTERNATER MOUNTING (35A) (WITH NON HARDENING PULLEY) (WITH COVER)
ALTERNATER (35A) (WITH NON HARDENING PULLEY) (WITH COVER) (INNER PARTS)
ALTERNATER (35A) (WITH NON HARDENING PULLEY) (INNER PARTS)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (11KW) (COLD TERRAIN SPEC.)
STARTING MOTOR (7
STARTING MOTOR (11KW) (COLD TERRAIN SPEC.) (INNER PARTS)
SAFETY GUARD (FOR FUEL INJECTION PUMP DRIVE)
WATER PUMP GASKET KIT
CYLINDER BLOCK GASKET KIT
CYLINDER HEAD GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION (JAPANESE)
NAME PLATE AND CAUTION (JAPANESE-ENGLISH)
CAUTION PLATE (JAPANESE)
EXHAUST PIPE (BLACK EXHAUST PIPE¤ 860MM)
CAUTION PLATE (JAPANESE) (1)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
HEATER SWITCH
PRE-CLEANER
EXHAUST MANIFOLD
THERMOSTAT HOUSING
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
WATER DRAIN VALVE
FUEL FILTER
INJECTION NOZZLE
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
FAN DRIVE
FAN GUARD (1 2)
FAN GUARD (2 2)
CORROSION RESISTER
STARTING MOTOR (7
SPARE PARTS
- KOMATSU Fault Codes
