Komatsu Engine S6D105-1X 63244-UP Parts Catalog
Model: Komatsu S6D105-1X Engine
Serial Number: 63244-UP
Number of Pages: 93 Pages
S6D105-1X S N 63244-UP
CYLINDER HEAD COVER
AIR CLEANER AND MOUNTING
TURBOCHARGER (EXCEPT JAPAN)
FRONT COVER AND GEAR
OIL PAN (COLD TERRAIN SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING (KEY STOP TYPE)
FLYWHEEL AND FLYWHEEL HOUSING (KEY STOP TYPE) (1)
CRANKSHAFT (WIHT AIR CONDITIONER)
LUBRICATING OIL PIPING
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP AND PIPING (WITH AIR COMPRESSOR) (EXCEPT JAPAN)
SOLENOID AND MOUNTING (KEY STOP TYPE)
ADDITIONAL FUEL FILTER
FUEL INJECTION PUMP (PUMP)
WATER PUMP AND COOLING FAN
ALTERNATOR AND MOUNTING (50A) (BRACKET MOUNTING TYPE)
ALTERNATOR AND MOUNTING (25A¤ 35A¤ 50A¤ 75A) (BRACKET MOUNTING TYPE)
STARTING MOTOR AND MOUNTING (5.5KW¤ 7
HEATER SWITCH AND HEATER SIGNAL
ALTERNATOR (50A) (WITH NON HARDENING PULLEY)
ALTERNATOR (35A)
ALTERNATOR (50A) (WITH HARDENING PULLEY)
ALTERNATOR (75A) (WITH NON HARDENING PULLEY)
STARTING MOTOR (7.5KW)
ACCESSORY
AIR COMPRESSOR PIPING (EXCEPT JAPAN)
AIR COMPRESSOR (EXCEPT JAPAN)
ENGINE KIT
CYLINDER HEAD COVER
ALTERNATOR (35A)
ACCESSORY
ENGINE KIT
