Komatsu Engine S6D105-1AJ 86535-UP Parts Catalog
Model: Komatsu S6D105-1AJ Engine
Serial Number: 86535-UP
Number of Pages: 95 Pages
S6D105-1AJ S N 86535-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
AIR CLEANER AND MOUNTING
EXHAUST MANIFOLD AND TURBOCHARGER
TURBOCHARGER
MUFFLER AND MOUNTING
CYLINDER BLOCK
CYLINDER BLOCK (1)
FRONT COVER AND GEAR
OIL PAN
OIL PAN (WITH OIL PAN HEATER)
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER AND MOUNTING
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (WITH BLOCK HEATER)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
FUEL INJECTION PUMP AND PIPING (WITH AIR COMPRESSOR)
ENGINE STOP MOTOR AND MOUNTING
FUEL FILTER AND PIPING
WATER SEPARATOR
ADDITIONL FUEL FILER
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (COUPLING)
FUEL INJECTION PUMP (FEED PUMP)
COOLING SYSTEM
WATER PUMP AND COOLING FAN
WATER PUMP AND COOLING FAN (HI-SPEED PULLEY TYPE)
CORROSION RESISTOR AND PIPING
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (35A)
ALTERNATOR AND MOUNTING (50A)
STARTING MOTOR AND MOUNTING (5.5KW¤ 7
HEATER SIGNAL AND HEATER SWITCH
ALTERNATOR (35A)
ALTERNATOR (25A)
ALTERNATOR (50A)
STARTING MOTOR (7
STARTING MOTOR (5
ACCESSORY
AIR COMPRESSOR AND PIPING
AIR COMPRESSOR
KIT
GASKET KIT
