Komatsu Engine S6D102E-1F-6 26200163-UP Parts Catalog
Model: Komatsu S6D102E-1F-6 Engine
Serial Number: 26200163-UP
Number of Pages: 137 Pages
S6D102E-D-1FL-6S S N 26200163-UP
ENGINE
CYLINDER HEAD
WATER VALVE AND WATER TEMPERATURE SENSOR
REAR HANGER
HEAD COVER
AIR INTAKE HEATER
HEATER SWITCH
AIR CLEANER (FORWARDED INDIVIDUALLY PARTS)
EXHAUST CONNECTOR CLAMP
EXHAUST MANIFOLD
EXHAUST MANIFOLD GASKET AND BOLT
AIR CONNECTOR
TURBOCHARGER OIL PIPING
TURBOCHARGER MOUNTING
HEAT SHIELD (TUNNEL SEPC.) (CERAMIC TYPE)
HEAT SHIELD (WITH PLATE) (FOR JAPAN)
HEAT SHIELD
MUFFLER AND MOUNTING
THERMOSTAT HOUSING
THERMOSTAT
OIL PRESSURE SWITCH
CYLINDER BLOCK
FRONT COVER
CAMFOLLOWER COVER
BREATHER HOSE
CYLINDER BLOCK BLIND PLUG
OIL FILLER
OIL PAN BOLT
OIL LEVEL SENSOR AND OIL GAUGE
OIL PAN AND SUCTION TUBE
FLYWHEEL HOUSING PLUG (WITH REVOLUTION SENSOR)
FLYWHEEL HOUSING
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
TAPPET
CAMSHAFT
FRONT GEAR TRAIN COVER
TACHOMETER DRIVE COVER
UNDER PLATE
OIL PUMP
OIL COOLER AND OIL FILTER
FUEL INJECTION PUMP AND OIL PIPING (FOR REGULATION OF EPA)
FUEL INJECTION PUMP (PUMP) (1 2) (FOR REGULATION OF EPA) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (FOR REGULATION OF EPA) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (FOR REGULATION OF EPA) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (FOR REGULATION OF EPA) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (FOR REGULATION OF EPA) (INNER PARTS)
FUEL INLET AND OUTLET JOINT
FUEL INJECTION PUMP MOUNTING AND GEAR
FUEL FILTER
INJECTION PIPING
FUEL RETURN
FUEL FILTER MOUNTING AND PIPING
CYLINDER BLOCK BLIND COVER
INJECTION NOZZLE
STOP SOLENOID
WATER PUMP (WITH NON HARDENING PULLEY)
WATER PUMP
WATER CONNECTOR
WATER CONNECTOR PLUG
FAN DRIVE PULLEY (HIGH SPEED TYPE)
FAN DRIVE PULLEY (STOCKBREEDING SPEC.)
COOLING FAN
FAN PULLEY (FOR 25A ALTERNATOR)
ALTERNATOR (35A)
ALTERNATOR (60A)
BELT TENSIONER (FOR 60A ALTERNATOR) (BELT LENGTH 1490MM)
BELT TENSIONER (FOR 60A ALTERNATOR) (BELT LENGTH 1473
ALTERNATOR SUPPORT (F0R 35A ALTERNATOR AND 60A ALTERNATOR)
STARTING MOTOR (5
STARTING MOTOR (4
STARTING MOTOR (4 (1)
STARTING MOTOR (5 (1)
STARTING MOTOR (4 (2)
STARTING MOTOR (4 (3)
STARTING MOTOR MOUNTING (4
STARTING MOTOR MOUNTING (5
REPAIR PARTS (1 4) (CYLINDER HEAD)
REPAIR PARTS (2 4) (CYLINDER BLOCK)
REPAIR PARTS (3 4) (CRANKSHAFT)
REPAIR PARTS (4 4) (PISTON)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
SPARE PARTS
CAUTION PLATE (JAPANESE-ENGLISH)
CAUTION PLATE (ENGLISH)
CAUTION PLATE (FOR REGULATION OF EPA)
CAUTION PLATE (JAPANESE) (ORDERING TRANSFERRED PARTS)
MUFFLER DRAIN TUBE (ORDERING TRANSFERRED PARTS)
CAUTION PLATE (ENGLISH) (ORDERING TRANSFERRED PARTS)
ENGINE
CYLINDER HEAD
REAR HANGER
HEAD COVER
AIR INTAKE HEATER
HEATER SWITCH
EXHAUST MANIFOLD
AIR CONNECTOR
HEAT SHIELD
THERMOSTAT HOUSING
THERMOSTAT
OIL PRESSURE SWITCH
CYLINDER BLOCK
FRONT COVER
CAMFOLLOWER COVER
BREATHER HOSE
OIL FILLER
OIL PAN BOLT
FLYWHEEL HOUSING
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
TAPPET
CAMSHAFT
UNDER PLATE
OIL PUMP
FUEL FILTER
INJECTION PIPING
FUEL RETURN
INJECTION NOZZLE
STOP SOLENOID
WATER PUMP
WATER CONNECTOR
COOLING FAN
ALTERNATOR (35A)
ALTERNATOR (60A)
STARTING MOTOR (5
STARTING MOTOR (4
SPARE PARTS
- KOMATSU Fault Codes
