Komatsu Engine NTO-6-CI-1D 134677-UP Parts Catalog
Model: Komatsu NTO-6-CI-1D Engine
Serial Number: 134677-UP
Number of Pages: 106 Pages
NTO-6-CI-1D S N 134677-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
COMPRESSION RELEASE
AIR CLEANER AND CONNECTION (EXCEPT JAPAN)
AIR CLEANER AND CONNECTION (FOR ALGERIA)
EXHAUST MANIFOLD AND MUFFLER
WATER MANIFOLD
THERMOSTAT
TURBOCHARGER
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
REAR COVER
GEAR CASE COVER AND FRONT SUPPORT
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT AND VIBRATION DAMPER
PISTON AND CONNECTING ROD
CAMSHAFT
CAM FOLLOWER AND PUSH ROD
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL FILTER
BYPASS FILTER
LUBRICATING OIL PIPING
TURBOCHARGER LUBRICATING OIL PIPING (EXCEPT JAPAN)
LUBRICATING OIL COOLER
TORQUE CONVERTER OIL COOLER
FUEL SYSTEM
PT FUEL PUMP AND PIPING
PT FUEL PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTOR AND FUEL CONNECTION
PT FUEL PUMP (1 6)
PT FUEL PUMP (2 6)
PT FUEL PUMP (3 6)
PT FUEL PUMP (4 6)
PT FUEL PUMP (5 6)
PT FUEL PUMP (6 6)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR AND MOUNTING
ALTERNATOR AND MOUNTING (800W)
STARTING MOTOR AND MOUNTING
REGULATOR AND SAFETY RELAY
ALTERNATOR
ALTERNATOR (800W)
STARTING MOTOR
STARTING MOTOR (11KW)
TOOL AND KIT
GASKET KIT (EXCEPT JAPAN)
CYLINDER HEAD
CYLINDER HEAD (1)
COMPRESSION RELEASE
WATER MANIFOLD
THERMOSTAT
TURBOCHARGER
CYLINDER BLOCK
REAR COVER
OIL PAN
CAMSHAFT
BYPASS FILTER
FUEL SYSTEM
PT FUEL PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
PT FUEL PUMP (1 6)
PT FUEL PUMP (2 6)
PT FUEL PUMP (3 6)
PT FUEL PUMP (4 6)
PT FUEL PUMP (5 6)
PT FUEL PUMP (6 6)
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR
ALTERNATOR (800W)
STARTING MOTOR
TOOL AND KIT
- KOMATSU Fault Codes
