Komatsu Engine NH-220-CI-2U 100101-UP Parts Catalog
Model: Komatsu NH-220-CI-2U Engine
Serial Number: 100101-UP
Number of Pages: 94 Pages
NH-220-CI-2U S N 100101-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
COMPRESSION RELEASE
AIR CLEANER
EXHAUST MANIFOLD AND MUFFLER
WATER MANIFOLD
THERMOSTAT AND CONNECTOR
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
REAR COVER
GEAR CASE COVER AND FRONT SUPPORT
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT AND VIBRATION DAMPER
PISTON AND CONNECTING ROD
CAMSHAFT
CAM FOLLOWER AND PUSH ROD
POWER TAKE OFF (1 2)
POWER TAKE OFF (2 2)
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL FILTER
LUBRICATING OIL BYPASS FILTER
LUBRICATING OIL PIPING
P.T.O. LUBRICATING OIL PIPING
LUBRICATING OIL COOLER
OIL COOLER (TORQFLOW AND STEERING CLUTCH)
FUEL SYSTEM
PT FUEL PUMP AND PIPING
PT FUEL PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTOR AND FUEL CONNECTION
PT FUEL PUMP (1 6)
PT FUEL PUMP (2 6)
PT FUEL PUMP (3 6)
PT FUEL PUMP (4 6)
PT FUEL PUMP (5 6)
PT FUEL PUMP (6 6)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
CORROSION RESISTOR
DYNAMO AND MOUNTING
ALTERNATOR AND MOUNTING
STARTING MOTOR AND MOUNTING
REGULATOR AND SAFETY RELAY
DYNAMO
ALTERNATOR
ALTERNATOR (800W)
STARTING MOTOR
STARTING MOTOR (11KW) (FOR COLD WEATHER)
TOOL AND KIT
TOOL
GASKET KIT
