Komatsu Engine NH-220-CI-2KK 174428-UP Parts Catalog
Model: Komatsu NH-220-CI-2KK Engine
Serial Number: 174428-UP
Number of Pages: 79 Pages
NH-220-CI-2KK S N 174428-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR CLEANER
EXHAUST MANIFOLD AND MUFFLER
WATER MANIFOLD
THERMOSTAT AND CONNECTOR
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
REAR COVER
GEAR CASE COVER AND FRONT SUPPORT
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT AND VIBRATION DAMPER
PISTON AND CONNECTING ROD
CAMSHAFT
CAM FOLLOWER AND PUSH ROD
POWER TAKE OFF (1 2)
POWER TAKE OFF (2 2)
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL FILTER
LUBRICATING OIL BYPASS FILTER
LUBRICATING OIL PIPING
P.T.O. LUBRICATING OIL PIPING
LUBRICATING OIL COOLER
OIL COOLER (TORQFLOW AND STEERING CLUTCH)
FUEL SYSTEM
PT FUEL PUMP AND PIPING
PT FUEL PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTOR AND FUEL CONNECTION
FLOAT TANK
PT FUEL PUMP (1 6)
PT FUEL PUMP (2 6)
PT FUEL PUMP (3 6)
PT FUEL PUMP (4 6)
PT FUEL PUMP (5 6)
PT FUEL PUMP (6 6)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
CORROSION RESISTOR
ALTERNATOR AND MOUNTING
STARTING MOTOR AND MOUNTING
REGULATOR AND SAFETY RELAY
ALTERNATOR
STARTING MOTOR
TOOL AND KIT
TOOL
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
AIR CLEANER
WATER MANIFOLD
CYLINDER BLOCK
REAR COVER
OIL PAN
CAMSHAFT
FUEL SYSTEM
PT FUEL PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
FLOAT TANK
PT FUEL PUMP (1 6)
PT FUEL PUMP (2 6)
PT FUEL PUMP (3 6)
PT FUEL PUMP (4 6)
PT FUEL PUMP (5 6)
PT FUEL PUMP (6 6)
CORROSION RESISTOR
ALTERNATOR
STARTING MOTOR
TOOL AND KIT
TOOL
GASKET KIT
- KOMATSU Fault Codes
