Komatsu Engine NH-220-CI-1F 18566-UP Parts Catalog
Model: Komatsu NH-220-CI-1F Engine
Serial Number: 18566-UP
Number of Pages: 90 Pages
NH-220-CI-1F S N 18566-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
COMPRESSION RELEASE
WATER MANIFOLD
EXHAUST MANIFOLD AND MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
REAR COVER
GEAR CASE COVER AND FRONT SUPPORT
OIL PAN AND OIL FILLER BRACKET
CRANKSHAFT AND VIBRATION DAMPER
PISTON AND CONNECTING ROD
FLYWHEEL¤ PTO AND REAR SUPPORT
CAMSHAFT
CAM FOLLOWER AND PUSH ROD
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL FULLFLOW FILTER AND MOUNTING
LUBRICATING OIL BYPASS FILTER
LUBRICATING OIL COOLER
LUBRICATING OIL PIPE AND CONNECTION
PTO LUBRICATION OIL PIPING
TORQUE CONVERTER OIL COOLER
FUEL SYSTEM
ACCESSORY DRIVE
INJECTOR AND FUEL CONNECTION
FUEL TUBING
FUEL FILTER
PT FUEL PUMP (1 3)
PT FUEL PUMP (2 3)
PT FUEL PUMP (3 3)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND PULLEY
COOLING FAN
THERMOSTAT AND WATER CONNECTION
CORROSION RESISTOR
AIR CLEANER
STARING MOTOR AND MOUNTING
STARTING MOTOR
DYNAMO AND MOUNTING
DYNAMO
VOLTAGE REGULATOR AND SAFETY RELAY
TOOL AND KIT
TOOL
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
COMPRESSION RELEASE
WATER MANIFOLD
CYLINDER BLOCK
CYLINDER BLOCK (1)
REAR COVER
CAMSHAFT
FUEL SYSTEM
ACCESSORY DRIVE
FUEL TUBING
FUEL FILTER
PT FUEL PUMP (1 3)
PT FUEL PUMP (2 3)
PT FUEL PUMP (3 3)
COOLING FAN
CORROSION RESISTOR
AIR CLEANER
STARTING MOTOR
DYNAMO AND MOUNTING
DYNAMO
TOOL AND KIT
TOOL
GASKET KIT
- KOMATSU Fault Codes
