Komatsu Engine 6D95L-1AA 29222-UP Parts Catalog
Model: Komatsu 6D95L-1AA Engine
Serial Number: 29222-UP
Number of Pages: 99 Pages
6D95L-1AA S N 29222-UP
CYLINDER HEAD
CYLINDER HEAD (1)
CYLINDER HEAD (HIGH ALTITUDE SPEC.)
ROCKER ARM
CYLINDER HEAD COVER
CYLINDER HEAD COVER (HIGH ALTITUDE SPEC.)
AIR INTAKE MANIFOLD AND CONNECTION (HIGH ALTITUDE SPEC.)
AIR INTAKE MANIFOLD AND CONNECTION (FOR ZIMBABWE)
AIR CLEANER AND CONNECTION
AIR CLEANER AND CONNECTION (HIGH ALTITUDE SPEC.)
AIR CLEANER AND CONNECTION (FOR ZIMBABWE)
EXHAUST MANIFOLD AND MUFFLER
EXHAUST MANIFOLD AND TURBOCHARGER (HIGH ALTITUDE SPEC.)
MUFFLER AND MOUNTING (HIGH ALTITUDE SPEC.)
CYLINDER BLOCK
CYLINDER BLOCK (1)
CYLINDER BLOCK (HIGH ALTITUDE SPEC.)
FRONT COVER AND GEAR
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL PUMP AND SUCTION PIPE (HIGH ALTITUDE SPEC.)
LUBRICATING OIL FILTER
TURBOCHARGER LUBRICATING OIL PIPING (HIGH ALTITUDE SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
FUEL FILTER AND PIPING
FUEL FILTER AND PIPING (HIGH ALTITUDE SPEC.) (WITHOUT WATER SEPARATOR)
FUEL FILTER AND PIPING (FOR ZIMBABWE)
WATER SEPARATOR AND PIPING
WATER SEPARATOR AND PIPING (15A ALTERNATOR HIGH ALTITUDE SPEC.)
WATER SEPARATOR AND PIPING (FOR ZIMBABWE)
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE SPEC.)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE SPEC.)
FUEL INJECTION PUMP (FEED PUMP)
FUEL INJECTION PUMP (FEED PUMP) (HIGH ALTITUDE SPEC.)
COOLING SYSTEM
WATER PUMP AND COOLING FAN
WATER PUMP AND COOLING FAN (HIGH ALTITUDE SPEC.)
WATER PUMP AND COOLING FAN (FOR CUBA)
TENSION PULLEY (HIGH ALTITUDE SPEC.) (WITHOUT WATER SEPARATOR)
TENSION PULLEY (FOR ZIMBABWE)
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (15A)
ALTERNATOR AND MOUNTING (13A) (FOR ZIMBABWE)
ALTERNATOR AND MOUNTING (25A) (HIGH ALTITUDE SPEC.)
STARTING MOTOR AND MOUNTING (5
ALTERNATOR (15A)
ALTERNATOR (13A)
ALTERNATOR (25A) (HIGH ALTITUDE SPEC.)
STARTING MOTOR (5
ENGINE KIT
GASKET KIT
GASKET KIT (HIGH ALTITUDE SPEC.)
