Komatsu Engine 6D125E-2D-5 60721-UP Parts Catalog
Model: Komatsu 6D125E-2D-5 Engine
Serial Number: 60721-UP
Number of Pages: 172 Pages
6D125E-2D-5 S N 60721-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER RELATED PARTS
AIR INTAKE MANIFOLD
HEATER SWITCH
AIR CLEANER
AIR CLEANER (FOR TRIMMING DOZER)
AIR CLEANER (HIGH ALTITUDE SPEC.)
AIR CLEANER CAP (WITH EXTENSION PIPE)
AIR CLEANER CAP
EXHAUST MANIFOLD
EXHAUST MANIFOLD (WITH SAFETY COVER)
TURBOCHARGER OIL PIPING (HIGH ALTITUDE SPEC.)
TURBOCHARGER (HIGH ALTITUDE SPEC.) (INNER PARTS)
MUFFLER (SILVER EXHAUST PIPE¤ 1013MM)
MUFFLER (SILVER EXHAUST PIPE¤ 1013MM) (WITH RAIN CAP)
MUFFLER (EXHAUST PIPE¤ 502
MUFFLER (SILVER EXHAUST PIPE¤ 1013MM) (WITH SAFETY COVER)
MUFFLER (SILVER EXHAUST PIPE¤ 1013MM) (WITH SAFETY COVER) (WITH RAIN CAP)
MUFFLER (EXHAUST PIPE¤ 502 (1)
MUFFLER
MUFFLER (1)
THERMOSTAT HOUSING
BLIND PLUG (WITHOUT WATER TEMPERATURE SENSOR)
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
CYLINDER BLOCK BLIND COVER AND PLUG
FRONT COVER
FRONT COVER MOUNTING
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER MOUNTING PARTS
WATER DRAIN VALVE
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP DRIVE
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
COOLING FAN (REVERSIBLE FAN)
FAN PULLEY (NON HARDENING PULLEY) (NOISE SUPPRESSION SPEC.) (FOR 13A ALTERNATOR)
FAN PULLEY (HARDENING PULLEY) (SANDY AND DUSTY SPEC.) (FOR 35A ALTERNATOR)
FAN PULLEY (NON HARDENING PULLEY) (FOR 35A ALTERNATOR)
FAN DRIVE
CORROSION RESISTOR
ALTERNATOR MOUNTING (35A) (WITH NON HARDENING PULLEY) (COLD TERRAIN (A) SPEC.)
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY) (SANDY AND DUSTY SPEC.)
ALTERNATOR MOUNTING (35A) (WITH NON HARDENING PULLEY) (WITH SAFETY COVER)
ALTERNATOR MOUNTING (35A) (WITH HARDENING PULLEY) (WITH SAFETY COVER) (SANDY AND DUSTY SPEC.)
ALTERNATOR (35A) (WITH NON HARDENING PULLEY) (COLD TERRAIN (A) SPEC.) (INNER PARTS)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (SANDY AND DUSTY SPEC.) (INNER PARTS)
ALTERNATOR (35A) (WITH NON HARDENING PULLEY) (WITH SAFETY COVER) (INNER PARTS)
ALTERNATOR (35A) (WITH HARDENING PULLEY) (WITH SAFETY COVER) (SANDY AND DUSTY SPEC.) (INNER PARTS)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (7.5KW) (ANTI-CORROSIVE TYPE) (TRIMMING SPEC.)
STARTING MOTOR (7
STARTING MOTOR (7.5KW) (ANTI-CORROSIVE TYPE) (TRIMMING SPEC.) (INNER PARTS)
STARTING MOTOR (7 (1)
STARTING MOTOR (7 (2)
SAFETY GUARD (FOR FUEL INJECTION PUMP DRIVE)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
SPARE PARTS (NOISE SUPPRESSION SPEC.)
SPARE PARTS (FOR 35A ALTERNATOR)
HEATER SIGNAL
NAME PLATE AND AIR CLEANER CAUTION (JAPANESE-ENGLISH)
NAME PLATE AND AIR CLEANER CAUTION (ENGLISH)
NAME PLATE AND AIR CLEANER CAUTION (CHINESE)
NAME PLATE AND AIR CLEANER CAUTION (GERMAN)
NAME PLATE AND AIR CLEANER CAUTION (FRENCH)
NAME PLATE AND AIR CLEANER CAUTION (INDONESIAN)
NAME PLATE AND AIR CLEANER CAUTION (SPANISH)
NAME PLATE AND CAUTION
EXHAUST PIPE (502
EXHAUST PIPE (SILVER EXHAUST PIPE¤ 1013MM)
CAUTION PLATE (CHINESE)
CAUTION PLATE (GERMAN)
CAUTION PLATE (ENGLISH)
CAUTION PLATE (FRENCH)
CAUTION PLATE (INDONESIAN)
CAUTION PLATE (SPANISH)
EXHAUST PIPE (SILVER EXHAUST PIPE¤ 1013MM) (WITH RAIN CAP)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
HEATER SWITCH
AIR CLEANER
AIR CLEANER CAP
EXHAUST MANIFOLD
MUFFLER
MUFFLER (1)
THERMOSTAT HOUSING
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
WATER DRAIN VALVE
FUEL FILTER
WATER SEPARATOR
INJECTION NOZZLE
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
FAN DRIVE
CORROSION RESISTOR
STARTING MOTOR (7
HEATER SIGNAL
EXHAUST PIPE (502
- KOMATSU Fault Codes
