Komatsu Engine 6D125-1AB-N 47990-UP Parts Catalog
Model: Komatsu 6D125-1AB-N Engine
Serial Number: 47990-UP
Number of Pages: 152 Pages
6D125-1AB-N S N 47990-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE
AIR INTAKE (HIGH ALTITUDE SPEC.)
AIR CLEANER (WITH SCREEN CAP)
AIR CLEANER (HIGH ALTITUDE SPEC.)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (HIGH ALTITUDE SPEC.)
TURBOCHARGER OIL PIPING (HIGH ALTITUDE SPEC.)
TURBOCHARGER (HIGH ALTITUDE SPEC.) (INNER PARTS)
MUFFLER
MUFFLER (HIGH ALTITUDE SPEC.)
WATER MANIFOLD
THERMOSTAT HOUSING
WATER TEMPERATURE SENSOR
CYLINDER BLOCK
CYLINDER BLOCK (HIGH ALTITUDE SPEC.)
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (NON HARDENING PULLEY)
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER (3-ELEMENT TYPE)
WATER DRAIN VALVE
FUEL INJECTION PUMP MOUNTING (WITH MECHANICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (WITH ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP MOUNTING (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR)
FUEL INJECTION PUMP (PUMP) (1 2) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (1 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (HIGH ALTITUDE SPEC.) (WITH MECHANICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (HIGH ALTITUDE SPEC.) (WITH ELECTRICAL GOVERNOR) (INNER PARTS)
FUEL INJECTION PUMP PIPING (HIGH ALTITUDE SPEC.)
FUEL FILTER
WATER SEPARATOR MOUNTING
INJECTION NOZZLE
NOZZLE HOLDER (INNER PARTS)
FUEL RETURN
STOP MOTOR
WATER PUMP
COOLING FAN
COOLING FAN (NOISE SUPRESSION SEPC. FOR EC)
FAN PULLEY
FAN DRIVE
CORROSION RESISTOR
ALTERNATOR MOUNTING (35A)
ALTERNATOR MOUNTING (50A)
HEATER SWITCH
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR (INNER PARTS)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
AIR COMPRESSOR GASKET KIT
SPARE PARTS
NAME PLATE AND CAUTION (ARABIC)
NAME PLATE AND CAUTION (PERSIAN)
NAME PLATE AND CAUTION (CHINESE)
NAME PLATE AND CAUTION (GERMAN)
NAME PLATE AND CAUTION (FRENCH)
NAME PLATE AND CAUTION (GREEK)
NAME PLATE AND CAUTION (ITALIAN)
NAME PLATE AND CAUTION (PORTUGUESE)
NAME PLATE AND CAUTION (INDONESIAN)
NAME PLATE AND CAUTION (SPANISH)
NAME PLATE AND CAUTION (ENGLISH)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE
EXHAUST MANIFOLD
MUFFLER
WATER MANIFOLD
THERMOSTAT HOUSING
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
CAMSHAFT
OIL PUMP
OIL FILTER
OIL ADAPTER
WATER DRAIN VALVE
FUEL FILTER
INJECTION NOZZLE
FUEL RETURN
STOP MOTOR
WATER PUMP
COOLING FAN
FAN PULLEY
FAN DRIVE
CORROSION RESISTOR
HEATER SWITCH
SPARE PARTS
- KOMATSU Fault Codes
