Komatsu Engine 4D94-2N 12336-UP Parts Catalog
Model: Komatsu 4D94-2N Engine
Serial Number: 12336-UP
Number of Pages: 83 Pages
4D94-2N S N 12336-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
AIR INTAKE MANIFOLD
EXHAUST MANIFOLD
AIR CLEANER
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK (1)
FRONT COVER AND PLATE
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT AND IDLER GEAR
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
ENGINE SUPPORT
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL STRAINER
LUBRICATING OIL FILTER
LUBRICATING OIL COOLER
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
FUEL FILTER AND MOUNTING
WATER SEPARATOR
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (FEED PUMP)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
WATER PUMP AND COOLING FAN (SANDY AND DUSTY SPEC.) (TRIMMING SPEC.)
ALTERNATOR AND MOUNTING
STARTING MOTOR AND MOUNTING (3
STARTING MOTOR RELAY AND SIGNAL
ALTERNATOR (25A) (WITH NON HARDENING PULLEY)
ALTERNATOR (13A) (WITH NON HARDENING PULLEY) (TRICAL¤ SANDY AND DUSTY SPEC.)
ALTERNATOR (13A) (WITH NON HARDENING PULLEY) (TRIMMING SPEC.)
STARTING MOTOR (3
STARTING MOTOR (3 (1)
STARTING MOTOR (3 (2)
STARTING MOTOR (3 (3)
STARTING MOTOR (3.5KW) (TRIMMING SPEC.)
TOOL AND KIT
GASKET KIT
