Komatsu Engine 4D130-1C-A 10544-UP Parts Catalog
Model: Komatsu 4D130-1C-A Engine
Serial Number: 10544-UP
Number of Pages: 72 Pages
4D130-1C-A S N 10544-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
AIR INTAKE MANIFOLD AND AIR CLEANER
EXHAUST MANIFOLD AND MUFFLER
WATER MANIFOLD AND THERMOSTAT
CYLINDER BLOCK
CYLINDER BLOCK (1 2)
CYLINDER BLOCK (2 2)
GEAR CASE COVER AND FRONT SUPPORT
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
BALANCER
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP
LUBRICATING OIL STRAINER
LUBRICATING OIL FILTER
LUBRICATING OIL COOLER
FUEL SYSTEM
FUEL INJECTION PUMP AND MOUNTING
FUEL INJECTION PIPING
FUEL FILTER AND MOUNTING
WATER SEPARATOR AND MOUNTING
WATER SEPARATOR
FUEL INJECTION PUMP LUBRICATING OIL PIPING
FUEL INJECTION PUMP (PUMP)
FUEL INJECTION PUMP (GOVERNOR)
FUEL INJECTION PUMP (FEED PUMP)
FUEL INJECTION PUMP (COUPLING)
COOLING AND ELECTRICAL SYSTEMS
WATER PUMP AND COOLING FAN
CORROSION RESISTOR
ALTERNATOR AND MOUNTING (13A)
ALTERNATOR AND MOUNTING (35A)
STATING MOTOR AND MOUNTING
SAFETY RELAY AND STARTING MOTOR RELAY
ALTERNATOR (13A)
ALTERNATOR (35A)
STARTING MOTOR (5
STARTING MOTOR (5 (1)
OPTIONAL PARTS
AIR INTAKE MANIFOLD AND CONNECTION (SANDY AND DUSTY SPEC.)
AIR CLEANER (SANDY AND DUSTY SPEC.)
TOOL AND KIT
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
CYLINDER BLOCK
OIL PAN
CRANKSHAFT
CAMSHAFT AND TAPPET
BALANCER
FUEL SYSTEM
WATER SEPARATOR
CORROSION RESISTOR
ALTERNATOR (13A)
ALTERNATOR (35A)
STARTING MOTOR (5
OPTIONAL PARTS
TOOL AND KIT
GASKET KIT
- KOMATSU Fault Codes
