Auto47
Manager
48
27,774
Komatsu Dump Trucks 730E-8 SN A40002 HAILE GOLD MINE Parts Catalog
Type of Machine: Dump Truck
Model: Komatsu AFE69-A 730E-8 SN A40002 HAILE GOLD MINE Dump Truck
Number of Pages: 949 Pages
AFE69-A KOMATSU MINING
FRAME & DECK GROUP
DECALS & WARNINGS 1 4
DECALS & WARNINGS 3 4
DECALS & WARNINGS 4 4
FRAME & UPRIGHTS
ENGINE ACCESS LADDERS
DIAGONAL LADDER INSTALLATION
RH LADDER INSTALLATION
LH LADDER INSTALLATION
RH PLATFORM & LADDER INSTALLATION
LH PLATFORM & HANDRAIL INSTALLATION
LH PLATFORM STEPS
LH DECK INSTALLATION
RH DECK INSTALLATION
CENTER DECK INSTALLATION
LH DECK HANDRAILS
RH DECK HANDRAILS
RETARDING GRID HANDRAILS
REAR DECK HANDRAILS
GRILLE HANDRAIL
LH LADDER HANDRAILS
RH & DIAGONAL LADDER HANDRAILS
RH MIRROR INSTALLATION
LH MIRROR INSTALLATION
LH DECK MUD FLAPS
RH DECK MUD FLAPS
FRONT PROTECTIVE COVERS & MUD FLAPS
LH DECK COVERS
LH DECK HYDRAULIC HOSE SHIELDS
CENTER DECK HEAT SHIELDS
COOLING SYSTEM
RADIATOR INSTALLATION
RADIATOR & SHROUD ASSEMBLY 1 2 58D-03-10100
RADIATOR & SHROUD ASSEMBLY 1 2 58D-03-10100 (1)
RADIATOR & SHROUD ASSEMBLY 2 2 58D-03-10100
RADIATOR, WATER JACKET (HTC) 58D-03-10040
RADIATOR, AFTERCOOLER (LTC) 58D-03-10050
RADIATOR, WATER JACKET (HTC) 58D-03-10040 (1)
RADIATOR, AFTERCOOLER (LTC) 58D-03-10050 (1)
RADIATOR PIPING 1 3
RADIATOR PIPING 3 3
FAN & FAN DRIVE
ENGINE GROUP
AIR CLEANER PIPING & INSTALLATION 1 2
AIR CLEANER PC2559
AIR CLEANER PC2559 (1)
AIR CLEANER RESTRICTION GAUGE PIPING
ALTERNATOR ASSEMBLY PC3000
ENGINE CRADLE INSTALLATION
ENGINE SUB-FRAME MOUNTS
ENGINE COMPONENTS
BATTERY CHARGING ALTERNATOR
A C COMPRESSOR INSTALLATION
EXHAUST PIPING
FRONT WHEEL & BRAKE GROUP
SPINDLE, HUB AND BRAKE ASSEMBLY XB4145
FRONT DISC BRAKE ASSEMBLY PC3084
FRONT WHEEL SPEED SENSOR INSTALLATION
FRONT WHEEL & MOUNTING
RIM ASSEMBLY
RIM ASSEMBLY (1)
FRONT SUSPENSION INSTALLATION
FRONT SUSPENSION ASSEMBLY 58D-50-00000
FRONT SUSPENSION ASSEMBLY 58D-50-00000 (1)
REAR WHEEL & BRAKE GROUP
REAR BRAKE INSTALLATION
REAR DISC BRAKE ASSEMBLY PC3085
REAR DISC BRAKE ASSEMBLY PC3085 (1)
WHEEL MOTOR INSTALLATION
WHEEL MOTOR PIPING
REAR AXLE INSTALLATION
ANTI-SWAY BAR INSTALLATION
REAR HATCH COVER
REAR AXLE ACCESS LADDER
DRIVE AXLE BLOWER HOSE
REAR WHEELS & MOUNTING
RIM ASSEMBLY (2)
REAR SUSPENSION INSTALLATION
REAR SUSPENSION ASSEMBLY 58D-50-00060
REAR SUSPENSION ASSEMBLY 58D-50-00060 (1)
STEERING SYSTEM
STEERING CONTROL UNIT INSTALLATION
STEERING CONTROL UNIT PB6905
STEERING ARMS INSTALLATION
STEERING CYLINDER INSTALLATION
STEERING CYLINDER AND BEARINGS
TIE ROD INSTALLATION
TIE ROD ASSEMBLY 58D-40-00060
TIE ROD ASSEMBLY 58D-40-00060 (1)
TIE ROD STEERING CYLINDER LUBRICATION LINES
CAB GROUP
CAB MOUNTING
CAB INSULATION
CAB CARPET 1 2
CAB CARPET 2 2
DOOR ASSEMBLY - LH 58E-54-10080
DOOR PANEL ASSEMBLY - LH 58E-54-10120
DOOR ASSEMBLY - RH 58E-54-10090
DOOR PANEL ASSEMBLY - RH 58E-54-10110
DOOR ASSEMBLY - LH 58E-54-10080 (1)
DOOR PANEL ASSEMBLY - LH 58E-54-10120 (1)
DOOR PANEL ASSEMBLY - LH 58E-54-10120 (2)
DOOR ASSEMBLY - RH 58E-54-10090 (1)
DOOR PANEL ASSEMBLY - RH 58E-54-10110 (1)
DOOR PANEL ASSEMBLY - RH 58E-54-10110 (2)
CAB WINDOWS
FRONT ACCESS COVER
CAB ACCESS COVERS
CAB LIGHTS
OPERATOR SEAT INSTALLATION
OPERATOR SEAT INSTALLATION (1)
SEAT ASSEMBLY 1 2 58E-57-00501
SEAT ASSEMBLY 1 2 58E-57-00501 (1)
SEAT ASSEMBLY 2 2 58E-57-00501
PASSENGER SEAT INSTALLATION
PASSENGER SEAT ASSM 1 2 PC2550
PASSENGER SEAT ASSM 1 2 PC2550 (1)
PASSENGER SEAT ASSM 2 2 PC2550
FOOTREST AND FLOOR MATS
MANUAL HOLDER
CUP HOLDER
VISOR INSTALLATION
OVERHEAD DASH MODULE
RADIO MODULE
AIR CLEANER RESTRICTION GAUGE MODULE
RADIO MODULE (1)
RADIO ANTENNA INSTALLATION
AIR CLEANER RESTRICTION GAUGE MODULE (1)
REAR SPEAKER INSTALLATION
ORBCOMM INSTALLATION
INSTRUMENT PANEL ASSEMBLY XC4088
GAUGE PANEL
UPPER RH DASH MODULE
LOWER RH DASH MODULE
LOWER RH DASH MODULE (1)
LOWER RH DASH MODULE (2)
LOWER LH DASH MODULE
GAUGE PANEL (1)
UPPER RH DASH MODULE (1)
LOWER RH DASH MODULE (3)
LOWER LH DASH MODULE (1)
PEDAL INSTALLATION
ELECTRONIC TREADLE PB9506
BRAKE VALVE PEDAL ASSEMBLY 58D-61-90000
ELECTRONIC TREADLE PB9506 (1)
STEERING COLUMN INSTALLATION
STEERING COLUMN XB8878
ARSC SWITCH EM7647
STEERING COLUMN XB8878 (1)
ARSC SWITCH EM7647 (1)
CENTER CONSOLE MODULE
A C SYSTEM PIPING & INSTALLATION 1 2
A C SYSTEM PIPING & INSTALLATION 1 2 (1)
A C SYSTEM PIPING & INSTALLATION 1 2 (2)
A C SYSTEM PIPING & INSTALLATION 2 2
HVAC INSTALLATION 2 2
HEATER AIR CONDITIONER ASSM 1 2 58F-07-00030
CONTROL PANEL SWITCH EL5676
HVAC VENTS
HEATER AIR CONDITIONER ASSM 1 2 58F-07-00030 (1)
CONTROL PANEL SWITCH EL5676 (1)
HEATER AIR CONDITIONER ASSM 2 2 58F-07-00030
CONTROL PANEL SWITCH EL5676 (2)
HEATER AIR CONDITIONER DASH MODULE
HEATER HOSE INSTALLATION
HEATER AC DRAIN HOSE INSTALLATION
WINDSHIELD WIPER WASHER INSTALLATION
WIPER LINKAGE ASSEMBLY PB9926
WIPER LINKAGE ASSEMBLY PB9926 (1)
WINDSHIELD WASHER INSTALLATION
BODY GROUP
BODY PIVOT
BODY GUIDE AND PADS
BODY MUD FLAPS 1 2
BODY MUD FLAPS 2 2
ROCK EJECTORS INSTALLATION
BODY SLING
DUMP BODY OPTIONS
ELECTRIC POWER COMPONENTS & WIRING GROUP
CONTROL CABINET INSTALLATION
CONTROL CABINET 1 6
AFSE PANEL 58B-43-00220
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480
RELAY - CPR & GFR VG7043
ICP PANEL 58D-98-01760
ICP PANEL 58D-98-01760 (1)
DIODE HEAT SINK ASSEMBLY GE0558
BLOWER INLET DUCT WORK INSTALLATION
BLOWER INLET HEAT FLAP INSTALLATION
BLOWER PRESSURE SWITCH
WHEEL MOTOR WIRING 1 3
WHEEL MOTOR WIRING 2 3
WHEEL MOTOR WIRING 3 3
ALTERNATOR WIRING 2 2
FUEL SYSTEM
FUEL TANK MOUNTING
FUEL TANK ASSEMBLY
FUEL TANK ASSEMBLY (1)
FUEL TANK QUICK FILL - RH
FUEL TANK QUICK FILL - LH
FUEL SYSTEM PIPING 1 2
FUEL SYSTEM PIPING 2 2
FUEL TANK GUAGE & WIRING
FUEL TANK MUD FLAPS 1 2
FUEL TANK MUD FLAPS 2 2
ELECTRICAL SYSTEM
BATTERY BOX 1 6
BATTERY BOX 2 6
BATTERY BOX 3 6
BATTERY BOX 4 6
BATTERY BOX 5 6
BATTERY BOX 6 6
BATTERY BOX EXTERNAL WIRING
ISOLATION BOX EXTERNAL WIRING 1 2
ISOLATION BOX EXTERNAL WIRING 2 2
ISOLATION BOX 1 3 58F-06-40110
ISOLATION BOX 1 3 58F-06-40110 (1)
ISOLATION BOX 2 3 58F-06-40110
ISOLATION BOX 3 3 58F-06-40110
EMERGENCY SHUTDOWN SWITCH INSTALLATION
STARTING SYSTEM WIRING 1 3
STARTING SYSTEM WIRING 2 3
STARTING SYSTEM WIRING 3 3
ALTERNATOR WIRING
COOLANT LEVEL SWITCH INSTALLATION
FUEL FILTER HARNESS INSTALLATION
GROUND WIRES
HEADLIGHTS FOG LIGHTS
PLM LIGHT ASSEMBLY
HORN INSTALLATION
RH DECK LIGHTS & WIRING
PLM LIGHT ASSEMBLY (1)
PLM LIGHT ASSEMBLY (2)
MIRROR MOUNTED FLOOD LIGHTS
LIGHT ASSEMBLY (SUPER HALOGEN) 2 2
BUMPER MOUNTED HEADLIGHTS
BUMPER MOUNTED HEADLIGHTS (1)
LIGHT ASSEMBLY (SUPER HALOGEN) 1 2
LIGHT ASSEMBLY (HID)
LADDER LIGHT SWITCH INSTALLATION
LADDER LIGHT 1 2
LADDER LIGHT 2 2
LIGHT ASSEMBLY (SUPER HALOGEN) 2 2 (1)
ENGINE SERVICE LIGHTS
LIGHT ASSEMBLY (SUPER HALOGEN) 2 2 (2)
LIGHT ASSEMBLY (SUPER HALOGEN) 1 2 (1)
LIGHT ASSEMBLY (SUPER HALOGEN) 2 2 (3)
LIGHT ASSEMBLY (HID) (1)
REAR AXLE LIGHTS & BACKUP ALARMS
REAR AXLE WIRING
REAR AXLE SERVICE LIGHT
REAR TURN & CLEARANCE LIGHTS
HOIST LIMIT BODY UP SWITCHES
BLEEDDOWN MANIFOLD WIRING
HYDRAULIC CABINET WIRING
ACCESSORY DRIVE WIRING
PLM SENSOR - FRONT SUSPENSIONS
PLM SENSOR - REAR SUSPENSIONS
REAR JUNCTION BOX INSTALLATION & WIRING
JUNCTION BOX ASSEMBLY - REAR XC2982
JUNCTION BOX ASSEMBLY - REAR XC2982 (1)
RH JUNCTION BOX INSTALLATION & WIRING
JUNCTION BOX ASSEMBLY - RH XB8637
LH JUNCTION BOX INSTALLATION & WIRING
JUNCTION BOX ASSEMBLY - LH XB8597
JUNCTION BOX ASSEMBLY - RH XB8637 (1)
JUNCTION BOX ASSEMBLY - LH XB8597 (1)
DID PANEL INSTALLATION
WINDOW SWITCH WIRING
WIPER WASHER DELAY TIMER MODULES
MISCELLANEOUS CAB ELECTRICAL
TERMINAL BOARD VS8192
CAB HARNESSES & CONNECTOR PLATE
AUXILIARY CONTROL CABINET EXTERNAL WIRING 1 4
AUXILIARY CONTROL CABINET EXTERNAL WIRING 2 4
AUXILIARY CONTROL CABINET EXTERNAL WIRING 3 4
AUXILIARY CONTROL CABINET STRUCTURE 1 2
AUXILIARY CONTROL CABINET INSTALLATION
AUXILIARY CONTROL CABINET STRUCTURE 2 2
AUXILIARY CONTROL CABINET - LH WALL
RELAY BOARD EK4991
AUXILIARY CONTROL CABINET - REAR WALL
RELAY BOARD EK4991 (1)
TERMINAL BOARD VS8192 (1)
AUXILIARY CONTROL CABINET INTERNAL WIRING 1 2
HYDRAULIC SYSTEM
HYDRAULIC TANK INSTALLATION
HYDRAULIC TANK ASSEMBLY
HYDRAULIC TANK ASSEMBLY (1)
HYDRAULIC TANK LADDER
HYDRAULIC TANK MUD FLAPS
HYDRAULIC TANK PIPING - STEERING, HOIST & BRAKE
PUMP MODULE INSTALLATION
DRIVE SHAFT INSTALLATION
DRIVE SHAFT INSTALLATION (1)
DRIVE SHAFT GUARD
PUMP MODULE PIPING 1 3
PUMP MODULE PIPING 2 3
PUMP MODULE PIPING 3 3
PUMP MODULE 1 3
HOIST CONTROL VALVE ASSEMBLY PB8267
SPOOL INLET SECTION VE7624
RELIEF VALVE ASSEMBLY VE3567
OVERCENTER MANIFOLD VALVE ASSM PC0522
PUMP MODULE 2 3
PUMP MODULE 3 3
PUMP MODULE - HOIST PUMP INSTALLATION
PUMP MODULE - STEERING PUMP INSTALLATION
HOIST CONTROL VALVE ASSEMBLY PB8267 (1)
SPOOL INLET SECTION VE7624 (1)
RELIEF VALVE ASSEMBLY VE3567 (1)
SPOOL INLET SECTION VE7624 (2)
RELIEF VALVE ASSEMBLY VE3567 (2)
OVERCENTER MANIFOLD VALVE ASSM PC0522 (1)
HOIST FILTER INSTALLATION
HYDRAULIC FILTER - HOIST XB3937
HYDRAULIC FILTER - HOIST XB3937 (1)
STEERING FILTER INSTALLATION
HYDRAULIC FILTER - STEERING XB3938
HYDRAULIC FILTER - STEERING XB3938 (1)
FRONT BRAKE PIPING 1 2
FRONT BRAKE PIPING 2 2
CAB PIPING 1 2
CAB PIPING 2 2
BRAKE VALVE PIPING
BRAKE VALVE INSTALLATION
BRAKE VALVE PEDAL ASSEMBLY 58D-61-90000 (1)
BRAKE VALVE PEDAL ASSEMBLY 58D-61-90000 (2)
STEERING CONTROL UNIT PIPING
STEERING CONTROL UNIT PB6905 (1)
HYDRAULIC BRAKE CABINET MOUNTING
HYDRAULIC BRAKE CABINET 1 6
HYDRAULIC BRAKE CABINET 2 6
HYDRAULIC BRAKE CABINET 3 6
ACCUMULATOR ASSEMBLY (2
HYDRAULIC BRAKE CABINET 4 6
BRAKE MANIFOLD PC2915
HYDRAULIC BRAKE CABINET 5 6
HYDRAULIC BRAKE CABINET 6 6
HOIST PILOT VALVE ASSEMBLY PB6922
HOIST PILOT MANIFOLD 58D-60-80000
ACCUMULATOR ASSEMBLY (2 (1)
BRAKE MANIFOLD PC2915 (1)
HOIST PILOT VALVE ASSEMBLY PB6922 (1)
HOIST PILOT MANIFOLD 58D-60-80000 (1)
BRAKE CABINET HOSE ROUTING
HOIST CYLINDER INSTALLATION
HOIST CYLINDER ASSEMBLY XB4508
HOIST CYLINDER ASSEMBLY XB4508 (1)
HOIST CYLINDER PIPING
REAR BRAKE PIPING 1 3
REAR BRAKE PIPING 2 3
REAR BRAKE PIPING 3 3
REAR DISC & PARKING BRAKE PIPING
BLEEDDOWN MANIFOLD PIPING 1 2
BLEEDDOWN MANIFOLD PIPING 2 2
BLEEDDOWN MANIFOLD INSTALLATION
BLEEDDOWN MANIFOLD PC3014
BLEEDDOWN MANIFOLD PC3014 (1)
FLOW AMPLIFIER INSTALLATION & PIPING 1 2
FLOW AMPLIFIER INSTALLATION & PIPING 2 2
STEERING CYLINDER PIPING
STEERING CYLINDER AND BEARINGS (1)
STEERING CYLINDER AND BEARINGS (2)
STEERING ACCUMULATOR INSTALLATION
STEERING ACCUMULATOR ASSEMBLY PC2040
STEERING ACCUMULATOR ASSEMBLY PC2040 (1)
ACCESSORY DRIVE PIPING 1 2
ACCESSORY DRIVE PIPING 2 2
ACCUMULATOR ASSEMBLY (2 (2)
OPTIONS & MISCELLANEOUS GROUP
AUTOMATIC LUBRICATION - PUMP INSTALLATION
LUBE PUMP CONTAINER ASSEMBLY 58F-60-00470
LUBE PUMP ASSEMBLY (SERIES B) XA4126
VENT VALVE ASSEMBLY LA0912
CHECK VALVE ASSEMBLY LA1187
AUTO LUBE FILTER ASSEMBLY PC0811
AUTOMATIC LUBRICATION - PUMP PIPING
AUTOMATIC LUBRICATION - STEERING CYLINDERS
AUTOMATIC LUBRICATION - FRONT INJECTORS
AUTOMATIC LUBRICATION - FRONT BRAKE MANIFOLDS
AUTOMATIC LUBRICATION - HYD TANK & HOSE JOINT
AUTOMATIC LUBRICATION - ACCESSORY DRIVE MANIFOLD
LUBE PUMP CONTAINER ASSEMBLY 58F-60-00470 (1)
LUBE PUMP ASSEMBLY (SERIES B) XA4126 (1)
VENT VALVE ASSEMBLY LA0912 (1)
CHECK VALVE ASSEMBLY LA1187 (1)
LUBE PUMP ASSEMBLY (SERIES B) XA4126 (2)
VENT VALVE ASSEMBLY LA0912 (2)
CHECK VALVE ASSEMBLY LA1187 (2)
AUTO LUBE FILTER ASSEMBLY PC0811 (1)
AUTOMATIC LUBRICATION - REAR INJECTORS
AUTOMATIC LUBRICATION - REAR INJECTOR HOSES
AUTOMATIC LUBRICATION - REAR SUSPENSIONS
AUTOMATIC LUBRICATION - ANTI-SWAY BAR
AUTOMATIC LUBRICATION - HOIST CYLINDERS
AUTOMATIC LUBRICATION - REAR AXLE & PIVOT
AUTOMATIC LUBRICATION - BODY PIVOT
CHARGING MANIFOLD ASSEMBLY EB1759
TOOL GROUP 1 2
TOOL GROUP 2 2
SERVICE CENTER - LH
SERVICE CENTER - FILL STATION
HUBODOMETER INSTALLATION
FIRE EXTINGUISHER
PLM SCOREBOARD
CONTROL GROUP
CONTROL CABINET 1 6 (1)
AFSE PANEL 58B-43-00220 (1)
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (1)
RELAY - CPR & GFR VG7043 (1)
RECTIFIER PANEL GE0557
DIODE HEAT SINK ASSEMBLY GE0558 (1)
CONTROL CABINET 2 6
CONTACTOR - GF & GFR VE1317
POSITION SENSOR INTERLOCK VE3530
CONTROL CABINET 4 6
RECTIFIER PANEL GE0557 (1)
DIODE HEAT SINK ASSEMBLY GE0558 (2)
CONTROL CABINET 5 6
CONTROL CABINET 6 6
DOORS AND COVERS 1 2
DOORS AND COVERS 2 2
AFSE PANEL 58B-43-00220 (2)
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (2)
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (3)
AFSE PANEL COVER ASSEMBLY 2 2 58B-43-00480
RELAY - CPR & GFR VG7043 (2)
ICP PANEL 58D-98-01760 (2)
ICP PANEL 58D-98-01760 (3)
POSITION SENSOR INTERLOCK VE3530 (1)
RECTIFIER PANEL GE0557 (2)
DIODE HEAT SINK ASSEMBLY GE0558 (3)
DIODE HEAT SINK ASSEMBLY GE0558 (4)
TERMINAL BOARD VS6690
ALTERNATOR GROUP
ALTERNATOR ASSEMBLY PC3000 (1)
ALTERNATOR - ENGINE MOUNT 1 4
ROTOR ASSEMBLY 58D-98-01960
ALTERNATOR - BRUSH HOLDER ASSM VJ1024
ALTERNATOR - ENGINE MOUNT 2 4
ALTERNATOR - ENGINE MOUNT 3 4
ALTERNATOR - ENGINE MOUNT 4 4
ALTERNATOR - STATOR ASSEMBLY
ALTERNATOR - TERTIARY CONNECTION
ROTOR ASSEMBLY 58D-98-01960 (1)
ALTERNATOR - FIELD CONNECTOR (BRUSH HOLDER) 1 2
ALTERNATOR - FIELD CONNECTOR (BRUSH HOLDER) 2 2
ALTERNATOR - BRUSH HOLDER ASSM VJ1024 (1)
RETARDER GRID GROUP
RETARDING GRID INSTALLATION
RETARDING GRID 1 6 PC3119
RETARDING GRID HARNESS ROUTING
RETARDING GRID 1 6 PC3119 (1)
RETARDING GRID 2 6 PC3119
RETARDING GRID 3 6 PC3119
RETARDING GRID 4 6 PC3119
RETARDING GRID BLOWER MOTOR 1 5 XA4558
RETARDING GRID 5 6 PC3119
RETARDING GRID BLOWER MOTOR 1 5 XA4558 (1)
RETARDING GRID 6 6 PC3119
RETARDING GRID BLOWER MOTOR 1 5 XA4558 (2)
RETARDING GRID BLOWER MOTOR 2 5 XA4558
RETARDING GRID BLOWER MOTOR 3 5 XA4558
RETARDING GRID BLOWER MOTOR 4 5 XA4558
BRUSH HOLDER ASSEMBLY VS8587
RETARDING GRID BLOWER MOTOR 5 5 XA4558
BRUSH HOLDER ASSEMBLY VS8587 (1)
WHEEL MOTOR GROUP
WHEEL MOTOR PC3017 1 8
WHEEL MOTOR PC3017 2 8
WHEEL MOTOR PC3017 3 8
WHEEL MOTOR PC3017 4 8
WHEEL MOTOR PC3017 5 8
WHEEL MOTOR PC3017 6 8
ROTOR ASSEMBLY XA5788
WHEEL MOTOR PC3017 7 8
WHEEL MOTOR PC3017 8 8
ROTOR ASSEMBLY XA5788 (1)
Komatsu, Dump Truck, s AFE69-A 730E-8 SN A40002 HAILE GOLD MINE, Parts Catalog,
