Komatsu Dump Trucks 730E-10 A50002 - A50004 A50007 - A50019 OCEANA GOLD Parts Catalog
Komatsu Dump Trucks AFE84-A 730E-10 A50002 - A50004 A50007 - A50019 OCEANA GOLD Parts Catalog
Type of Machine: Dump Truck
Model: Komatsu AFE84-A 730E-10 SN A50002 - A50004, A50007 - A50019 OCEANA GOLD Dump Truck
Number of Pages: 1065 Pages
AFE84-A KOMATSU MINING
ENGINE & RELATED PARTS
FAN GUARD INSTALLATION
FAN INSTALLATION
FAN DRIVE SYSTEM
AIR CLEANER PIPING & INSTALLATION - LH
AIR CLEANER 58D-02-01570
AIR CLEANER PIPING & INSTALLATION - RH
AIR CLEANER 58D-02-01570 (1)
AIR CLEANER 58D-02-01570 (2)
ALTERNATOR ASSEMBLY 58D-06-20011
ENGINE AND COMPONENTS
ENGINE SUBFRAME MOUNTS
ENGINE SUB-FRAME INSTALLATION
ENGINE CRADLE INSTALLATION
EXHAUST PIPING -DUAL WALL
EXHAUST BLANKETS
SELECTIVE CATALYTIC REDUCTION (SCR) ASSEMBLIES
COOLING SYSTEM
RADIATOR INSTALLATION - UPPER
RADIATOR INSTALLATION - LOWER
RADIATOR & SHROUD ASSEMBLY
RADIATOR & SHROUD ASSEMBLY 1 2 58D-03-10100
RADIATOR & SHROUD ASSEMBLY 1 2 58D-03-10100 (1)
RADIATOR & SHROUD ASSEMBLY 2 2 58D-03-10100
LOW TEMPERATURE CORE (LTC) 58D-03-10050
HIGH TEMPERATURE CORE (HTC) 58D-03-10040
LOW TEMPERATURE CORE (LTC) 58D-03-10050 (1)
HIGH TEMPERATURE CORE (HTC) 58D-03-10040 (1)
RADIATOR PIPING 1 3
RADIATOR PIPING 2 3
FUEL TANK & RELATED PARTS
FUEL TANK INSTALLATION
FUEL TANK ASSEMBLY
FUEL TANK ASSEMBLY (1)
FUEL SYSTEM PIPING 1 3
FUEL SYSTEM PIPING 2 3
FUEL SYSTEM PIPING 3 3
FUEL SYSTEM PIPING - ENGINE
FUEL TANK REMOTE FILL - RH
DEF TANK REMOTE FILL - RH
FUEL LEVEL SENDER & WIRING
DEF TANK INSTALLATION AND PIPING 1 2
DEF TANK INSTALLATION AND PIPING 1 2 (1)
DEF TANK 58D-02-03001
DEF TANK 58D-02-03001 (1)
DEF TANK 58D-02-03001 (2)
DEF TANK HOSE CONNECTIONS - BOTTOM
DEF PUMP MODULE
DOSER FLUID SUPPLY MODULE 58F-01-00390
DOSER FLUID SUPPLY MODULE 58F-01-00390 (1)
ELECTRICAL SYSTEM
BATTERY BOX INSTALLATION
BATTERY BOX 1 6
BATTERY BOX 2 6
BATTERY BOX 3 6
BATTERY BOX 4 6
BATTERY BOX 5 6
BATTERY BOX 6 6
ISOLATION BOX INSTALLATION
ISOLATION BOX 1 3 58F-06-05350
ISOLATION BOX 1 3 58F-06-05350 (1)
ISOLATION BOX 2 3 58F-06-05350
ISOLATION BOX 3 3 58F-06-05350
ISOLATION BOX EXTERNAL WIRING 1 2
ISOLATION BOX EXTERNAL WIRING 2 2
GROUND LEVEL ENGINE SHUTDOWN SWITCH
CRANKING MOTOR INSTALLATION
CRANKING MOTOR WIRING
BATTERY CHARGING ALTERNATOR WIRING
EXTERNAL ENGINE WIRING HARNESS INSTALLATION
LH DECK WIRING HARNESS & LIGHTS
HORN INSTALLATION
RH DECK WIRING HARNESS & LIGHTS
PLM LIGHT ASSEMBLY INSTALLATION
PLM LIGHT ASSEMBLY
PLM LIGHT ASSEMBLY (1)
LH ENGINE BAY LIGHTS & SWITCH
RH ENGINE BAY LIGHTS & SWITCH
LADDER LIGHTS
GROUND LEVEL LADDER LIGHTS SWITCH
HEADLIGHT WIRING HARNESS
HEADLIGHTS & FOG LIGHTS
HEADLIGHTS - BUMPER MOUNTED
REAR AXLE HOUSING SERVICE LIGHT
HYDRAULIC BRAKE CABINET INTERNAL WIRING
STEERING ACCUMULATOR PRESSURE SWITCHES
STEERING FILTER PRESSURE SWITCH
HOIST FILTER PRESSURE SWITCH
PUMP MODULE PRESSURE SENSOR & SWITCHES
BLEEDDOWN MANIFOLD PRESSURE SENSOR & SWITCHES
PLM PRESSURE SENSOR - FRONT SUSPENSIONS
PLM PRESSURE SENSOR - REAR SUSPENSIONS
FRONT WHEEL SPEED SENSOR INSTALLATION
FRONT WHEEL SPEED SENSOR WIRING HARNESS
BODY UP & HOIST LIMIT SWITCH INSTALLATION
AUXILIARY CONTROL CABINET POWER CABLES
AUXILIARY CONTROL CABNET EXTERNAL HARNESS
AUXILIARY CONTROL T4 ENGINE HARNESS
AUXILIARY CONTROL CABINET CABLE CONNECTIONS
RIGHT FRONT FRAME RAIL HARNESS
RIGHT REAR FRAME RAIL HARNESSES
LEFT FRONT FRAME RAIL HARNESS
LEFT REAR FRAME RAIL HARNESS
AUXILIARY CONTROL CABINET INSTALLATION
AUXILIARY CONTROL CABINET STRUCTURE 1 2
AUXILIARY CONTROL CABINET STRUCTURE 2 2
AUXILIARY CTRL CABINET COMPONENTS - LH WALL 1 2
AUXILIARY CTRL CABINET COMPONENTS - LH WALL 2 2
AUXILIARY CONTROL CABINET COMPONENTS - RH WALL 1 2
VEHICLE ELECTRICAL CENTER VEC-90 58E-06-20050
VEHICLE ELECTRICAL CENTER VEC-91 58E-06-20061
AUXILIARY CONTROL CABINET COMPONENTS - RH WALL 2 2
VEHICLE ELECTRICAL CENTER VEC-90 58E-06-20050 (1)
VEHICLE ELECTRICAL CENTER VEC-91 58E-06-20061 (1)
AUXILIARY CONTROL CABINET INTERNAL WIRING 1 2
EXHAUST SYSTEM WIRING HARNESS
EXHAUST SYSTEM WIRING HARNESS (1)
DEF SYSTEM WIRING RELAY BOX 58B-06-19022
DEF SYSTEM WIRING RELAY BOX 58B-06-19022 (1)
DRIVE SYSTEM
BLOWER INLET DUCT INSTALLATION
BLOWER INLET HEAT FLAP INSTALLATION
REAR AXLE BLOWER HOSE INSTALLATION
REAR AXLE BLOWER PRESSURE SWITCH INSTALLATION
ALTERNATOR ASSEMBLY 58D-06-20011 (1)
ALTERNATOR - ENGINE MOUNT 1 3
ALTERNATOR ROTOR ASSEMBLY 58D-98-03300
ALTERNATOR - BEARING ASSEMBLY 58D-98-03330
ALTERNATOR - ENGINE MOUNT 2 3
ALTERNATOR - MAIN ELECTRICAL CONNECTION
ALTERNATOR - TERTIARY CONNECTION
ALTERNATOR ROTOR ASSEMBLY 58D-98-03300 (1)
ALTERNATOR - BEARING ASSEMBLY 58D-98-03330 (1)
ALTERNATOR - BEARING ASSEMBLY 58D-98-03330 (2)
ALTERNATOR - FIELD CONNECTOR (BRUSH HOLDER) 1 3
ALTERNATOR - FIELD CONNECTOR (BRUSH HOLDER) 2 3
ALTERNATOR - FIELD CONNECTOR (BRUSH HOLDER) 3 3
CONTROL CABINET EXTERNAL WIRING 1 3
CONTROL CABINET EXTERNAL WIRING 1 3 (1)
CONTROL CABINET EXTERNAL WIRING 1 3 (2)
CONTROL CABINET EXTERNAL WIRING 2 3
CONTROL CABINET EXTERNAL WIRING 3 3
AFSE PANEL 58B-43-00220
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480
CPR & GFR RELAY VG7043
ICP PANEL 58B-98-01910
RECTIFIER PANEL GE0557
DIODE HEAT SINK ASSEMBLY GE0558
CONTROL CABINET 2 11 58D-43-80070
CONTROL CABINET 3 11 58D-43-80070
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (1)
RECTIFIER PANEL GE0557 (1)
DIODE HEAT SINK ASSEMBLY GE0558 (1)
CONTROL CABINET 4 11 58D-43-80070
ICP PANEL 58B-98-01910 (1)
CONTROL CABINET 5 11 58D-43-80070
CONTROL CABINET 7 11 58D-43-80070
CONTROL CABINET 8 11 58D-43-80070
CONTROL CABINET 9 11 58D-43-80070
CONTACTOR - GF & GFR VE1317
POSITION SENSOR INTERLOCK VE3530
CONTROL CABINET 10 11 58D-43-80070
CONTROL CABINET 11 11 58D-43-80070
CONTROL CABINET DOORS AND COVERS 1 2
CONTROL CABINET DOORS AND COVERS 2 2
AFSE PANEL 58B-43-00220 (1)
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (2)
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (3)
AFSE PANEL COVER ASSEMBLY 2 2 58B-43-00480
CPR & GFR RELAY VG7043 (1)
ICP PANEL 58B-98-01910 (2)
CONTACTOR - GF & GFR VE1317 (1)
POSITION SENSOR INTERLOCK VE3530 (1)
RECTIFIER PANEL GE0557 (2)
DIODE HEAT SINK ASSEMBLY GE0558 (2)
DIODE HEAT SINK ASSEMBLY GE0558 (3)
RETARDING GRID INSTALLATION
RETARDING GRID 58D-06-01680 1 5
BLOWER MOTOR (BRUSH HOLDER WIRING) XA4146
BRUSH HOLDER ASSEMBLY VS8587
RETARDING GRID 58D-06-01680 1 5 (1)
BLOWER MOTOR (BRUSH HOLDER WIRING) XA4146 (1)
BRUSH HOLDER ASSEMBLY VS8587 (1)
RETARDING GRID 58D-06-01680 2 5
BLOWER MOTOR (BRUSH HOLDER WIRING) XA4146 (2)
BRUSH HOLDER ASSEMBLY VS8587 (2)
RETARDING GRID 58D-06-01680 3 5
BLOWER MOTOR (BRUSH HOLDER WIRING) XA4146 (3)
BRUSH HOLDER ASSEMBLY VS8587 (3)
RETARDING GRID 58D-06-01680 4 5
BLOWER MOTOR (COMMUTATOR END) XA4146
BRUSH HOLDER ASSEMBLY VS8587 (4)
BLOWER MOTOR (NON-COMMUTATOR END) XA4146
BLOWER MOTOR (BRUSH HOLDER WIRING) XA4146 (4)
BRUSH HOLDER ASSEMBLY VS8587 (5)
BLOWER MOTOR (FIELD INSTALLATION) XA4146
BRUSH HOLDER ASSEMBLY VS8587 (6)
WHEEL MOTOR INSTALLATION
WHEEL MOTOR 58D-22-50000 1 8
WHEEL MOTOR 58D-22-50000 1 8 (1)
WHEEL MOTOR 58D-22-50000 1 8 (2)
WHEEL MOTOR 58D-22-50000 2 8
WHEEL MOTOR 58D-22-50000 3 8
WHEEL MOTOR 58D-22-50000 4 8
WHEEL MOTOR 58D-22-50000 5 8
WHEEL MOTOR 58D-22-50000 6 8
WHEEL MOTOR ROTOR ASSEMBLY XA5788
WHEEL MOTOR 58D-22-50000 7 8
WHEEL MOTOR ROTOR ASSEMBLY XA5788 (1)
WHEEL MOTOR WIRING 1 2
WHEEL MOTOR WIRING 2 2
WHEEL MOTOR PIPING - RH
HYDRAULIC SYSTEM
HYDRAULIC TANK INSTALLATION
HYDRAULIC TANK ASSEMBLY
HYDRAULIC TANK 58D-60-00990
HYDRAULIC TANK ASSEMBLY (1)
HYDRAULIC TANK 58D-60-00990 (1)
HYDRAULIC TANK 58D-60-00990 (2)
HYDRAULIC TANK PIPING - HOIST CIRCUIT
HYDRAULIC TANK PIPING - STEERING CIRCUIT
HOIST FILTER FILTER PIPING & INSTALLATION
HOIST FILTER 58E-60-20010
HOIST FILTER 58E-60-20010 (1)
STEERING FILTER PIPING & INSTALLATION
STEERING FILTER 58E-60-01700
STEERING FILTER 58E-60-01700 (1)
DRIVE SHAFT INSTALLATION
PUMP MODULE PIPING 1 2
PUMP MODULE PIPING 2 2
HOIST VALVE & OVERCENTER VALVE INSTALLATION 1 3
HOIST CONTROL VALVE ASSEMBLY PB8267
RELIEF VALVE ASSEMBLY VE3567
SPOOL SECTION ASSEMBLY VE7624
OVERCENTER VALVE ASSEMBLY PC0522
HOIST VALVE & OVERCENTER VALVE INSTALLATION 2 3
HOIST VALVE & OVERCENTER VALVE INSTALLATION 3 3
HOIST CONTROL VALVE ASSEMBLY PB8267 (1)
RELIEF VALVE ASSEMBLY VE3567 (1)
SPOOL SECTION ASSEMBLY VE7624 (1)
RELIEF VALVE ASSEMBLY VE3567 (2)
SPOOL SECTION ASSEMBLY VE7624 (2)
OVERCENTER VALVE ASSEMBLY PC0522 (1)
HOIST PUMP INSTALLATION
HOIST PUMP ASSEMBLY PC3076
HOIST PUMP ASSEMBLY PC3076 (1)
STEERING PUMP INSTALLATION
STEERING PUMP INSTALLATION (1)
STEERING PUMP HOUSING (FRONT) 58C-60-00080
STEERING PUMP HOUSING (FRONT) 58C-60-00080 (1)
STEERING PUMP ROTATING GROUP 58C-60-00080
STEERING PUMP HOUSING (REAR) 58C-60-00080
CONTROL ASSEMBLY 58E-98-00370
STEERING PUMP SEAL INSTALLATION 58B-60-00080
CONTROL ASSEMBLY 58E-98-00370 (1)
HOIST CYLINDER PIPING
HOIST CYLINDER INSTALLATION
HOIST CYLINDER INSTALLATION - LOWER
HOIST CYLINDER ASSEMBLY W BEARINGS XB4507
HOIST CYLINDER ASSEMBLY XB4508
HOIST CYLINDER ASSEMBLY W BEARINGS XB4507 (1)
HOIST CYLINDER ASSEMBLY XB4508 (1)
HOIST CYLINDER ASSEMBLY XB4508 (2)
STEERING CONTROL UNIT PIPING
STEERING CONTROL UNIT PB6905
STEERING CONTROL UNIT PB6905 (1)
BRAKE VALVE PIPING
BRAKE VALVE INSTALLATION
CAB HYDRAULIC BRAKE CABINET PIPING
HYDRAULIC BRAKE CABINET HOSE ROUTING 1 3
HYDRAULIC BRAKE CABINET HOSE ROUTING 2 3
HYDRAULIC BRAKE CABINET HOSE ROUTING 3 3
HYDRAULIC BRAKE CABINET INSTALLATION
HYDRAULIC BRAKE CABINET 1 2
HYDRAULIC BRAKE CABINET 1 2 (1)
HYDRAULIC BRAKE CABINET 2 2
HOIST PILOT VALVE PIPING
HOIST PILOT VALVE ASSEMBLY PB6922
HOIST PILOT MANIFOLD 58D-60-80000
HOIST PILOT VALVE ASSEMBLY PB6922 (1)
HOIST PILOT MANIFOLD 58D-60-80000 (1)
DUAL RELAY VALVE PIPING & INSTALLATION
BRAKE MANIFOLD, SHUTTLE & JUNCTION BLOCK PIPING
BRAKE MANIFOLD PC2915
BRAKE MANIFOLD PC2915 (1)
FRONT BRAKE PIPING
REAR BRAKE PIPING 1 3
REAR BRAKE PIPING 2 3
REAR BRAKE PIPING 3 3
REAR DISC & PARKING BRAKE PIPING
STEERING ACCUMULATOR INSTALLATION
PISTON ACCUMULATOR ASSEMBLY 58E-60-10091
PISTON ACCUMULATOR ASSEMBLY 58E-60-10091 (1)
STEERING BLEEDDOWN MANIFOLD INSTALLATION
STEERING BLEEDDOWN MANIFOLD 58D-60-14000
STEERING BLEEDDOWN MANIFOLD PIPING 1 2
STEERING BLEEDDOWN MANIFOLD PIPING 2 2
STEERING BLEEDDOWN MANIFOLD 58D-60-14000 (1)
FLOW AMPLIFIER INSTALLATION
FLOW AMPLIFIER HOSE FITTINGS
STEERING CYLINDER PIPING
STEERING CYLINDER INSTALLATION
STEERING CYLINDER W BEARINGS XB4661
STEERING CYLINDER W BEARINGS XB4661 (1)
AUXILIARY HYDRAULIC SYSTEM 1 2
AUXILIARY HYDRAULIC SYSTEM 2 2
AUXILIARY HYDRAULIC MANIFOLD 58B-60-01770
AUXILIARY HYDRAULIC MANIFOLD 58B-60-01770 (1)
BLADDER ACCUMULATOR ASSEMBLY (2
MAIN FRAME & RELATED PARTS
FRAME & UPRIGHTS
PIN BORE WEAR SLEEVES
LH ENGINE ACCESS LADDER & HANDRAILS
RH ENGINE ACCESS LADDER & HANDRAILS
HYDRAULIC TANK LADDER
FRAME GROUND WIRING
OPERATOR'S COMPARTMENT & CONTROL SYSTEM
CAB MOUNTING HARDWARE
CAB LIFTING HARDWARE
CAB INSULATION
CAB INTERIOR COVERS
CAB ACCESSORIES
CAB INTERIOR TRIM
CAB EXTERNAL COVERS
CAB HYDRAULIC HOSE COVERS
CAB WINDOWS
CAB DOOR INSTALLATION
DOOR ASSEMBLY - LH 58E-54-30626
DOOR ASSEMBLY - RH 58E-54-30636
DOOR ASSEMBLY - LH 58E-54-30626 (1)
DOOR ASSEMBLY - RH 58E-54-30636 (1)
OPERATOR SEAT INSTALLATION
OPERATOR SEAT- PREMIUM 58E-57-16771
SEAT SUSPENSION ASSEMBLY 58E-98-10860
OPERATOR SEAT- PREMIUM 58E-57-16771 (1)
SEAT SUSPENSION ASSEMBLY 58E-98-10860 (1)
SEAT SUSPENSION ASSEMBLY 58E-98-10860 (2)
PASSENGER SEAT INSTALLATION
PASSENGER SEAT- PREMIUM 58E-57-16760
SEAT SUSPENSION ASSEMBLY 58E-98-11250
PASSENGER SEAT- PREMIUM 58E-57-16760 (1)
SEAT SUSPENSION ASSEMBLY 58E-98-11250 (1)
SEAT SUSPENSION ASSEMBLY 58E-98-11250 (2)
MANUAL HOLDER
CAB FLOORMATS
OVERHEAD DASH MODULE
CAB SUN VISOR
INSTRUMENT PANEL
GAUGE PANEL INSTALLATION
GAUGE PANEL 58E-06-60001
GAUGE PANEL 58E-06-60001 (1)
LOWER LH DASH SWITCHES
LOWER RH DASH SWITCHES
RADIO MODULE
RADIO ANTENNA INSTALLATION
STEERING COLUMN 1 2
STEERING COLUMN 2 2
STEERING COLUMN 2 2 (1)
STEERING COLUMN ASSEMBLY 58E-54-06714
STEERING COLUMN ASSEMBLY 58E-54-06714 (1)
CENTER CONSOLE MODULE - ELECTRICAL 1 2
CENTER CONSOLE MODULE - ELECTRICAL 2 2
CENTER CONSOLE MODULE - STRUCTURAL
SHIFT LEVER INSTALLATION
HOIST LEVER INSTALLATION
ACCELERATOR PEDAL INSTALLATION
VID PANEL INSTALLATION
IRIDIUM CONTROLLER INSTALLATION
KOMTRAX PLUS II CONTROLLER INSTALLATION
CAB ELECTRICAL - BACK WALL WIRING 2 2
CAB EXTERNAL WIRING CONNECTOR PLATE
CAB RETARD BRAKE LIGHTS
CAB SPEAKERS & DOME LIGHTS
CAB SPEAKERS & DOME LIGHTS (1)
CAB ELECTRICAL - SPEAKERS & DOME LIGHTS WIRING
WIPER WASHER TIMER DELAY MODULES
WINDSHIELD WIPER INSTALLATION
WINDSHIELD WASHER RESERVOIR INSTALLATION
AIR CONDITIONING PIPING 1 2
AIR CONDITIONING PIPING 2 2
AIR CONDITIONING COMPRESSOR INSTALLATION & PIPING
A C CONDENSER INSTALLATION
HVAC INSTALLATION
HVAC DUCT ASSEMBLY 58E-98-20022
HVAC DEFROST DUCT ASSEMBLY 58E-98-20031
HVAC MODULE 58E-98-20042
HVAC MODULE INSTALLATION 58E-98-20051 1 2
HVAC DUCT ASSEMBLY 58E-98-20022 (1)
HVAC DEFROST DUCT ASSEMBLY 58E-98-20031 (1)
HVAC MODULE 58E-98-20042 (1)
HVAC MODULE INSTALLATION 58E-98-20051 1 2 (1)
HVAC MODULE INSTALLATION 58E-98-20051 2 2
HEATER HOSE INSTALLATION
HEATER AC DRAIN HOSE INSTALLATION
DECKS & HANDRAILS
DIAGONAL LADDER INSTALLATION
DIAGONAL LADDER & UPPER PLATFORM HANDRAILS - RH
GRILLE HANDRAIL
LH LOWER PLATFORM INSTALLATION
RH PLATFORM & LADDER INSTALLATION
LH LADDER INSTALLATION
RH LADDER INSTALLATION
LH LADDER HANDRAILS
LH DECK INSTALLATION
RH DECK INSTALLATION
CENTER DECK INSTALLATION
LH DECK HANDRAILS
RH DECK HANDRAILS
REAR DECK HANDRAILS
LH MIRROR INSTALLATION
RH MIRROR INSTALLATION
REINFORCE PLATFORM KIT
GUARDS & MUD FLAPS
GRILLE & AIR DAM FLAPS INSTALLATION
GRILLE INSERTS
HYDRAULIC TANK MUD FLAPS
FUEL TANK MUD FLAPS (OPTIONAL)
DRIVE SHAFT GUARD
CHASSIS LOOSE COMPONENTS 1 3
CHASSIS LOOSE COMPONENTS 2 3
DUMP BODY MUD FLAPS 1 2
DUMP BODY MUD FLAPS 2 2
LH DECK COVERS
CAB CONNECTOR MUD FLAPS
ISOLATION BOX WIRING COVERS
FRONT SUSPENSION & STEERING LINKAGE
SPINDLE, HUB AND BRAKE ASSEMBLY 58D-32-90001
FRONT BRAKE ASSEMBLY 58D-32-00070
STEERING ARM INSTALLATION
TIE ROD INSTALLATION
TIE ROD ASSEMBLY 58D-40-00060
TIE ROD ASSEMBLY 58D-40-00060 (1)
FRONT SUSPENSION INSTALLATION - FRAME
FRONT SUSPENSION ASSEMBLY 58D-50-90000
FRONT SUSPENSION INSTALLATION - STEERING ARM
FRONT SUSPENSION ASSEMBLY 58D-50-90000 (1)
REAR SUSPENSION & AXLE HOUSING
REAR SUSPENSION INSTALLATION
REAR SUSPENSION ASSEMBLY 58D-50-00060
REAR SUSPENSION ASSEMBLY 58D-50-00060 (1)
REAR AXLE HOUSING INSTALLATION
ANTI-SWAY BAR INSTALLATION
REAR AXLE HOUSING HATCH
REAR BRAKE INSTALLATION
REAR BRAKE ASSEMBLY PC3085
REAR BRAKE ASSEMBLY PC3085 (1)
WHEELS & RIMS
FRONT WHEEL INSTALLATION 1 2
FRONT WHEEL INSTALLATION 2 2
STANDARD RIM ASSEMBLY
REAR WHEEL INSTALLATION
STANDARD RIM ASSEMBLY (1)
SMART RIM ASSEMBLY - REAR OUTER
STANDARD RIM ASSEMBLY (2)
SMART RIM ASSEMBLY - REAR OUTER (1)
BODY & RELATED PARTS
BODY & SLING
BODY PIVOT
BODY GUIDE & BODY PADS
DUMP BODY EYEBROWS
BODY HEAT SHIELDS
ROCK EJECTORS INSTALLATION
DECALS & PLATES
SAFETY LABELS 1 6
SAFETY LABELS 2 6
SAFETY LABELS 3 6
SAFETY LABELS 4 6
SAFETY LABELS 6 6
SAFETY LABELS 7 6
CAB SAFETY LABELS
GRADE SPEED CHART
LUBRICATION CHART
TOOLS
SPECIAL TOOL GROUP
CUSTOM METER KIT
SUSPENSION CHARGING BLOCK KIT - FRONT
SUSPENSION CHARGING BLOCK KIT - REAR
FLUSHING BLOCK
CHARGING MANIFOLD ASSEMBLY EB1759
SMART RIM TOOL
KOMVISION TOOL GROUP
MISCELLANEOUS & OPTIONS
AUTOMATIC LUBRICATION SYSTEM PIPING - FRONT 1 2
AUTOMATIC LUBRICATION SYSTEM PIPING - FRONT 2 2
3-PIECE INJECTOR ASSEMBLY TA4410
AUTOMATIC LUBRICATION SYSTEM - REAR 1 2
4-PIECE INJECTOR ASSEMBLY VW7989
5-PIECE INJECTOR ASSEMBLY TA4411
AUTOMATIC LUBRICATION SYSTEM - REAR 2 2
AUTOMATIC LUBRICATION SYSTEM - REAR 2 2 (1)
3-PIECE INJECTOR ASSEMBLY TA4410 (1)
4-PIECE INJECTOR ASSEMBLY VW7989 (1)
5-PIECE INJECTOR ASSEMBLY TA4411 (1)
TIE ROD STEERING CYLINDER LUBRICATION LINES
LUBRICATION PUMP SUB-ASSEMBLY
LUBRICATION PUMP SUB-ASSEMBLY (1)
LUBRICATION PUMP SUB-ASSEMBLY (2)
AUTO LUBE FILTER ASSEMBLY PC0811
LUBE PUMP CONTAINER ASSEMBLY 58F-98-40250
LUBE PUMP ASSEMBLY 58F-98-40240 1 3
VENT VALVE ASSEMBLY LA0912
CHECK VALVE ASSEMBLY LA1187
AUTO LUBE FILTER ASSEMBLY PC0811 (1)
LUBE PUMP CONTAINER ASSEMBLY 58F-98-40250 (1)
LUBE PUMP ASSEMBLY 58F-98-40240 1 3 (1)
VENT VALVE ASSEMBLY LA0912 (1)
CHECK VALVE ASSEMBLY LA1187 (1)
LUBE PUMP ASSEMBLY 58F-98-40240 1 3 (2)
LUBE PUMP ASSEMBLY 58F-98-40240 2 3
LUBE PUMP ASSEMBLY 58F-98-40240 3 3
VENT VALVE ASSEMBLY LA0912 (2)
CHECK VALVE ASSEMBLY LA1187 (2)
REAR AXLE SERVICE CENTER - LH
REMOTE SERVICE CENTER
HUBODOMETER INSTALLATION
FIRE EXTINGUISHER
IRIDIUM SATELLITE ANTENNA INSTALLATION
GPS ANTENNA INSTALLATION
KWB WIRELESS RADIO & ANTENNA INSTALLATION
KOMVISION DASH MODULE INSTALLATION
KOMVISION DISPLAY MODULE 58E-54-25601
KOMVISION DISPLAY MODULE 58E-54-25601 (1)
KOMVISION CONTROLLER BOX
KOMVISION CAMERA INSTALLATION - LEFT
KOMVISION CAMERA INSTALLATION - REAR
KOMVISION CAMERA INSTALLATION - RIGHT
KOMVISION CAMERA INSTALLATION - FRONT
KOMVISION CAMERA INSTALLATION - FRONT LEFT
KOMVISION CAMERA INSTALLATION - FRONT RIGHT
KOMVISION RADAR HARNESS ROUTING
KOMVISION RADAR INSTALLATION - FRONT
RADAR SENSOR ASSEMBLY XC3988
KOMVISION RADAR INSTALLATION - SIDES
RADAR SENSOR ASSEMBLY XC3988 (1)
KOMVISION RADAR INSTALLATION - REAR
RADAR SENSOR ASSEMBLY XC3988 (2)
RADAR SENSOR ASSEMBLY XC3988 (3)
Komatsu, Dump Truck, s AFE84-A 730E-10 SN A50002 - A50004, A50007 - A50019 OCEANA GOLD, Parts Catalog,
FAN INSTALLATION
FAN DRIVE SYSTEM
EXHAUST BLANKETS
COOLING SYSTEM
RADIATOR PIPING 1 3
RADIATOR PIPING 2 3
FUEL TANK ASSEMBLY
DEF PUMP MODULE
ELECTRICAL SYSTEM
BATTERY BOX 1 6
BATTERY BOX 2 6
BATTERY BOX 3 6
BATTERY BOX 4 6
BATTERY BOX 5 6
BATTERY BOX 6 6
HORN INSTALLATION
PLM LIGHT ASSEMBLY
LADDER LIGHTS
DRIVE SYSTEM
HYDRAULIC SYSTEM
BRAKE VALVE PIPING
FRONT BRAKE PIPING
FRAME & UPRIGHTS
FRAME GROUND WIRING
CAB INSULATION
CAB INTERIOR COVERS
CAB ACCESSORIES
CAB INTERIOR TRIM
CAB EXTERNAL COVERS
CAB WINDOWS
MANUAL HOLDER
CAB FLOORMATS
CAB SUN VISOR
INSTRUMENT PANEL
RADIO MODULE
STEERING COLUMN 1 2
STEERING COLUMN 2 2
HVAC INSTALLATION
DECKS & HANDRAILS
GRILLE HANDRAIL
LH LADDER HANDRAILS
LH DECK HANDRAILS
RH DECK HANDRAILS
REAR DECK HANDRAILS
GUARDS & MUD FLAPS
GRILLE INSERTS
DRIVE SHAFT GUARD
LH DECK COVERS
WHEELS & RIMS
BODY & SLING
BODY PIVOT
DUMP BODY EYEBROWS
BODY HEAT SHIELDS
DECALS & PLATES
SAFETY LABELS 1 6
SAFETY LABELS 2 6
SAFETY LABELS 3 6
SAFETY LABELS 4 6
SAFETY LABELS 6 6
SAFETY LABELS 7 6
CAB SAFETY LABELS
GRADE SPEED CHART
LUBRICATION CHART
TOOLS
SPECIAL TOOL GROUP
CUSTOM METER KIT
FLUSHING BLOCK
SMART RIM TOOL
FIRE EXTINGUISHER
- KOMATSU Fault Codes
