Komatsu Dump Truck HD1500-8 Shop Manual SEN06630-21
Type of Machine: Dump Truck
Type of Manual: Shop Manual
Model: Komatsu HD1500-8 Dump Truck
Serial Number: 81001 and up
Publication Date: 06.2022
Form Number: SEN06630-21
Number of Pages: 2992 Pages
00 Index And Foreword
Index
Abbreviations
Foreword, Safety, Basic Information
01 Specifications
Contents
Abbreviations
Specifications
10 Structure And Function
Contents
Abbreviations
Boot-Up System
Engine System
Control System
Power Train System
Work Equipment System
Auto-Greasing System
Service Center
Undercarriage And Frame
Work Equipment
Cab And Its Attachments
Lifting System
20 Standard Value Table
Contents
Abbreviations
Standard Value Table For Engine
Standard Value Table For Machine
30 Test And Adjust
Contents
Abbreviations
Related Information To Test And Adjust
Engine And Cooling System
Power Train
Work Equipment
Lifting System
Pm Clinic
40 Troubleshooting
Contents
Abbreviations
Related Information On Troubleshooting
Troubleshooting By Failure Code (Display Of Code)
Troubleshooting Of Electrical System (E-Mode)
Troubleshooting For Hydraulic And Mechanical Systems (H Mode)
50 Disassembly And Assembly
Contents
Abbreviations
Disassemble And Assemble-Related Information
Power Train
Work Equipment
60 Maintenance Standard
Contents
Abbreviations
Power Train
Hydrauuc System
Work Equipment
80 The Other Information
Contents
Abbreviations
Air Conditioner System
Component Parts Of Air Conditioner System
Sensors For Air Conditioner System
Explanation Of Procedure For Testing And Troubleshooting Of Air Conditioner
Circuit Diagram And Arrangement Of Connector Pins For Air Conditioner
Air Conditioner System Diagram
Installation Locations Of Air Conditioner Parts And Arrangement Of Connectors
Testing Air Leakage (Duct)
Testing Air Conditioner Using Self-Diagnosis Function
How To Open The Electrical System Abnormality Record Screen In Service Mode Of The Machine Monitor
Test Vent (Mode) Changeover
Testing Freshjrecirc Air Changeover
Test (Triple) Pressure Switch For Refrigerant
Test Relays
Air Conditioner Troubleshooting Chart 1
Air Conditioner Troubleshooting Chart 2
Information Described In Troubleshooting Table
Failure Code [879aka]
Failure Code [879akb]
Failure Code [879bka]
Failure Code [879bkb]
Failure Code [879cka]
Failure Code [879ckb]
Failure Code [879emc]
Failure Code [879fmc]
Failure Code [879gkx]
A-1 Troubleshoot Power Supply System (Air Conditioner 00es Not Oærate)
A-2 Troubleshooting For Compressor And Refrigerant System (Air Is Not Cooled)
A-3 Troubleshooting For Blower Motor System (No Air Comes Out Or Air Flow Is Abnormal
A-4 Troubleshooting For Fresh/Recirc Air Changeover
Troubleshooting Using Gauge Pressure
Connection Of Service Tool
Precautions For Disconnecting And Connecting Hoses And Tubes In Air Conditioner Pipings
Handle Compressor Oil
Method For Replacing Desiccant
Komvision System
Structure And Operation Of Komvision System
Testing And Adjusting Komvision System
Troubleshooting Of Komvsion System
90 Circuit Diagrams
Contents
Abbreviations
Hydrauuc Circuit Diagram
Electrical Circuit Diagram
Index
