Hyundai
86
176,834
Komatsu Dump Truck 930E-5 Spare Parts Catalog
Type of Machine: Dump Truck
Model: Komatsu 930E-5 Dump Truck
Serial Number: A40203 – A40204, A40206 – A40207 A40209 A40210 DOWNER
Number of Pages: 1251 Pages
AFE78-BK KOMATSU MINING
ENGINE & RELATED PARTS
FAN GUARD INSTALLATION
FAN INSTALLATION
AIR CLEANER PIPING & INSTALLATION - LH
AIR CLEANER 58F-02-00160
AIR CLEANER PIPING & INSTALLATION - RH
AIR CLEANER 58F-02-00160 (1)
AIR CLEANER 58F-02-00160 (2)
ENGINE AND COMPONENTS
ENGINE CRADLE INSTALLATION 1 2
ENGINE CRADLE INSTALLATION 2 2
EXHAUST PIPING - FRONT
EXHAUST PIPING - REAR
EXHAUST BLANKETS
COOLING SYSTEM
RADIATOR INSTALLATION - UPPER
RADIATOR INSTALLATION - LOWER 1 2
RADIATOR INSTALLATION - LOWER 2 2
RADIATOR & SHROUD ASSEMBLY 58F-03-40000
LOW TEMPERATURE CORE 58F-03-02110
HIGH TEMPERATURE CORE 58F-03-02100
LOW TEMPERATURE CORE 58F-03-02110 (1)
HIGH TEMPERATURE CORE 58F-03-02100 (1)
RADIATOR PIPING 1 4
RADIATOR PIPING 2 4
RADIATOR PIPING 3 4
RADIATOR PIPING 4 4
RADIATOR PIPING - HEAT EXCHANGER
HEAT EXCHANGER PB9796
HEAT EXCHANGER PB9796 (1)
FUEL TANK & RELATED PARTS
FUEL TANK INSTALLATION
FUEL TANK ASSEMBLY 58F-04-00701
FUEL TANK ASSEMBLY 58F-04-00701 (1)
FUEL SYSTEM PIPING 1 4
FUEL SYSTEM PIPING 2 4
FUEL SYSTEM PIPING 4 4
FUEL TANK REMOTE FILL - RH
FUEL TANK REMOTE FILL - LH 1 2
FUEL TANK REMOTE FILL - LH 2 2
FUEL LEVEL SENDER & WIRING
ELECTRICAL SYSTEM
BATTERY BOX INSTALLATION
BATTERY BOX ASSEMBLY 1 7 58F-54-20972
BATTERY BOX ASSEMBLY 1 7 58F-54-20972 (1)
BATTERY BOX ASSEMBLY 2 7 58F-54-20972
BATTERY BOX ASSEMBLY 3 7 58F-54-20972
BATTERY BOX ASSEMBLY 4 7 58F-54-20972
BATTERY BOX ASSEMBLY 5 7 58F-54-20972
BATTERY BOX ASSEMBLY 6 7 58F-54-20972
BATTERY BOX ASSEMBLY 7 7 58F-54-20972
ISOLATION BOX INSTALLATION
ISOLATION BOX 1 3
ISOLATION BOX 2 3
ISOLATION BOX 3 3
ISOLATION BOX EXTERNAL WIRING 1 2
ISOLATION BOX EXTERNAL WIRING 2 2
GROUND LEVEL ENGINE SHUTDOWN SWITCH
CRANKING MOTOR INSTALLATION
CRANKING MOTOR WIRING 1 2
A C COMPRESSOR GUARD ASSEMBLY
CRANKING MOTOR WIRING 2 2
BATTERY CHARGING ALTERNATOR INSTALLATION
BATTERY CHARGING ALTERNATOR WIRING
EXTERNAL ENGINE WIRING HARNESS INSTALLATION 1 2
EXTERNAL ENGINE WIRING HARNESS INSTALLATION 2 2
LH DECK WIRING HARNESS & LIGHTS
HORN INSTALLATION
RH DECK WIRING HARNESS & LIGHTS
LH ENGINE BAY LIGHTS & SWITCH
RH ENGINE BAY LIGHTS & SWITCH
MIRROR MOUNTED BACKUP LIGHTS
LADDER LIGHTS
GROUND LEVEL LADDER LIGHTS SWITCH
HEADLIGHT WIRING HARNESS
HEADLIGHTS & FOG LIGHTS 1 2
REAR AXLE LIGHTS & BACKUP ALARMS
REAR AXLE HOUSING SERVICE LIGHT
HYDRAULIC BRAKE CABINET INTERNAL WIRING
AMBIENT AIR TEMPERATURE SENSOR
ENGINE AIR INTAKE PRESSURE SWITCH
STEERING ACCUMULATOR PRESSURE SWITCH
STEERING FILTER PRESSURE SWITCH
HOIST FILTER PRESSURE SWITCH
HYDRAULIC TANK SENSOR & SWITCH
PUMP MODULE PRESSURE SENSORS
STEERING BLEEDDOWN MANIFOLD SENSOR & SWITCHES
BRAKE COOLING OIL TEMPERATURE SENSORS
PLM PRESSURE SENSOR - FRONT SUSPENSIONS 1 2
PLM PRESSURE SENSOR - FRONT SUSPENSIONS 2 2
PLM PRESSURE SENSOR - REAR SUSPENSIONS 1 2
PLM PRESSURE SENSOR - REAR SUSPENSIONS 2 2
FRONT WHEEL SPEED SENSOR INSTALLATION
FRONT WHEEL SPEED SENSOR WIRING HARNESS
BODY UP & HOIST LIMIT SWITCH INSTALLATION
AUXILIARY CONTROL CABINET POWER CABLES
AUX CNTRL CABINET CABLE & HARNESS CONNECTIONS 1 2
AUX CNTRL CABINET CABLE & HARNESS CONNECTIONS 2 2
AUXILIARY CONTROL CABINET EXTERNAL WIRING CLAMPING
RIGHT FRONT FRAME RAIL HARNESS
RIGHT REAR FRAME RAIL HARNESS
LEFT FRONT FRAME RAIL HARNESS
LEFT REAR FRAME RAIL HARNESS
LEFT REAR FRAME RAIL HARNESS (1)
LEFT REAR FRAME RAIL HARNESS (2)
LEFT REAR FRAME RAIL HARNESS (3)
LEFT REAR FRAME RAIL HARNESS (4)
LEFT REAR FRAME RAIL HARNESS (5)
LEFT REAR FRAME RAIL HARNESS (6)
LEFT REAR FRAME RAIL HARNESS (7)
AUXILIARY CONTROL CABINET INSTALLATION
AUXILIARY CONTROL CABINET STRUCTURE 1 2
AUXILIARY CONTROL CABINET STRUCTURE 2 2
AUXILIARY CONTROL CABINET - REAR WALL 1 2
AUXILIARY CONTROL CABINET - REAR WALL 2 2
AUXILIARY CONTROL CABINET - LH WALL 2 2
AUXILIARY CONTROL CABINET - RH WALL 1 2
VEHICLE ELECTRICAL CENTER VEC-89 58E-06-02043
VEHICLE ELECTRICAL CENTER VEC-90 58E-06-20051
VEHICLE ELECTRICAL CENTER VEC-91 58E-06-20062
VEHICLE ELECTRICAL CENTER VEC-92 58E-06-09621
AUXILIARY CONTROL CABINET - RH WALL 2 2
VEHICLE ELECTRICAL CENTER VEC-89 58E-06-02043 (1)
VEHICLE ELECTRICAL CENTER VEC-90 58E-06-20051 (1)
VEHICLE ELECTRICAL CENTER VEC-91 58E-06-20062 (1)
VEHICLE ELECTRICAL CENTER VEC-92 58E-06-09621 (1)
AUXILIARY CONTROL CABINET INTERNAL WIRING 1 2
DRIVE SYSTEM
AUXILIARY BLOWER INSTALLATION
AUXILIARY BLOWER MOTOR 58F-02-04110
TRANSFORMER 1 2 58E-06-11011
TRANSFORMER 2 2 58E-06-11011
REAR AXLE BLOWER DUCTS
ALTERNATOR INLET DUCTS
AXLE BLOWR PRES SW INST 1 2 (S N A40203-04)
AXLE BLOWR PRES SW INST 1 2 (S N A40206-07, 09-10)
AXLE BLOWR PRES SW INST 2 2
REAR AXLE LIGHTS & BACKUP ALARMS (1)
WHEEL MOTOR CABLE MOUNT - REAR AXLE
WHEEL MOTOR CABLE CONNECTIONS
CONTROL CABINET EXTERNAL WIRING - WHEEL MOTOR 1 2
CONTROL CABINET EXTERNAL WIRING - ALTERNATOR
CONTROL CABINET EXTERNAL WIRING - RETARDING GRID
CONTROL CABINET EXTERNAL WIRING - AUX BLOWERS
CONTROL CABINET 1 13
ICP PANEL 58F-43-01310
RECTIFIER PANEL GE0557
CONTROL CABINET 1 13 (1)
ICP PANEL 58F-43-01310 (1)
RECTIFIER PANEL GE0557 (1)
CONTROL CABINET 2 13
AFSE PANEL 1 2 58B-43-00220
CPR & GFR RELAY VG7043
CONTROL CABINET 3 13
CONTROL CABINET 4 13
CONTROL CABINET 5 13
CONTROL CABINET 7 13
CONTROL CABINET 7 13 (1)
CONTROL CABINET 8 13
CONTROL CABINET 9 13
CONTROL CABINET 10 13
CONTROL CABINET 11 13
CONTROL CABINET 12 13
CONTROL CABINET 13 13
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480
AFSE PANEL COVER ASSEMBLY 2 2 58B-43-00480
AFSE PANEL 1 2 58B-43-00220 (1)
AFSE PANEL 2 2 58B-43-00220
AFSE PANEL COVER ASSEMBLY 1 2 58B-43-00480 (1)
ICP PANEL 58F-43-01310 (2)
RECTIFIER PANEL GE0557 (2)
CPR & GFR RELAY VG7043 (1)
RETARDING GRID INSTALLATION
RETARDING GRID 1 6 58F-06-03102
RETARDING GRID 1 6 58F-06-03102 (1)
RETARDING GRID 2 6 58F-06-03102
RETARDING GRID 3 6 58F-06-03102
RETARDING GRID 5 6 58F-06-03102
RETARDING GRID 6 6 58F-06-03102
GRID BLOWER MOTOR 1 4 58F-98-01340
GRID BLOWER MOTOR 2 4 58F-98-01340
GRID BLOWER MOTOR 3 4 58F-98-01340
GRID BLOWER MOTOR 4 4 58F-98-01340
ALTERNATOR ASSEMBLY 1 6 58F-06-11302
ALTERNATOR ASSEMBLY 1 6 58F-06-11302 (1)
ALTERNATOR ASSEMBLY 2 6 58F-06-11302
ALTERNATOR ROTOR ASSEMBLY 1 2 58F-43-03101
ALTERNATOR ASSEMBLY 3 6 58F-06-11302
ALTERNATOR ASSEMBLY 4 6 58F-06-11302
ALTERNATOR ASSEMBLY 5 6 58F-06-11302
ALTERNATOR ASSEMBLY 6 6 58F-06-11302
BRUSH HOLDER ASSEMBLY
CONNECTOR ASSEMBLY - HARDWARE
ALTERNATOR ROTOR ASSEMBLY 1 2 58F-43-03101 (1)
ALTERNATOR BEARING ASSEMBLY 58F-06-05480
ALTERNATOR BEARING ASSEMBLY 58F-06-05480 (1)
ALTERNATOR STATOR ASSEMBLY 58F-43-03160
WHEEL MOTOR ASSEMBLY MOUNTING
REAR BRAKE INSTALLATION
REAR BRAKE ASSEMBLY 58F-33-40020
WHEEL MOTOR 58F-30-00171
WHEEL MOTOR ROTOR ASSEMBLY 1 2 58F-30-00200
TRANSMISSION 1 2 58F-30-00191
TRANSMISSION 2 2 58F-30-00191
CARRIER ASSEMBLY - HIGH SPEED GE1315
CARRIER ASSEMBLY - LOW SPEED 58F-22-01530
CARRIER ASSEMBLY - HIGH SPEED GE1315 (1)
CARRIER ASSEMBLY - LOW SPEED 58F-22-01530 (1)
REAR BRAKE INSTALLATION (1)
REAR BRAKE ASSEMBLY 58F-33-40020 (1)
WHEEL MOTOR 58F-30-00171 (1)
WHEEL MOTOR ROTOR ASSEMBLY 1 2 58F-30-00200 (1)
WHEEL MOTOR ROTOR ASSEMBLY 1 2 58F-30-00200 (2)
WHEEL MOTOR ROTOR ASSEMBLY 2 2 58F-30-00200
HYDRAULIC SYSTEM
HYDRAULIC TANK INSTALLATION
HYDRAULIC TANK ASSEMBLY
HYDRAULIC TANK STRUCTURE
HYDRAULIC TANK ASSEMBLY (1)
HYDRAULIC TANK STRUCTURE (1)
HYDRAULIC TANK STRUCTURE (2)
HYDRAULIC TANK PIPING - HOIST CIRCUIT 1 2
HYDRAULIC TANK PIPING - HOIST CIRCUIT 2 2
HYDRAULIC TANK PIPING - STEERING CIRCUIT 1 2
HYDRAULIC TANK PIPING - STEERING CIRCUIT 2 2
HOIST FILTER PIPING & INSTALLATION
HOIST FILTER ASSEMBLY 58F-60-00990
HOIST FILTER ASSEMBLY 58F-60-00990 (1)
STEERING FILTER PIPING & INSTALLATION
STEERING FILTER ASSEMBLY 58F-60-40350
STEERING FILTER ASSEMBLY 58F-60-40350 (1)
DRIVESHAFT INSTALLATION - TRACTION ALTERNATOR
DRIVESHAFT INSTALLATION - HOIST PUMP
DRIVESHAFT ASSEMBLY 58E-11-10000
DRIVESHAFT ASSEMBLY 58E-11-10000 (1)
VALVE PUMP MODULE INSTALLATION
VALVE PUMP MODULE PIPING 1 3
VALVE PUMP MODULE PIPING 2 3
VALVE PUMP MODULE PIPING 3 3
HOIST VALVE & OVERCENTER VALVE INSTALLATION
HOIST VALVE ASSEMBLY PC1482
RELIEF VALVE ASSEMBLY 58B-98-01650
SPOOL SECTION ASSEMBLY VE3810
SPOOL SECTION ASSEMBLY - TANK BF3050
OVERCENTER VALVE ASSEMBLY PC0522
HOIST VALVE ASSEMBLY PC1482 (1)
RELIEF VALVE ASSEMBLY 58B-98-01650 (1)
SPOOL SECTION ASSEMBLY VE3810 (1)
SPOOL SECTION ASSEMBLY - TANK BF3050 (1)
RELIEF VALVE ASSEMBLY 58B-98-01650 (2)
SPOOL SECTION ASSEMBLY VE3810 (2)
SPOOL SECTION ASSEMBLY - TANK BF3050 (2)
OVERCENTER VALVE ASSEMBLY PC0522 (1)
HOIST PUMP INSTALLATION
HOIST PUMP ASSEMBLY PB9008
HOIST PUMP ASSEMBLY PB9008 (1)
STEERING PUMP INSTALLATION
STEERING PUMP SEAL INSTALLATION 58C-60-00080
STEERING PUMP SEAL INSTALLATION 58C-60-00080 (1)
STEERING PUMP HOUSING (FRONT) 58C-60-00080
STEERING PUMP ROTATING GROUP 58C-60-00080
STEERING PUMP HOUSING (REAR) 58C-60-00080
CONTROL ASSEMBLY 58E-98-00370
CONTROL ASSEMBLY 58E-98-00370 (1)
HOIST CYLINDER PIPING
HOIST CYLINDER ASSEMBLY W BEARINGS EM8376
HOIST CYLINDER INSTALLATION - TOP
HOIST CYLINDER INSTALLATION - BOTTOM
HOIST CYLINDER ASSEMBLY W BEARINGS EM8376 (1)
BRAKE COOLING PIPING - LEFT FRONT 1 2
BRAKE COOLING PIPING - LEFT FRONT 2 2
BRAKE COOLING PIPING - RIGHT FRONT 1 2
BRAKE COOLING PIPING - RIGHT FRONT 2 2
BRK COOL PIPING - REAR AXLE (S N A40203-04)
BRK COOL PIPING - REAR AXLE (S N A40206-07, 09-10)
STEERING CONTROL UNIT PIPING 1 2
STEERING CONTROL UNIT PIPING 2 2
STEERING CONTROL UNIT INSTALLATION
STEERING CONTROL UNIT PB9881
STEERING CONTROL UNIT PB9881 (1)
BRAKE VALVE PIPING 1 2
BRAKE VALVE PIPING 2 2
BRAKE VALVE INSTALLATION
BRAKE VALVE ASSEMBLY 58F-61-00001
BRAKE VALVE ASSEMBLY 58F-61-00001 (1)
HYDRAULIC BRAKE CABINET PIPING - BRAKE MANIFOLD
HYDRAULIC BRAKE CABINET PIPING - HOIST PILOT VALVE
HYDRAULIC BRAKE CABINET PIPING - DUAL RELAY VALVE
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (1)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (2)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (3)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (4)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (5)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (6)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (7)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (8)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (9)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (10)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (11)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (12)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (13)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (14)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (15)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (16)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (17)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (18)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (19)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (20)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (21)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (22)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (23)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (24)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (25)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (26)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (27)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (28)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (29)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (30)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (31)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (32)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (33)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (34)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (35)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (36)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (37)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (38)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (39)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 1 3 (40)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 2 3
HYDRAULIC BRAKE CABINET HOSE CLAMPING 2 3 (1)
HYDRAULIC BRAKE CABINET HOSE CLAMPING 3 3
HYDRAULIC BRAKE CABINET INSTALLATION
HYDR BRK CBNT STRUCTURE 1 2
HYDR BRK CBNT STRUCTURE 1 2 (1)
HYDR BRK CBNT STRUCTURE 2 2 (S N A40203-04)
HYDR BRK CBNT STRUCTURE 2 2 (S N A40206-07, 09-10)
HOIST PILOT VALVE INSTALLATION
HOIST PILOT VALVE ASSEMBLY PB6922
HOIST PILOT VALVE ASSEMBLY PB6922 (1)
HOIST PILOT VALVE PIPING 1 2
HOIST PILOT VALVE PIPING 2 2
SHUTTLE VALVE & JUNCTION BLOCK PIPING
FRONT BRAKE DUAL RELAY VALVE PIPING & INSTALLATION
BRAKE MANIFOLD PIPING
BRAKE MANIFOLD COMPONENTS
BRAKE MANIFOLD 58F-60-51750
BRAKE MANIFOLD 58F-60-51750 (1)
FRONT BRAKE APPLY PIPING
REAR BRAKE APPLY PIPING 2 2
REAR BRAKE DUAL RELAY VALVE INSTALLATION
REAR BRAKE DUAL RELAY VALVE PIPING
BRAKE ACCUMULATOR INSTALLATION 1 2
PISTON ACCUMULATOR ASSM (10.0 GAL) 58B-60-20071
BRAKE ACCUMULATOR INSTALLATION 2 2
PISTON ACCUMULATOR ASSM (10.0 GAL) 58B-60-20071 (1)
PARKING BRAKE PIPING
STEERING BLEEDDOWN MANIFOLD PIPING 1 3
STEERING BLEEDDOWN MANIFOLD PIPING 2 3
STEERING BLEEDDOWN MANIFOLD PIPING 3 3
STEERING BLEEDDOWN MANIFOLD PC1493
STEERING BLEEDDOWN MANIFOLD INSTALLATION
STEERING BLEEDDOWN MANIFOLD PC1493 (1)
STEERING BLEEDDOWN MANIFOLD PC1493 (2)
STEERING ACCUMULATOR INSTALLATION
PISTON ACCUMULATOR ASSM (16
PISTON ACCUMULATOR ASSM (16 (1)
FLOW AMPLIFIER INSTALLATION
FLOW AMPLIFIER HOSE FITTINGS
FLOW AMPLIFIER PIPING
STEERING CYLINDER PIPING 1 2
STEERING CYLINDER PIPING 2 2
STEERING CYLINDER W BEARINGS 58F-41-50000
STEERING CYLINDER INSTALLATION
STEERING CYLINDER W BEARINGS 58F-41-50000 (1)
STEERING CYLINDER W BEARINGS 58F-41-50000 (2)
AUXILIARY HYDRAULIC SYSTEM 1 2
AUXILIARY HYDRAULIC SYSTEM 2 2
AUXILIARY HYDRAULIC MANIFOLD 58B-60-01771
BLADDER ACCUMULATOR ASSM (2
AUXILIARY HYDRAULIC MANIFOLD 58B-60-01771 (1)
BLADDER ACCUMULATOR ASSM (2 (1)
MAIN FRAME & RELATED PARTS
FRAME & UPRIGHTS
PIN BORE WEAR SLEEVES
LH ENGINE ACCESS LADDER & HANDRAILS
RH ENGINE ACCESS LADDER & HANDRAILS
HYDRAULIC TANK LADDER
FRAME GROUND WIRING
OPERATOR'S COMPARTMENT & CONTROL SYSTEM
CAB MOUNTING HARDWARE
CAB LIFTING HARDWARE
CAB INSULATION 1 2
CAB INSULATION 2 2
CAB INTERIOR COVERS
CAB INTERIOR TRIM
CAB EXTERNAL COVERS
CAB HYDRAULIC HOSE COVERS
CAB WINDOWS
CAB DOOR INSTALLATION
DOOR ASSEMBLY - LH 58E-54-30626
DOOR ASSEMBLY - RH 58E-54-30636
DOOR ASSEMBLY - LH 58E-54-30626 (1)
DOOR ASSEMBLY - RH 58E-54-30636 (1)
OPERATOR SEAT INSTALLATION
OPERATOR SEAT- BASIC 58B-57-00000
OPERATOR SEAT SUSPENSION ASSEMBLY 58B-98-10270
OPERATOR SEAT SUSPENSION ASSEMBLY 58B-98-10270 (1)
OPERATOR SEAT SUSPENSION ASSEMBLY 58B-98-10270 (2)
PASSENGER SEAT INSTALLATION
PASSENGER SEAT - PREMIUM 58E-57-16760
PASSENGER SEAT SUSPENSION ASSEMBLY 58E-98-11250
PASSENGER SEAT SUSPENSION ASSEMBLY 58E-98-11250 (1)
PASSENGER SEAT SUSPENSION ASSEMBLY 58E-98-11250 (2)
MANUAL HOLDER
CUP HOLDER
CAB FOOTREST
CAB FLOORMATS
CAB SUN VISOR
INSTRUMENT PANEL
GAUGE PANEL INSTALLATION
GAUGE PANEL 58E-06-11891
GAUGE PANEL 58E-06-11891 (1)
LOWER LH DASH SWITCHES
LOWER RH DASH SWITCHES
CAB INTERNAL WIRING
RADIO MODULE
RADIO ANTENNA INSTALLATION
STEERING COLUMN 1 2
STEERING COLUMN 2 2
STEERING COLUMN ASSEMBLY 58E-54-06714
STEERING COLUMN ASSEMBLY 58E-54-06714 (1)
CENTER CONSOLE MODULE - ELECTRICAL 1 2
CENTER CONSOLE MODULE - ELECTRICAL 2 2
CENTER CONSOLE MODULE - STRUCTURAL
SHIFT LEVER INSTALLATION
HOIST LEVER INSTALLATION
ACCELERATOR PEDAL INSTALLATION
VID PANEL INSTALLATION
KOMTRAX PLUS CONTROLLER INSTALLATION
SATELLITE CONTROLLER INSTALLATION
SATELLITE ANTENNA INSTALLATION
CAB ELECTRICAL - BACK WALL 1 2
CAB DIAGNOSTIC PANEL
CAB EXTERNAL WIRING CONNECTOR PLATE
CAB RETARD BRAKE LIGHTS
CAB SPEAKERS & DOME LIGHTS
WIPER WASHER TIMER DELAY MODULES
WINDSHIELD WIPER INSTALLATION
WINDSHIELD WASHER RESERVOIR INSTALLATION 1 2
WINDSHIELD WASHER RESERVOIR INSTALLATION 2 2
AIR CONDITIONING PIPING 1 3
AIR CONDITIONING PIPING 2 3
AIR CONDITIONING PIPING 3 3
A C CONDENSER INSTALLATION
HVAC INSTALLATION
HVAC DUCT ASSEMBLY 58E-98-20022
HVAC DEFROST DUCT ASSEMBLY 58E-98-20031
HVAC MODULE 58E-98-20043
HVAC MODULE INSTALLATION 1 2 58E-98-20052
HVAC DUCT ASSEMBLY 58E-98-20022 (1)
HVAC DEFROST DUCT ASSEMBLY 58E-98-20031 (1)
HVAC MODULE 58E-98-20043 (1)
HVAC MODULE INSTALLATION 1 2 58E-98-20052 (1)
HVAC MODULE INSTALLATION 2 2 58E-98-20052
HVAC EXTERNAL FILTER
HEATER HOSE INSTALLATION 1 2
HEATER HOSE INSTALLATION 2 2
HEATER AC DRAIN HOSE INSTALLATION
DECKS & HANDRAILS
DIAGONAL LADDER INSTALLATION
DIAGONAL LADDER & UPPER PLATFORM HANDRAILS
GRILLE HANDRAIL
LH LOWER PLATFORM INSTALLATION
PLATFORM ASSEMBLY 1 3
RH LOWER PLATFORM INSTALLATION
LH LOWER PLATFORM HANDRAILS
RH LOWER PLATFORM HANDRAILS
RH DROPDOWN LADDER INSTALLATION
RH DROPDOWN LADDER LATCH
DROPDOWN LADDER
LH EMERGENCY GATE & LADDER 1 2
LH EMERGENCY GATE & LADDER 2 2
RH EMERGENCY GATE & LADDER 1 2
RH EMERGENCY GATE & LADDER 2 2
LH EMERGENCY LADDER HANDRAILS
RH EMERGENCY LADDER HANDRAILS
LH DECK INSTALLATION
RH DECK INSTALLATION
CENTER DECK INSTALLATION
LH DECK HANDRAILS
RH DECK HANDRAILS 1 2
RH DECK HANDRAILS 2 2
RETARDING GRID HANDRAILS
LH MIRROR INSTALLATION
RH MIRROR INSTALLATION
GUARDS & MUD FLAPS
GRILLE INSTALLATION
GRILLE INSERTS
HYDRAULIC TANK MUD FLAPS (STANDARD)
HYDRAULIC TANK MUD FLAPS (OPTIONAL)
FUEL TANK MUD FLAP (STANDARD)
FUEL TANK MUD FLAPS (OPTIONAL)
DRIVESHAFT GUARDS
STEERING BLEEDDOWN MANIFOLD COVERS
HYDRAULIC HOSE SHIELDS
AUXILIARY HYDRAULIC MANIFOLD MUD FLAPS
CENTER DECK HEAT SHIELDS
UPRIGHT MUD FLAPS
UPRIGHT MUD FLAPS (1)
UPRIGHT MUD FLAPS (2)
UPRIGHT MUD FLAPS (3)
UPRIGHT MUD FLAPS (4)
UPRIGHT MUD FLAPS (5)
DECK MUD FLAPS
DUMP BODY MUD FLAPS 1 2
DUMP BODY MUD FLAPS 2 2
LH DECK COVERS
CAB CONNECTOR MUD FLAPS
FRONT SUSPENSION MUD FLAP
REAR SUSPENSION MUD FLAP
ISOLATION BOX WIRING COVERS
ALTERNATOR GUARD ASSEMBLY
A C COMPRESSOR GUARD ASSEMBLY (1)
FRONT SUSPENSION & STEERING LINKAGE
SPINDLE, HUB AND BRAKE ASSEMBLY 1 2 58F-32-50070
SPINDLE, HUB AND BRAKE ASSEMBLY 2 2 58F-32-50070
FRONT BRAKE ASSEMBLY 58F-32-50010
FRONT BRAKE ASSEMBLY 58F-32-50010 (1)
STEERING ARM PIN JOINTS
TIE ROD ASSEMBLY 58F-40-00210
TIE ROD ASSEMBLY 58F-40-00210 (1)
FRONT SUSPENSION INSTALLATION - FRAME
FRONT SUSPENSION ASSEMBLY 58F-50-00102
FRONT SUSPENSION INSTALLATION - STEERING ARM
FRONT SUSPENSION ASSEMBLY 58F-50-00102 (1)
REAR SUSPENSION & AXLE HOUSING
REAR SUSPENSION INSTALLATION
REAR SUSPENSION WITH BEARINGS
REAR SUSPENSION ASSEMBLY EM8846
REAR SUSPENSION ASSEMBLY EM8846 (1)
REAR AXLE HOUSING INSTALLATION
PIVOT EYE ASSEMBLY INSTALLATION
ANTI-SWAY BAR INSTALLATION
REAR AXLE HOUSING COVERS
REAR AXLE HOUSING HATCH
REAR AXLE HOUSING LADDER
PARKING BRAKE INSTALLATION
PARKING BRAKE ASSEMBLY 58F-33-00321
PARKING BRAKE ASSEMBLY 58F-33-00321 (1)
WHEELS & RIMS
FRONT WHEEL INSTALLATION
REAR WHEEL INSTALLATION - STANDARD RIM
REAR WHEEL INSTALLATION - SMART RIM
STANDARD RIM ASSEMBLY
SMART RIM ASSEMBLY - REAR INNER & FRONT
SMART RIM ASSEMBLY - REAR OUTER
TIRE INFLATION - REAR INNER & FRONT
TIRE INFLATION - REAR OUTER
TIRE INFLATION COMPONENTS - REAR EXTENSION
BODY & RELATED PARTS
BODY PIVOT 1 3
BODY PIVOT 2 3
BODY PIVOT 3 3
ROCK EJECTORS
DECALS & PLATES
SAFETY LABELS 1 7
SAFETY LABELS 2 7
SAFETY LABELS 3 7
SAFETY LABELS 4 7
SAFETY LABELS 5 7
SAFETY LABELS 6 7
SAFETY LABELS 7 7
CAB SAFETY LABELS
GRADE SPEED CHART
LUBRICATION CHART
TOOLS
SPECIAL TOOL GROUP
CUSTOM METER KIT 58B-06-00800
SUSPENSION CHARGING BLOCK KIT - FRONT
SUSPENSION CHARGING BLOCK KIT - REAR
CHARGING MANIFOLD ASSEMBLY EB1759
BODY RETENTION SLING
FLUSHING BLOCK
SMART RIM TOOL
KOMVISION TOOLS
MISCELLANEOUS & OPTIONS
AUTOMATIC LUBRICATION SYSTEM PIPING - FRONT 1 4
AUTOMATIC LUBRICATION SYSTEM PIPING - FRONT 3 4
3-PIECE INJECTOR ASSEMBLY TA4410
AUTOMATIC LUBRICATION SYSTEM PIPING - FRONT 4 4
3-PIECE INJECTOR ASSEMBLY TA4410 (1)
4-PIECE INJECTOR ASSEMBLY VW7989
5-PIECE INJECTOR ASSEMBLY TA4411
AUTOMATIC LUBRICATION SYSTEM PIPING - REAR 1 2
4-PIECE INJECTOR ASSEMBLY VW7989 (1)
5-PIECE INJECTOR ASSEMBLY TA4411 (1)
AUTOMATIC LUBRICATION SYSTEM PIPING - REAR 2 2
AUTOMATIC LUBRICATION SYSTEM PIPING - REAR 2 2 (1)
LUBRICATION PUMP SUB-ASSEMBLY 1 2
AUTO LUBE FILTER ASSEMBLY 58F-90-00620
LUBE PUMP CONTAINER ASSEMBLY 58F-98-40250
LUBE PUMP ASSEMBLY 1 3 58F-98-40240
VENT VALVE ASSEMBLY LA0912
CHECK VALVE ASSEMBLY LA1187
LUBRICATION PUMP SUB-ASSEMBLY 2 2
AUTO LUBE FILTER ASSEMBLY 58F-90-00620 (1)
LUBE PUMP CONTAINER ASSEMBLY 58F-98-40250 (1)
VENT VALVE ASSEMBLY LA0912 (1)
CHECK VALVE ASSEMBLY LA1187 (1)
LUBE PUMP ASSEMBLY 1 3 58F-98-40240 (1)
LUBE PUMP ASSEMBLY 2 3 58F-98-40240
LUBE PUMP ASSEMBLY 3 3 58F-98-40240
VENT VALVE ASSEMBLY LA0912 (2)
CHECK VALVE ASSEMBLY LA1187 (2)
REMOTE SERVICE CENTER 1 2
REMOTE SERVICE CENTER 2 2
FIRE EXTINGUISHER
PLM SCOREBOARD
RETRACTABLE LADDER INSTALLATION
RETRACTABLE LADDER HYDRAULICS
PLATFORM ASSEMBLY 1 3 (1)
PLATFORM ASSEMBLY 2 3
PLATFORM ASSEMBLY 3 3
MANIFOLD ASSEMBLY 58E-60-12010
MANIFOLD ASSEMBLY 58E-60-12010 (1)
RETRACTABLE LADDER SWITCH
RETRACTABLE LADDER DECALS
RETRACTABLE LADDER MIRROR
