Komatsu Dozer D475A-1 10001-up Parts Catalog
Type of Machine: Dozer
Model: Komatsu D475A-1 Dozer
Serial Number: 10001-up
Engine: SA8V170-1A
Number of Pages: 348 Pages
D475A-1 S N 10001-UP
ENGINE RELATED PARTS AND ELECTRICAL SYSTEM
ENGINE MOUNT
FUEL CONTROL LEVER
FUEL CONTROL LINKAGE (1 2)
FUEL CONTROL LINKAGE (2 2)
DECELERATOR PEDAL
RADIATOR MOUNT
RADIATOR AND RESERVE TANK
RADIATOR PIPING
RADIATOR WIND BREAK
COOLING FAN DRIVE MOTOR AND PIPING
OIL COOLER
OIL COOLER PIPING (1 2)(#10001-10092)
OIL COOLER PIPING (1 2)(#10093-)
OIL COOLER PIPING (2 2)
HYDRAULIC PUMP (FAN DRIVE) (1 2)
HYDRAULIC PUMP (FAN DRIVE) (2 2)
SOLENOID VALVE
THERMO VALVE
FUEL TANK
FUEL PIPING
BATTERY AND RELAY SWITCH¤ L.H.
BATTERY AND RELAY SWITCH¤ R.H.
INSTRUMENT PANEL (1 2)
INSTRUMENT PANEL (2 2)
ELECTRICAL SYSTEM (1 3)
ELECTRICAL SYSTEM (2 3)
ELECTRICAL SYSTEM (3 3)
RIPPER POINT LIGHT
MONITOR PANEL
PANEL SWITCH
RELAY BOX (1 2)
RELAY BOX (2 2)
TORQUE CONVERTOR AND TRANSMISSION
UNIVERSAL JOINT
DAMPER
DAMPER (1)
TORQUE CONVERTER (WITHOUT LOCK-UP)
TORQUE CONVERTER (1 2) (WITH LOCK-UP)
TORQUE CONVERTER (2 2) (WITH LOCK-UP)
POWER TAKE OFF (1 2) (WITHOUT LOCK-UP)
POWER TAKE OFF (2 2) (WITHOUT LOCK-UP)
PTO LUBRICATING PIPING (WITHOUT LOCK-UP)
POWER TAKE OFF (1 2) (WITH LOCK-UP)
POWER TAKE OFF (2 2) (WITH LOCK-UP)
PTO LUBRICATING PIPING (WITH LOCK-UP)
TORQUE CONVERTER VALVE (WITHOUT LOCK-UP)
TORQUE CONVERTER VALVE (1 2) (WITH LOCK-UP)
TORQUE CONVERTER VALVE (2 2) (WITH LOCK-UP)
TRANSMISSION CASE
REVERSE CLUTCH
FORWARD CLUTCH
3RD CLUTCH
2ND CLUTCH
1ST CLUTCH
TRANSMISSION VALVE (1 3)
TRANSMISSION VALVE (2 3)
TRANSMISSION VALVE (3 3)
MANUAL SELECT VALVE
HYDRAULIC PUMP (TRANSMISSION AND PTO LUBRICATION)
TRANSMISSION FILTER
TORQUE CONVERTER AND OIL COOLER PIPING
TRANSMISSION PIPING (1 2)
TRANSMISSION PIPING (2 2)
TRANSMISSION CONTROL LEVER
TRANSMISSION CONTROL LINKAGE
STEERING SYSTEM AND FINAL DRIVE
MAIN FRAME
STEERING CASE
TRANSFER CASE AND GEAR (1 2)
TRANSFER CASE AND GEAR (2 2)
BEVEL GEAR AND SHAFT
BRAKE
STEERING CLUTCH
STEERING VALVE (1 2)
STEERING VALVE (2 2)
STEERING VALVE LEVER
POWER LINE FILTER
OIL STRAINER
STEERING PIPING
CONCENTRATED PIPING (FOR OIL PRESSURE CHECK)
STEERING CONTROL LEVER
BRAKE PEDAL
PARKING BRAKE LEVER
FINAL DRIVE (1 3)
FINAL DRIVE (2 3)
FINAL DRIVE (3 3)
TRACK
TRACK FRAME
RECOIL SPRING
YOKE AND COVER
TRACK ROLLER GUARD
FRONT IDLER
TRACK ROLLER
CARRIER ROLLER
TRACK SHOE (LUBRICATE TYPE)
TRACK SHOE (LUBRICATE TYPE) (COLD TERRAIN SPEC.)
GUARD
RADIATOR GUARD
ENGINE HOOD AND COVER
FENDER
FLOOR FRAME
FLOOR PLATE
REAR COVER
UNDER GUARD
ROPS MOUNT
ROPS CANOPY
OPERATOR'S SEAT
EQUALIZER BAR
PIVOT SHAFT
STEEL CAB (BODY AND FRONT WINDOW) (1 10)
STEEL CAB (DOOR AND SIDE WINDOW) (2 10)
STEEL CAB (REAR WINDOW) (3 10)(#10001-10031)
STEEL CAB (REAR WINDOW) (3 10)(#10032-)
STEEL CAB (FURNITURE IN CAB¤ FRONT) (4 10)
STEEL CAB (FURNITURE IN CAB¤ REAR) (5 10)
STEEL CAB (INNER TOP COVER AND CAB MOUNT) (6 10)
STEEL CAB (CAB ELECTRICAL PARTS¤ FRONT) (7 10)
STEEL CAB (CAB ELECTRICAL PARTS¤ REAR) (8 10)
STEEL CAB (WINDOW WASHER) (9 10)
STEEL CAB (SHEET ASS'Y) (10 10)
ACCESSORY (FOR STEEL CAB)
COMPRESSOR AND CONDENSER RELATED PARTS
AIR CONDITIONER PIPING (HEATER LINE) (1 2)
AIR CONDITIONER PIPING (COOLER LINE) (2 2)
AIR CONDITIONER (1 2)
AIR CONDITIONER (2 2)
AIR CONDITIONER UNIT (1 2)
AIR CONDITIONER UNIT (2 2)
COMPRESSOR
DISTRIBUTOR¤ L.H.
DISTRIBUTOR¤ R.H.
CONTROL PANEL (FOR AIR CONDITIONER)
PERFORATED ENGINE SIDE COVER
WORK EQUIPMENT CONTROL SYSTEM
HYDRAULIC PUMP (WORK EQUIPMENT) (1 2)(#10001-10050)
HYDRAULIC PUMP (WORK EGUIPMENT) (1 2)(#10051-)
HYDRAULIC PUMP (WORK EQUIPMENT) (2 2)(#10001-10050)
HYDRAULIC PUMP (WORK EGUIPMENT) (2 2)(#10051-)
HYDRAULIC PUMP¤ TANK AND VALVE MOUNT
BLADE LIFT CYLINDER YOKE
HYDRAULIC TANK
HYDRAULIC VALVE (BLADE LIFT) (1 3)
HYDRAULIC VALVE (BLADE LIFT) (2 3)
HYDRAULIC VALVE (BLADE LIFT) (3 3)
HYDRAULIC VALVE (BLADE TILT AND RIPPER LOW) (1 2)
HYDRAULIC VALVE (BLADE TILT AND RIPPER LOW) (2 2)
HYDRAULIC VALVE (RIPPER HIGH)
BLADE LIFT CYLINDER (1 2)
BLADE LIFT CYLINDER (2 2)
BLADE TILT CYLINDER
BLADE TILT CYLINDER (FOR K-TYPE LINK)
RIPPER LIFT CYLINDER
RIPPER TILT CYLINDER
PIN PULLER CYLINDER
HYDRAULIC PIPING (TANK TO PUMP TO VALVE)
HYDRAULIC PIPING (BLADE LIFT LINE) (1 2)
HYDRAULIC PIPING (BLADE LIFT LINE) (2 2)
HYDRAULIC PIPING (BLADE TILT LINE) (1 2)
HYDRAULIC PIPING (BLADE TILT LINE) (2 2)
HYDRAULIC PIPING (BLADE TILT LINE) (2 2) (FOR K-TYPE LINK)
HYDRAULIC PIPING (RIPPER LIFT AND TILT LINE) (1 2)
HYDRAULIC PIPING (RIPPER LIFT AND TILT LINE) (2 2)
HYDRAULIC PIPING (RIPPER CYLINDER LINE) (1 2)
HYDRAULIC PIPING (RIPPER CYLINDER LINE) (2 2)
HYDRAULIC PIPING (PIN PULLER LINE) (FOR GIANT RIPPER)
BLADE CONTROL LEVER
BLADE CONTROL LINKAGE
RIPPER CONTROL LEVER
RIPPER CONTROL LINKAGE
BLANK PARTS
WORK EQUIPMENT
STRAIGHT TILT BLADE
STRAIGHT TILT FRAME
REINFORCED STRAIGHT TILT BLADE
REINFORCED STRAIGHT TILT FRAME
STRAIGHT TILT U-BLADE
STRAIGHT TILT FRAME (FOR STRAIGHT TILT U-BLADE)
STRAIGHT TILT U-BLADE (FOR K-TYPE LINK)
STRAIGHT TILT BLADE (FOR K-TYPE LINK)
STRAIGHT TILT FRAME (FOR K-TYPE LINK)
PUSHER PLATE (FOR STRAIGHT TILT BLADE)
PUSHER PLATE (FOR STRAIGHT TILT U-BLADE)
CUSHION DOZER BLADE
CUSHION DOZER FRAME
MULTI SHANK RIPPER (VARIABLE TYPE)
GIANT RIPPER (VARIABLE TYPE)
CUSHION BLOCK
GREASE PIPING (FOR RIPPER)
COUNTER WEIGHT AND DRAWBAR
MARK PLATE¤ TOOL AND KIT
VANDALISM PROTECTION
MARKS AND PLATES (EXCEPT JAPAN) (ENGLISH)
MARKS AND PLATES (EXCEPT JAPAN) (SPANISH-ENGLISH)
MARKS AND PLATES (EXCEPT JAPAN) (GERMAN-ENGLISH)
MARKS AND PLATES (EXCEPT JAPAN) (FRENCH-ENGLISH)
TOOL (EXCEPT JAPAN)
PERIODICAL REPLACEMENT AND SAFETY PARTS
Engine: SA8V170-1A
ENGINE MOUNT
FUEL CONTROL LEVER
DECELERATOR PEDAL
RADIATOR MOUNT
RADIATOR PIPING
RADIATOR WIND BREAK
OIL COOLER
SOLENOID VALVE
THERMO VALVE
FUEL TANK
FUEL PIPING
RIPPER POINT LIGHT
MONITOR PANEL
PANEL SWITCH
RELAY BOX (1 2)
RELAY BOX (2 2)
UNIVERSAL JOINT
DAMPER
DAMPER (1)
TRANSMISSION CASE
REVERSE CLUTCH
FORWARD CLUTCH
3RD CLUTCH
2ND CLUTCH
1ST CLUTCH
MANUAL SELECT VALVE
TRANSMISSION FILTER
MAIN FRAME
STEERING CASE
BRAKE
STEERING CLUTCH
POWER LINE FILTER
OIL STRAINER
STEERING PIPING
BRAKE PEDAL
PARKING BRAKE LEVER
FINAL DRIVE (1 3)
FINAL DRIVE (2 3)
FINAL DRIVE (3 3)
TRACK
TRACK FRAME
RECOIL SPRING
YOKE AND COVER
TRACK ROLLER GUARD
FRONT IDLER
TRACK ROLLER
CARRIER ROLLER
GUARD
RADIATOR GUARD
FENDER
FLOOR FRAME
FLOOR PLATE
REAR COVER
UNDER GUARD
ROPS MOUNT
ROPS CANOPY
OPERATOR'S SEAT
EQUALIZER BAR
PIVOT SHAFT
COMPRESSOR
DISTRIBUTOR¤ L.H.
DISTRIBUTOR¤ R.H.
HYDRAULIC TANK
BLADE TILT CYLINDER
PIN PULLER CYLINDER
BLADE CONTROL LEVER
BLANK PARTS
WORK EQUIPMENT
STRAIGHT TILT BLADE
STRAIGHT TILT FRAME
CUSHION DOZER BLADE
CUSHION DOZER FRAME
CUSHION BLOCK
TOOL (EXCEPT JAPAN)
- KOMATSU Fault Codes
