Auto47
Manager
48
27,774
Komatsu Bulldozers D65EX-15 SN 67001-UP Parts Catalog
Type of Machine: Bulldozer
Model: Komatsu D65EX-15 Bulldozer
Serial Number: 67001-UP
Number of Pages: 559 Pages
KOMATSU D65EX-15 S N 67001-UP
ENGINE RELATED PARTS
AIR CLEANER CAP (FOR PRE CLEANER)
AIR CLEANER CAP
EXHAUST PIPE (ELBOW TYPE)
ENGINE SPARE PARTS
CAUTION PLATE
ENGINE MOUNT
ENGINE WIRING
DAMPER
COOLING SYSTEM
COOLING (RADIATOR AND OIL COOLER)
COOLING (MOUNT AND RESERVE TANK)
COOLING (SHROUD AND FAN)
COOLING (GUARD)
COOLING (WASHER TANK)
COOLING (FUN GUARD)
FUEL TANK AND RELATED PARTS
FUEL TANK
FUEL TANK (LAMP WIRING)
FUEL LINE
FUEL LINE (FOR POOR FUEL)
FUEL LINE (FOR TORIMMING DOZER)
FUEL LINE (FOR POOR FUEL¤ TRIMMING SPEC.)
ADDITIONAL FUEL STRAINER
ELECTRICAL SYSTEM
VEHICLE WIRING
VEHICLE WIRING (ENGINE AND T M WIRING CLAMP)
VEHICLE WIRING (REAR WIRING CLAMP)
KOMTRAX WIRING
KOMTRAX LESS WIRING
KOMTRAX WIRING (ANGLE SENSOR)
KOMTRAX WIRING (ANTENNA)
VEHICLE LAMP
FRONT AND REAR WORK LAMP (ADDITIONAL)
ADDITIONAL REAR LAMP
BACK-UP ALARM
POWER TRAIN AND FINAL DRIVE
UNIVERSAL JOINT
POWER LINE MOUNT
POWER LINE MOUNT (1)
H.S
H.S (1)
H.S (2)
H.S (3)
H.S (4)
H.S (5)
H.S (6)
H.S (7)
H.S (8)
H.S (9)
TRANSMISSION MOUNT
POWER LINE (PUMP)
POWER LINE (PUMP REALTED PARTS)
POWER LINE (SUPPORT)
POWER LINE (WIRING)
TORQUE CONVERTER (BARE)
TORQUE CONVERTER (CASE)
TORQUE CONVERTER (SCAVENGING PUMP)
TORQUE CONVERTER (POWER TAKE OFF)
TORQUE CONVERTER (FILTRATION AND SUPPORT)
TRANSMISSION (1ST HOUSING)
TRANSMISSION (2ND¤ 3RD¤ FOWARD AND REVERSE HOUSING)
TRANSMISSION (CARRIER) (1 2)
TRANSMISSION (CARRIER) (2 2)
TRANSMISSION (CASE)
TRANSMISSION (INPUT AND OUTPUT SHAFT)
TRANSMISSION (FILTER AND HARNESS)
TRANSMISSION VALVE (UPPER VALVE)
TRANSMISSION VALVE (LOWER VALVE AND MOUTING)
TRANSMISSION (MAIN VALVE)
TRANSMISSION (COVER)
TRANSMISSION (LUBRICATION OIL INLET)
FINAL DRIVE (MOUNT)
FINAL DRIVE (BEARING)
FINAL DRIVE (CARRIER)
FINAL DRIVE (SPROCKET AND HUB)
POWER LINE (COOLER)
POWER LINE (COOLER OIL LINE) (FOR TRIMMING DOZER)
POWER LINE (CONCENTRATED PIPING)
P L OIL LINE (BLOCK)
TRAVEL CONTROL (BREAKE ROD)
TRAVEL CONTROL (PARKING CABLE)
HYDRAULIC SYSTEM
HYDRAULIC PUMP (MOUNT)
HYDRAULIC PUMP LINE (SUCTION AND DELIVERY)
HYDRAULIC PUMP LINE (FILTER RETURN AND LOAD SENSING)
HYDRAULIC PUMP LINE (H.S.S. MOTOR LINE)
HYDRAULIC PUMP LINE (FAN PUMP)
HYDRAULIC PUMP LINE (FAN MOTOR LINE)
HYDRAULIC PUMP LINE (REDUCING VALVE)
HYDRAULIC PUMP LINE (DRAIN BLOCK)
LIFT CYLINDER LINE
LIFT CYILINDER LINE (FOR TRIMMING DOZER)
LIFT CYLINDER LINE (REGULATOR VALVE)
LIFT CYLINDER LINE (REGULATOR VALVE) (FOR TRIMMING DOZER)
LIFT CYLINDER LINE (VALVE)
TILT LINE (TILT VALVE SIDE)
ANGLE PLUG
TRIMMING LINE
TILT LINE (TRACK FRAME SIDE)
TILT LINE (TRACK FRAME SIDE) (WIDE GAUGE SPEC.)
TRIMMING LINE (TRACK FRAME SIDE)
REAR HYDRAULIC LINE (RIPPER PIPING)
REAR HYDRAULIC LINE (RIPPER BRACKET)
MAIN FRAME AND RELATED PARTS
MAIN FRAME
MAIN FRAME (FOR TRIMMING DOZER)
EQUALIZER BAR AND PIVOT SHAFT
EQUALIZER BAR AND PIVOT SHAFT (FOR LONG TRACK)
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
OPERATOR'S SEAT (RECLINING TYPE) (FABRIC SEAT)
OPERATOR'S SEAT (RECLINING TYPE) (FABRIC SEAT) (HIBACK)
OPERATOR'S SEAT (TURN AND RECLINING TYPE) (FABRIC SEAT) (HIBACK)
OPERATOR'S SEAT (RECLINING TYPE) (LEATHER SEAT) (HIBACK)
OPERATOR'S SEAT (RECLINING TYPE) (FABRIC SEAT) (WITH HEAD REST)
OPERATOR'S SEAT (TURN AND RECLINING TYPE) (FABRIC SEAT) (WITH HEAD REST)
OPERATOR'S SEAT (TURN AND RECLINING TYPE) (FABRIC SEAT) (HIBACK) (WITH HEAD REST)
SEAT BELT (FOR SUSPENSION SEAT) (FOR RETRACTION)
PROTECTION SEAT
OPERATOR'S CAB (BODY)
OPERATOR'S CAB (DOOR AND DOOR LOCK)
OPERATOR'S CAB (DOOR) (DUMPER¤ WINDOW¤ WIPER)
OPERATOR'S CAB (DOOR OPEN LOCK BRACKET)
OPERATOR'S CAB (DOOR OPEN LOCK LATCH)
OPERATOR'S CAB (WINDOW)
OPERATOR'S CAB (SASH)
OPERATOR'S CAB (GRIP)
OPERATOR'S CAB (ELECTRIALC EQUIPMENT) (SWITCH¤ ROOM LAMP¤ WIPER)
OPERATOR'S CAB (WASHER HOSE)
OPERATOR'S CAB (RADIO) (FOR JAPAN)
OPERATOR'S CAB (RADIO MOUNT BRACKET) (RADIO ADD ON)
OPERATOR'S CAB (INSIDE COVER)
OPERATOR'S CAB (MIRROR)
OPERATOR'S CAB (AIR-CONDTIONER DUCT)
OPERATOR'S CAB (INSTALLATION PARTS)
OPERATOR'S CAB (ENVELOPE PARTS) (1 2)
OPERATOR'S CAB (ENVELOPE PARTS) (2 2)
OPERATOR'S CAB (FOPS PLATE)
FLOOR MAT (WITH CAB)
FLOOR MAT (WITHOUT CAB)
REAR VIEW MIRROR
ROPS GUARD (WITH CAB) (FOR JAPAN AND EU)
ROPS GUARD (WITHOUT CAB)
AIR CONDITIONER (CONDENSER)
AIR CONDITIONER (FILTER ASS'Y)
AIR CONDITIONER (PIPING BRACKET)
AIR CONDITIONER (COMPRESSOR MOUNT AND PULLEY COVER)
AIR CONDITIONER (HEATER LINE)
AIR CONDITIONER (HEATER LINE BRACKET)
HEATER (HEATER LINE BRACKET)
AIR CONDITIONER (COMPRESSOR)
CUP HOLDER
FLOOR FRAME (FRAME AND MOUNT) (WITH CAB)
FLOOR FRAME (TRAVEL CONTROL) (LEVER AND CONSOLE L.H.)
FLOOR FRAME (TRAVEL CONTROL) (LIFT)
FLOOR FRAME (BRADE CONTROL) (WITH CAB)
FLOOR FRAME (BRADE CONTROL) (WITHOUT CAB)
FLOOR FRAME (BRADE CONTROL) (ANGLE DOZER) (WITH CAB)
FLOOR FRAME (BRADE CONTROL) (ANGLE DOZER) (WITHOUT CAB)
FLOOR FRAME (BRADE CONTROL) (P.P
FLOOR FRAME (BRADE CONTROL) (P.P (1)
FLOOR FRAME (BRADE CONTROL) (P.P (2)
FLOOR FRAME (BLADE LOCK LEVER)
FLOOR FRAME (TRANSMISSION LOCK LEVER)
FLOOR FRAME (PARKING BRAKE CABLE)
FLOOR FRAME (H.S
FLOOR FRAME (ELECTIRC EQUIOPMENT AND RELAY BOX)
FLOOR FRAME (FLOOR WIRING HARNESS) (1 3)
FLOOR FRAME (FLOOR WIRING HARNESS) (2 3)
FLOOR FRAME (FLOOR WIRING HARNESS) (3 3)
FLOOR FRAME (WASHER HOSE)
FLOOR FRAME (BRAKE PEDAL)
FLOOR FRAME (FUEL CONTROL)
FLOOR FRAME (MOUNT)
FLOOR FRAME (BLIND) (WITHOUT CAB)
DASH BOARD (FOR AIR CONDITIONER AND BOX) (1 2)
DASH BOARD (FOR AIR CONDITIONER AND BOX) (1 2) (FOR HEATER)
DASH BOARD (FOR AIR CONDITIONER AND BOX) (2 2)
DASH BOARD (FOR AIR CONDITIONER BOX AND PANEL) (1 4)
DASH BOARD (FOR AIR CONDITIONER BOX AND PANEL) (2 4)
DASH BOARD (FOR AIR CONDITIONER BOX AND PANEL) (3 4)
DASH BOARD (FOR AIR CONDITIONER BOX AND PANEL) (4 4)
DASH BOARD (DECAL)
AIR CONDITIONER UNIT
BLOWER (FOR AIR CONDITIONER)
FLOOR COVER
ARM REST COVER (WITH CAB)
ARM REST COVER (FOR RIPPER) (WITH CAB)
ARM REST COVER (COVER R.H.) (WITHOUT CAB)
ARM REST COVER (COVER R.H.) (FOR RIPPER) (WITHOUT CAB)
ARM REST COVER (COVER L.H.)
ARM REST COVER (COVER L.H.) (FOR HANDRAIL)
REAR WORK EQUIPMENT CONTROL (FOR RIPPER)
REAR WORK EQUIPMENT CONTROL (FOR RIPPER) (WITHOUT CAB)
GUARD
LIFT CYLINDER SUPPORT
RADIATOR MASK
RADIATOR MASK (FOR REINFORCED TYPE)
RADIATOR MASK (FOR TRIMMING DOZAR)
FRONT GUARD (ENGINE HOOD) (WITH CAB) (EU SILENT SPEC.)
FRONT GUARD (ENGINE HOOD) (WITH CAB) (WITH RAIN CAP)
FRONT GUARD (ENGINE HOOD) (WITH RAIN CAP)
FRONT GUARD (ENGINE SIDE COVER) (WITH CAB) (EU SILENT SPEC. AND WITH RAIN CAP)
FRONT GUARD (REAR SUPPORT AND RADIATOR COVER) (WITH CAB)
ENGINE SIDE COVER (WINDOW WASHER TANK) (FOR CAB)
ENGINE SIDE COVER (LOWER)
ENGINE SIDE COVER (LOWER) (FOR POOR FUEL)
ADDITIONAL FRONT GUARD
FENDER (ADDITIONAL FUEL STRAINER AND BATTERY WIRING)
FENDER (ADDITIONAL FUEL STRAINER AND BATTERY WIRING) (WITH LARGE BATTERY)
FENDER (ADDITIONAL FUEL STRAINER AND BATTERY WIRING) (WITH LARGE BATTERY) (FOR TRRIMING DOZER)
FENDER (HYDRAULIC TANK)
FENDER (HYDRAULIC CONTROL VALVE)
FENDER (HYDRAULIC CONTROL VALVE) (FOR RIPPER)
FENDER (HYDRAULIC CONTROL VALVE) (FOR TRIMMING DOZER)
FENDER (LATERAL MOUNT) (WITH CAB)
FENDER (P.P
FENDER (P.P (1)
FENDER (P.P (2)
FENDER (HOOD)
FENDER (FILTER)
FENDER (HANDLE)
FENDER (ROPS BRACKET)
FENDER (ROPS BRACKET) (FOR TRIMMING DOZER)
FENDER (REAR GUARD AND FILTER MOUNTING)
FENDER (HOOD MOUNTING)
FENDER (BRACKET MOUNTING)
FENDER (COVER)
FENDER COVER (FILTER AND BATTERY COVER)
FENDER COVER (FILTER AND BATTERY COVER) (WITH HANDRAIL)
FENDER COVER (FILTER AND BATTERY COVER) (WITH HANDRAIL) (FOR CANOPY)
FENDER COVER (FILTER COVER MOUNTING)
FENDER COVER (FILTER COVER MOUNTING) (WITH HANDRAIL)
FENDER COVER (FILTER COVER MOUNTING) (WITH HANDRAIL) (FOR CANOPY)
FENDER COVER (HOLDER)
REAR COVER
REAR COVER (FOR RIPPER)
UNDER GUARD (REINFORCED TYPE)
UNDER GUARD (HINGE TYPE)
UNDER GUARD (HINGE TYPE) (FOR TRIMMING DOZER)
FRONT HOOK
UNDER CARRIAGE
FRONT IDLER
FRONT IDLER (FOR TRIMMING DOZER)
IDLER CUSHION
IDLER CUSHION (FOR TRIMMING DOZAR)
TRACK ROLLER
TRACK ROLLER (FOR LONG TRACK)
CARRIER ROLLER
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (510MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (560MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (610MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (610MM WIDE) (LONG TRACK SPEC.)
TRACK SHOE (MASTER PIN TYPE) (SINGLE GROUSER) (510MM WIDE)
TRACK SHOE (MASTER PIN TYPE) (SINGLE GROUSER) (560MM WIDE)
TRACK SHOE (MASTER PIN TYPE) (SINGLE GROUSER) (610MM WIDE)
TRACK SHOE (MASTER PIN TYPE) (SINGLE GROUSER) (660MM WIDE)
TRACK SHOE (MASTER PIN TYPE) (HEAVY DUTY) (510MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (660MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (TRIPLE GROUSER WITH HOLE)(510MM WID E)
TRACK SHOE (LUBRICATE TYPE) (HEAVY DUTY) (510MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SNOW TYPE) (510MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (510MM WIDE) (LONG TRACK SPEC.)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (560MM WIDE) (LONG TRACK SPEC.)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (510MM WIDE) (WITH A.R. LINKS)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (560MM WIDE) (WITH A.R. LINKS)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (610MM WIDE) (WITH A.R. LINKS)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (660MM WIDE) (WITH A.R. LINKS)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (510MM WIDE) (WITH A.R. LINKS) (LONG TRACK SPEC.)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (560MM WIDE) (WITH A.R. LINKS) (LONG TRACK SPEC.)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (610MM WIDE) (WITH A.R. LINKS) (LONG TRACK SPEC.)
TRACK SHOE (LUBRICATE TYPE) (SINGLE GROUSER) (810MM WIDE) (WIDE GAUGE)(#67014-)
TRACK SHOE (LUBRICATE TYPE) (HEAVY DUTY) (560MM WIDE)
TRACK SHOE (LUBRICATE TYPE) (HEAVY DUTY) (610MM WIDE)
TRACK FRAME
TRACK FRAME (FOR LONG TRACK)
TRACK FRAME (FOR TRIMMING DOZER)
ROLLER GUARD
ROLLER GUARD (FULL GUARD)
ROLLER GUARD (FOR LONG TRACK)
ROLLER GUARD (FULL GUARD) (FOR LONG TRACK)
WORK EQUIPMENT
STRAIGHT FRAME
STRAIGHT FRAME (SEMI-U) (3.0M)
ANGLE FRAME
H-FRAME (FOR TRIMMING DOZER)
ARM AND BRACE (TILT DOZER)
ARM AND BRACE (ANGLE DOZER) (REINFORCED TYPE)
ARM AND BRACE (SEMI-U) (TILT DOZER) (3M)
ARM AND BRACE (SEMI-U) (TILT DOZER) (3M) (FIXED TYPE)
STRAIGHT BLADE
STRAIGHT BLADE (SEMI-U)
ANGLE BLADE (REINFORCED TYPE)
STRAIGHT BLADE (3M) (SEMI-U)
TRIMMING BLADE
LIFT CYLINDER
LIFT CYLIDNER (FOR LONG TRACK)
LIFT CYLINDER (FOR TRIMMING DOZER)
LIFT CYLINDER (CYLINDER FIXING PARTS)
TILT CYLINDER
TRIMMING CYILINDER
TILT DOZER LINE
TILT DOZER LINE (SEMI-U) (3M)
TRIMMING DOZER LINE
RIPPER (RIGED TYPE)
RIPPER CYLINDER
RIPPER CYLINDER PLUG
DRAWBAR
DRAWBAR (RIGID TYPE)
DRAWBAR (RIGID TYPE) (FOR SCRAPER)
TRIMMING SPEC. ADD. PARTS
MARKS AND PLATES
MARKS AND PLATES (JAPANESE)
MARKS AND PLATES (JAPANESE) (FOR ANGLE DOZER)
MARKS AND PLATES (JAPANESE) (FOR TRIMMING DOZER)
MARK AND PLATES (LARGE)
GRAVITY MARKS
ACCUMULATOR PLATES
ROPS PLATES
NAME PLATES (AIR-CON)
ACCESSORY
SPARE PARTS
TOOL
SERVICE KIT AND COMPONENT PARTS
SERVICE KIT
SHOE BOLT AND NUT SERVICE KIT
TRACK LINK (MASTER PIN TYPE) (SUPPLY PARTS)
TRACK LINK (LUBRICATE TYPE) (SUPPLY PARTS)
TRACK LINK (LUBRICATE TYPE) (WITH ABRASION RESISTANCE LINK) (SUPPLY PARTS)
TRACK LINK (LUBRICATE TYPE) (SUPPLY PARTS) (LONG TRACK TYPE)
TRACK LINK (LUBRICATE TYPE) (ABRASION RESISTANCE LINK AND LONG TRACK TYPE) (SUPPLY PARTS)
HSS PUMP (1 6)
HSS PUMP (2 6)
HSS PUMP (3 6)
HSS PUMP (4 6)
HSS PUMP (5 6)
HSS PUMP (6 6)
FAN PUMP (1 5)
FAN PUMP (2 5)
FAN PUMP (3 5)
FAN PUMP (4 5)
FAN PUMP (5 5)
HYDRAULIC PUMP (POWER LINE) (1 2)
HYDRAULIC PUMP (POWER LINE) (2 2)
LIFT CYLINDER (1)
LIFT CYLIDNER (FOR LONG TRACK) (1)
LIFT CYLINDER (FOR TRIMMING DOZER) (1)
TILT CYLINDER (1)
TRIMMING CYLINDER
RIPPER CYLINDER (1)
HSS MOTOR (1 2)
HSS MOTOR (2 2)
FAN MOTOR (1 2)
FAN MOTOR (2 2)
CONTROL VALVE (3-SPOOL) (1 7)
CONTROL VALVE (3-SPOOL) (2 7)
CONTROL VALVE (3-SPOOL) (3 7)
CONTROL VALVE (3-SPOOL) (4 7)
CONTROL VALVE (3-SPOOL) (5 7)
CONTROL VALVE (3-SPOOL) (6 7)
CONTROL VALVE (3-SPOOL) (7 7)
CONTROL VALVE (4-SPOOL) (1 8)
CONTROL VALVE (4-SPOOL) (2 8)
CONTROL VALVE (4-SPOOL) (3 8)
CONTROL VALVE (4-SPOOL) (4 8)
CONTROL VALVE (4-SPOOL) (5 8)
CONTROL VALVE (4-SPOOL) (6 8)
CONTROL VALVE (4-SPOOL) (7 8)
CONTROL VALVE (4-SPOOL) (8 8)
CONTROL VALVE (4-SPOOL) (1 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (2 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (3 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (4 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (5 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (6 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (7 8) (FOR TRIMMING DOZER)
CONTROL VALVE (4-SPOOL) (8 8) (FOR TRIMMING DOZER)
PPC VALVE (FOR BLADE CONTROL)
PPC VALVE (FOR RIPPER CONTROL)
PILOT VALVE
ELECTRIC LEVER
Komatsu, Bulldozer, s D65EX-15 SN 67001-UP, Parts Catalog,
