Komatsu Bulldozers D155A-3 60001-UP Spare Parts Catalog
Type of Machine: Bulldozer
Model: Komatsu D155A-3 Bulldozer
Serial Number: 60001-UP
Number of Pages: 651 Pages
Engine Related Parts
Engine Mount
Engine Mount (Pre Heater)
Exhaust Pipe
Exhaust Pipe¤ Short
Wiring¤ Engine
Wiring¤ Engine (For Gauge Type Panel)
Damper
Air Compressor Piping (1 2)
Air Compressor Piping (1 2) (Sandy And Dusty Terrain Spec.)(#61055-)
Air Compressor Piping (2 2)
Air Compressor Related Parts
Air Compressor(#60001-.)
Air Compressor(#.-)
Air Compressor (Sandy And Dusty Terrain Spec.)(#61055-.)
Air Compressor (Sandy And Dusty Terrain Spec.)(#.-)
Heater Line
Scraper Sub Pump
Reserve Tank
Reserve Tank And Dust Proof Grid
Cooling Line
Fan Guard (With Air Conditioner)
Fan Guard (Without Air Conditioner)
Oil Cooler Line
Hydraulic Oil Line
Hydraulic Oil Line (For Syria)(#61200-)
Fuel Tank And Related Parts
Fuel Tank (Quick Charge)
Fuel Tank (Large Capacity Type)
Fuel Line
Fuel Line (With Water Separator)
Battery (Ns200 Dry)
Battery (C200 Dry)
Head Lamp (With Sweeper)(#60755-)
Back Up Alarm
Power Train And Final Drive
Universal Joint
Bevel And Shaft
Clutch And Brake (1 2)
Clutch And Brake (2 2)(#60001-(153120))
Clutch And Brake (2 2)(#(153121)-)
Steering Case (1 2)
Steering Case (2 2)
Torque Converter Shaft
Power Line Piping
P0wer Line Piping (1 2)
P0wer Line Piping (2 2)
Concentrated Piping
Noise Absorption
Control
Steering Valve (1 3)
Steering Valve (2 3)
Steering Valve (3 3)
Valve Body
Power Line Mount
Torque Converter (Bear Torque Converter)
Torque Converter (Case And Piping)
Torque Converter (Power Take Off Gear)
Transmission (1st¤2nd¤ And 3rd Clutch)
Transmission (Forward And Reverse Clutch)
Transmission (1st¤2nd¤ And 3rd Carrier)
Transmission (Forward And Reverse Carrier)
Transmission (Case)
Transmission (Input And Output Shaft)
Transmission (Quick Return Valve)(#60001-(51070))
Transmission (Quick Return Valve)(#(51071)-)
Transmission (Modulating Valve)(#60001-(51070))
Transmission (Modulating Valve)(#(51071)-)
Transmission (Main Relief Valve)
Transmission (Control Valve Cover And Lever)
Transmission (Gasket And Bracket)
Final Drive¤ L.H. (Gear Case)
Final Drive¤ L.H. (Sprocket Hub And Carrier)
Final Drive¤ R.H. (Gear Case)
Final Drive¤ R.H. (Sprocket Hub And Carrier)
Power Line Piping (1)
Power Train Oil Line
Power Line Filter
Additional Oil Line
Power Line Mount (1)
Power Line Sub Control
Wiring (Power Line) (For Electric Monitor System Panel)
Wiring (Power Line) (For Gauge Type Panel)
Wiring (Power Line) (For Pitch Dozer)
Wiring (Power Line) (Pre Heater)
Ripper Blank Parts
Hydraulic Tank (With Sweeper)(#60755-)
Pitch Valve (C B)
Hydraulic Pump Line
Brank Parts (With Variable Ripper)
Brank Parts (Ripper Drain)
Blade Lift Line (Main Frame)
Blade Lift Line (Block To Cylinder) (Radiator Guard)
Blade Lift Line (Main Frame To Block) (Radiator Guard)
Blade Tilt Line
Ripper Line (Main Frame)
Ripper Line (Main Frame) (For Syria)(#61200-)
Ripper Block And Piping
Pin Puller Valve (For Giant Ripper)
Scraper Sub Pump Piping
Main Frame And Related Parts
Main Frame
Main Frame (Noise Suppression Spec.For Ec) (Dynamic)(#60753-)
Power Line Gauge Piping
Power Line Gauge Piping (For Syria)(#61200-)
Equalizer Bar
Pivot Shaft
Pivot Shaft (For Pitch Dozer)
Operator's Compartment And Control System
Operator's Seat (Turn And Reclining Type) (Fabric Seat)(#60001-60203)
Operator's Seat (Turn And Reclining Type) (Leather Seat)(#60001-60203)
Operator's Seat (Turn And Reclining Type) (Fabric Seat) (With Head Rest)(#60001-60203)
Turn Table(#60001-60203)
Operator's Seat (Turn And Reclining Type) (Leather Seat)(#60204-)
Operator's Seat (Turn And Reclining Type) (Fabric Seat) (With Head Rest)(#60204-)
Operator's Seat (Turn And Reclining Type) (Fabric Seat)(#60204-)
Operator's Seat Assembly (Turn And Reclining Type) (Leather Seat)(#60204-)
Operator's Seat Assembly (Turn And Reclining Type) (Fabric Seat)(#60204-)
Turn Table(#60204-)
Arm Rest
Arm Rest (Without Ripper)
Arm Rest (With Ripper) (Pre Heater)
Seat Belt (For Kab)
Cab (Body)
Cab (Door And Door Lock)
Cab (Door Open Lock)
Cab (Door Open Lock) (Pre Heater)
Cab (Sash And Grip)
Cab (Roof Lining And Garnish) (For Am Radio)
Cab (Roof Lining And Garnish) (For Am-Fm Radio)
Cab (Room Lamp And Wiring)
Cab (Wiper)
Cab (Am Radio)
Cab (Radio Less)
Cab (Accessory)
Cab (Front Side Work Lamp)
Cab (Rear Side Work Lamp)
Cab (Mount Bolt And Seal)
Floor Mat
Floor Seat (Without Cab)
Back Mirror
Back Mirror (Tbg Spec.)
Sunvisor
R.O.P.S. Guard
R.O.P.S. Guard (Tbg Spec.)
R.O.P.S. Canopy (Steel Type)
R.O.P.S. Guard (With Sweeper)(#60755-)
R.O.P.S. Guard (With Beacon)
Additional Head Lamp (With Beacon)(#61069-)
Rops Guard (With Beacon And Ec.)
Additional Work Lamp (For R.O.P.S. Guard)
Extinguisher
First Aid Box
Thermos Bottle
Lunch Box
Ripper P.P.C. Piping
Brank Parts (Without Ripper)
Floor Frame
Floor Frame (Without Cab)
Floor Frame (Pre Heater)
Floor Frame (For Syria)(#61200-)
Floor Frame Wiring (For Syria)(#61200-)
Steering And Transmission Control Lever (For Syria)(#61200-)
Steering Control Shaft (For Syria)(#61200-)
Parking Lever (For Syria)(#61200-)
Fuel Control Lever (For Syria)(#61200-)
Pedal Cover (Steering Brake Pedal) (For Syria)(#61200-)
Pedal Cover (Decelerator Padal And Linkage) (For Syria)(#61200-)
Travel Control Knob (For Syria)(#61200-)
Blade Control (Tilt Dozer) (1 2) (For Syria)(#61200-)
Blade Control (Tilt Dozer) (2 2) (For Syria)(#61200-)
Arm Rest (With Ripper) (For Syria)(#61200-)
Ripper P.P.C. Piping (For Syria)(#61200-)
Connector And Cap (Without Pin Puller) (For Syria)(#61200-)
Blade Control Lever And Knob (For Tilt Dozer) (For Syria)(#61200-)
Work Equipment Control (For Syria)(#61200-)
Power Line Sub Control (For Syria)(#61200-)
Rear Floor Mount
Rigid Mount (Without Suspension)
Rear Floor Mount(#61200-)
Rear Floor Mount (With Suspension)
Floor Frame Cover(#61200-)
Front Floor Mount
Dashboard (Air Conditioner)
Dashboard (Heater)
Dashboard (Without Cab) (Without Side Cover)
Dashboard (Without Air Con.) (With Side Cover) (Duct And Cover)
Dashboard (Without Cab And Side Cover) (For Gauge Type Panel)
Dashboard (Without Cab) (With Side Cover)
Dashboard (Duct And Cover)
Dashboard (Without Air Con.) (With Side Cover) (Panel And Wiring)
Dashboard (Panel And Wiring)
Dashboard (Mounting)
Air Conditioner Unit (Evaporator And Radiator)
Air Conditioner Unit (Thermostat And Drain Hose)
Heater Unit
Blower (For Air Conditioner)
Monitor Panel
Panel Cover Lock
Floor Frame Wiring
Floor Frame Wiring (Pre Heater)
Parking Lever
Fuel Control Lever
Travel Control Knob And Governor Rod(#61200-)
Pin Puller Switch
Blade Control¤ Tilt And Pitch Dozer(#60001-60478)
Blade Control¤ Tilt And Pitch Dozer(#60479-)
Blade Control¤ Angle Dozer (P.P.C. Valve And Piping)(#60001-60478)
Blade Control¤ Angle Dozer (P.P.C. Valve And Piping)(#60479-)
Blade Control¤ Tilt Dozer
Blade Control¤ Angle Dozer (Lock Lever And Valve)
Blade Control¤ Pitch Dozer
Scraper Control
Ripper Control
Window Washer
Guard
Radiator Guard
Radiator Guard (With Sweeper)(#60755-)
Radiator Guard (Noise Suppression Spec.For Ec) (Dynamic)(#60753-)
Hydraulic Oil Cooler
Fan (Blower)
Fan (Blower) (Noise Suppression Spec.For Ec) (Dynamic)(#60753-)
Fan (Reversible)
Lift Cylinder Support
Lift Cylinder Less
Head Lamp
Head Lamp (With Sweeper)(#60755-) (1)
Radiator Mask
Radiator Mask (Noise Suppression Spec. For Ec)(#60001-60752)
Radiator Mask (Noise Suppression Spec. For Ec) (Dynamic)(#60753-)
Radiator Mask (Perforated Type)
Radiator Mask (Full Lattice Type)
Engine Hood (With Air Conditioner)
Engine Hood (Without Air Conditioner) (Without Side Cover) (1 2)
Engine Hood (With Air Conditioner) (Without Side Cover) (1 2)
Engine Hood (With Air Conditioner) (Closed Type)
Engine Hood (Without Air Con.) (Closed Type Side Cover)
Engine Hood (Without Air Con.) (Perforated Type Side Cover)
Engine Hood (With Air Con) (Perforated Type Side Cover)
Engine Hood (With Air Conditioner) (Perforated And Precleaner)
Engine Hood (With Air Conditioner) (Noise Suppression Spec.) (Dynamic)(#60753-)
Engine Hood (Without Air Con.)(Closed Type Side Cover)(Pre Heat)
Engine Hood (With Air Conditioner And Precleaner) (Without Side Cover)(#60001-61273)
Engine Hood (With Air Conditioner And Precleaner) (Without Side Cover)(#61274-)
Engine Hood (With Air Conditioner And Precleaner) (Clsed Type Side Cover)(#60001-61273)
Engine Hood (With Air Conditioner And Precleaner) (Closed Type Side Cover)(#61274-)
Side Cover¤ L.H. (Perforated Type)
Engine Hood (Without Air Conditioner) (Without Side Cover) (2 2)
Engine Hood (With Air Conditioner) (Without Side Cover) (2 2)
Side Cover¤ L.H. (With Air Conditioner) (Cold Weather Spec.)
Side Cover¤ L.H. (Without Air Conditioner) (Closed Type) (Pre Heater)
Side Cover¤ L.H. (Noise Suppression Spec. Ec)(#60001-60752)
Side Cover¤ L.H. (Noise Suppression Spec.)(#60753-)
Duct And Water Line (Pre Heater)
Side Cover¤ R.H. (With Air Conditioner)
Side Cover¤ R.H. (With Air Conditioner) (Closed Type)
Side Cover¤ R.H. (Without Air Con.) (Closed Type)
Side Cover¤ R.H. (Without Air Con.) (Perforated Type)
Side Cover¤ R.H. (Noise Suppression Spec. Ec)(#60001-60752)
Side Cover¤ R.H. (Noise Suppression Spec.)(#60753-)
Side Cover¤ R.H. (Without Air Conditioner) (Pre¤Heater) (Closed Type)
Hood Mount (With Cab)
Pre Screen Cover
Pre Cleaner Cover(#61073-)
Pre Cleaner Cover (With Perfo Side Cover)(#61073-)
Battery Holder
Fender (With Sweeper)(#60755-)
Wiring (Fender)
Wiring (Fender) (Pre Heater)
Fender
Fender (Pre Heater)
Hood Mount (Fender)
Battery (Ns200 Wet)
Battery (C200 Wet)
Hydraulic Tank
Hydraulic Tank Line
C.L.S.S. Valve
Brank Parts (With Variable Ripper) (1)
P.P.C. Valve Line
P.P.C. Valve Line (Pre Heater)
Charge Line (C B)
Coolant Pre Heater (1 2)
Coolant Pre Heater (2 2)
Fender Related
Fender Cover
Fender Cover (Pre Heater)
Rear Lamp
Coolant Pre Heater (Cover)
Rear Cover
Fuel Tank And Hydraulic Tank Cover (With Sweeper)(#60755-)
Rops Mount
Rops Mount (For Syria)(#61200-)
Under Guard
Under Guard (Dust Disposal Spec.)
Under Guard (Noise Suppression For Ec) (Dynamic)(#60753-)
Under Guard (Pre Heater)
Under Carriage
Front Idler(#60001-.)
Front Idler(#.-)
Idler Cushion
Track Roller
Track Bogie
Carrier Roller
Track Shoe (Dry Type) (Single Grouser)
Track Shoe (Dry Type) (Single Grouser) (Heavy-Duty)
Track Shoe (Lubricate Type) (Master Link 4 Place Type)(#60001-61075)
Track Shoe (Lubricate Type) (Master Link 4 Place Type) (Heavy-Duty)(#60001-61075)
Track Shoe (Lubricate Type) (560mm Wide) (Master Link 2 Place Type)(#61076-)
Track Shoe (Lubricate Type) (610mm Wide) (Master Link 2 Place Type)(#61076-)
Track Shoe (Lubricate Type) (660mm Wide) (Master Link 2 Place Type)(#61076-)
Track Shoe (Lubricate Type) (710mm Wide) (Master Link 2 Place Type)(#61076-)
Track Shoe (Lubricate Type) (560mm Wide) (Master Link 2 Place Type) (Heavy-Duty)(#61076-)
Track Shoe (Lubricate Type) (610mm Wide) (Master Link 2 Place Type) (Heavy-Duty)(#61076-)
Track Shoe (Lubricate Type) (660mm Wide) (Master Link 2 Place Type) (Heavy-Duty)(#61076-)
Track Frame (L.H.)
Track Frame (R.H.)
Track Roller Guard
Work Equipment
Dozer Frame
C-Frame
Dozer Frame (Reinforced Type)
Trunnion Less (For Shipping)
Dozer Frame (For Coal Dozer)
Dozer Frame (Cold Weather A.Spec.)
Frame (Rake Dozer)
Blade Semi-U Dozer
Angle Blade
Blade Semi-U Dozer (Reinforced Type)
Blade Full-U Dozer
Blade Full-U Dozer (Reinforced Type)
Blade Semi-U Dozer (With Pusher Plate)
Blade Coal Dozer
Blade Semi-U Dozer (Dust Disposal Spec.)
Angle Blade (Rake Banles)(#60755-)
Straight Rock Rake Dozer
Straight Rake Dozer
Blade Lift Cylinder Piping
Blade Lift Cylinder Piping (With Sweeper)(#60755-)
Blade Tilt Cylinder And Brace (For Tilt Dozer)
Blade Tilt And Pitch Cylinder (For Pitch Dozer)
Brace (Rake Dozer)
Blade Tilt Piping (For Tilt Dozer)
Blade Tilt Piping (For Pitch Dozer)
Straight Frame Cover (For Rake Dozer)
Ripper Beam And Arm (For Multi Ripper)
Ripper Beam And Arm (For Giant Ripper)
Ripper Beam And Arm (For Giant Ripper) (With Pusher Block)(#60393-)
Ripper Shank (For Multi Ripper)
Ripper Shank (For Giant Ripper)
Ripper Point (Symmetry¤Yellow¤Short)
Ripper Point (Non Symmetry¤Yellow¤Long)
Ripper Point (Non Symmetry¤Red¤Long)
Ripper Point (Red¤Short)
Ripper Point (Symmetry¤Red¤Long)
Ripper Mount
Ripper Cylinder Piping (For Variable Type Ripper)
Ripper Cylinder Piping (For Fixed Type Ripper)
Pin Puller Cylinder Piping
Ripper Point Light(#60001-61199)
Ripper Point Light(#61200-)
Drawbar
Counter Weight
Ripper Light (R.H.)(#60001-61199)
Ripper Light (R.H.)(#61200-)
Marks And Plates
Marks And Plates (English)(#60001-61047)
Marks And Plates (English)(#6104
Marks And Plates (Arabic)(#60001-61047)
Marks And Plates (Arabic)(#6104
Marks And Plates (Indonesian)(#60001-61047)
Marks And Plates (Indonesian)(#6104
Marks And Plates (Spanish)(#60001-61047)
Marks And Plates (Spanish)(#6104
Marks And Plates (German)(#60001-61047)
Marks And Plates (German)(#6104
Marks And Plates (French)(#60001-61047)
Marks And Plates (French)(#6104
Marks And Plates (Portuguese)(#60001-61047)
Marks And Plates (Portuguese)(#6104
Marks And Plates (Russian)(#60001-61047)
Marks And Plates (Russian)(#6104
Marks And Plates (Chinese)(#60001-61047)
Marks And Plates (Chinese)(#6104
Marks And Plates (Persian)(#60001-61047)
Mark And Plates (Persian)(#6104
Marks And Plates (English) (For U.S.A. And Puertorico)(#60001-61047)
Marks And Plates (English) (For U.S.A. And Puertorico)(#6104
Marks And Plates (English Ec Spec.)(#60001-61047)
Marks And Plates (English) (Eu)(#6104
Marks And Plates (German Ec Tbg Spec.)(#60001-61047)
Marks And Plates (German And English) (Eu)(#6104
Marks And Plates (French Ec Spec.)(#60001-61047)
Marks And Plates (French And English) (Eu)(#6104
Marks And Plates (Spanish Ec Spec.)(#60001-61047)
Marks And Plates (Spanish And English) (Eu)(#6104
Marks And Plates (Portuguese And English) (Eu)(#6104
Marks And Plates (Italy And English) (Eu)(#6104
Marks And Plates (Spanish) (Character)(#6104
Marks And Plates (Portuguese) (Character)(#6104
Marks And Plates (English) (Character) (Except U.S
Marks And Plates (Turkish) (Character)(#6104
Mark And Plate (Rear Side) (Except Japan)
Marks And Plates (Center Of Gravity)
Mark And Plate (Except Japan) (R.O.P.S.)
Mark And Plate (Except Japan) (Seat Belt)
Accessory
Spare Parts (Except Japan)
Cap And Overall
Tool
Miscellaneous
Vandalism Protection Cap
Vandalism Protection Cap (With Chain)
Sweeper (For Forest)(#60755-)
Pre Heating (-30ßc)
Service Kit And Component Parts
Service Kit
Shoe Bolt And Nut Service Kit
Track Link (Lubricate Type) (Master Link 2 Place Type) (Supply Parts)(#61076-)
Hydraulic Pump (1 2) (Power Line)
Hydraulic Pump (2 2) (Power Line)
Hydraulic Pump (1 2) (Work Equipment)
Hydraulic Pump (2 2) (Work Equipment)
Scavenging Pump
Blade Lift Cylinder
Blade Tilt Cylinder (For Tilt Dozer)(#60001-61092)
Blade Tilt Cylinder (For Tilt Dozer)(#61093-)
Blade Tilt Cylinder (For Pitch Dozer)(#60001-61092)
Blade Tilt Cylinder (For Pitch Dozer)(#61093-)
Ripper Lift Cylinder(#60001-.)
Ripper Lift Cylinder(#.-)
Ripper Tilt Cylinder(#60001-.)
Ripper Tilt Cylinder(#.-)
Pin Puller Cylinder
Hydraulic Tank (Control Valve) (4-Spool) (1 6)
Hydraulic Tank (Control Valve) (4-Spool) (2 6)
Hydraulic Tank (Control Valve) (4-Spool) (3 6)
Hydraulic Tank (Control Valve) (4-Spool) (4 6)(#60001-60271)
Hydraulic Tank (Control Valve) (4-Spool) (4 6)(#60272-)
Hydraulic Tank (Control Valve) (4-Spool) (5 6)
Hydraulic Tank (Control Valve) (4-Spool) (6 6)(#60001-60271)
Hydraulic Tank (Control Valve) (4-Spool) (6 6)(#60272-)
P.P.C. Valve (For Ripper Control)
P.P.C. Valve (For Blade Control)(#60001-60271)
P.P.C. Valve (For Blade Control)(#60272-)
E.P.C. Valve
Engine Mount
Exhaust Pipe
Exhaust Pipe¤ Short
Wiring¤ Engine
Damper
Air Compressor(#.-)
Heater Line
Scraper Sub Pump
Reserve Tank
Cooling Line
Oil Cooler Line
Hydraulic Oil Line
Fuel Line
Battery (Ns200 Dry)
Battery (C200 Dry)
Back Up Alarm
Universal Joint
Bevel And Shaft
Steering Case (1 2)
Steering Case (2 2)
Power Line Piping
Concentrated Piping
Noise Absorption
Control
Valve Body
Power Line Mount
Transmission (Case)
Power Line Filter
Additional Oil Line
Ripper Blank Parts
Pitch Valve (C B)
Hydraulic Pump Line
Blade Tilt Line
Main Frame
Equalizer Bar
Pivot Shaft
Turn Table(#60204-)
Arm Rest
Seat Belt (For Kab)
Cab (Body)
Cab (Sash And Grip)
Cab (Wiper)
Cab (Am Radio)
Cab (Radio Less)
Cab (Accessory)
Floor Mat
Back Mirror
Sunvisor
R.O.P.S. Guard
Extinguisher
First Aid Box
Thermos Bottle
Lunch Box
Floor Frame
Rear Floor Mount
Front Floor Mount
Dashboard (Heater)
Heater Unit
Monitor Panel
Panel Cover Lock
Floor Frame Wiring
Parking Lever
Fuel Control Lever
Pin Puller Switch
Scraper Control
Ripper Control
Window Washer
Guard
Radiator Guard
Fan (Blower)
Fan (Reversible)
Lift Cylinder Less
Head Lamp
Radiator Mask
Pre Screen Cover
Battery Holder
Wiring (Fender)
Fender
Fender (Pre Heater)
Hood Mount (Fender)
Battery (Ns200 Wet)
Battery (C200 Wet)
Hydraulic Tank
Hydraulic Tank Line
C.L.S.S. Valve
P.P.C. Valve Line
Charge Line (C B)
Fender Related
Fender Cover
Rear Lamp
Rear Cover
Rops Mount
Under Guard
Under Carriage
Front Idler(#.-)
Idler Cushion
Track Roller
Track Bogie
Carrier Roller
Track Frame (L.H.)
Track Frame (R.H.)
Track Roller Guard
Work Equipment
Dozer Frame
C-Frame
Frame (Rake Dozer)
Blade Semi-U Dozer
Angle Blade
Blade Full-U Dozer
Blade Coal Dozer
Straight Rake Dozer
Brace (Rake Dozer)
Ripper Mount
Drawbar
Counter Weight
Marks And Plates
Accessory
Cap And Overall
Tool
Miscellaneous
Pre Heating (-30ßc)
Service Kit
Scavenging Pump
Blade Lift Cylinder
Pin Puller Cylinder
E.P.C. Valve
- KOMATSU Fault Codes
