Komatsu Bulldozer D65E-12 D65P-12 D65EX-12 D65PX-12 Shop Manual SEBM001924
Type of Machine: Bulldozer
Type of Manual: Shop Manual
Model: Komatsu D65E-12 D65P-12 D65EX-12 D65PX-12 Bulldozer
Serial Number: 60001 and u
Publication Date: 08.2020
Form Number: SEBM001924
Number of Page: 1426 Pages
Foreword
General
How To Read The Shop Manual
Hoisting Instructions
Method Of Disassembling, Connecting Push-Pull Type Coupler
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Table
Units
01 General
General Assembly Drawing
Specifications
Weight Table
Table Of Fuel, Coolant And Lubricants
10 Structure And Function
20 Testing And Adjusting
Standard Value Table For Engine
Standard Value Table For Chassis
Standard Value Table For Electrical System
Tool List For Testing And Adjusting
Adjusting Valve Clearance
Measuring Compression Pressure
Measuring Blowby
Adjusting Fuel Injection Timing
Measuring Exhaust Color
Measuring Boost Pressure
Measuring Exhaust Temperature (D65p,Ex,Px)
Measuring Engine Oil Pressure
Measuring Engine Speed
Testing Fan Belt Tension
Measuring Speed At Torque Converter Stall
Adjusting Fuel Control Linkage
Adjusting Steering And Directional Lever, Gear Shift Lever, Parking Brake Lever Linkage (D65e,P)
Adjusting Directional Lever, Gear Shift Lever, Parking Brake Linkage (Dg5ex,Px)
Adjusting Brake Pedal Linkage
Adjusting Work Equipment Control Linkage
Adjusting Straight Tiltdozer
Adjusting Ppc Valve
Measuring Power Train Oil Pressure
Testing And Adjusting Work Equipment Hydraulic Pressure (D6se,P)
Testing And Adjusting Work Equipment, Steering Hydraulic Pressure (D65ex,Px)
Testing And Adjusting Control Circuit Pressure
Measuring Output Pressure Of Ppc Valve
Measuring Oil Leakage From Hss Motor (Dg5ex,Px)
Measuring Leakage Inside Cylinder
Bleeding Air From Hydraulic Cylinder
Releasing Remaining Pressure From Hydraulic Circuit
Procedure For Simple Test Of Steering Brake Performance
Procedure For Testing Sensors
Testing And Adjusting “Open” And “Close” Lock And Steady Rest Of Operator’S Cab Door
Troubleshooting
30 Disassembly And Assembly
40 Maintenace Standard
Engine Mount
Power Train Unit Mount
Damper, Universal Joint
Torque Converter, Pto
Transmission Control Valve
Main Relief Valve
Bevel Gear Shaft, Steering Clutch, Steering Brake (D65e,P-12)
Bevel Gear Shaft, Hss Steering Brake (1/2) (D6se,P-12)
Bevel Gear Shaft, Hss Steering Brake (2/2) (D65ex,Px-12)
Bevel Gear Shaft, Hss Steering Brake (1/2) (D65ex,Px-12)
Steering Control Valve (D6se,P-12)
Bevel Gear Shaft, Hss Brake Valve (D6sex,Px-12)
Power Train, Lubrication Pump
Ppc Pump
Ppc Valve
Ppccharge Valve
Final Drive
Full-Scale Drawing Of Sprocket Tooth Shape
Hull Frame
Track Frame, Recoil Spring
Idler
Track Roller
Carrier Roller
Track Shoe (Dry Type)
Track Shoe (Lubricated Type)
Suspension
Hydraulic Pump (D55e,P-12)
Hydraulic, Hss Pump (D65ex,Px-12)
Hss Motor (D65ex,Px-12)
Main Control Valve
Work Equipment Cylinder
Work Equipment
Cutting Edge, End Bit
Ripper
90 Others
Trimming Dozer Ddmo6o-4a
D65ex,Px-12 For Ka Spec.
